Tilbage til HIFI4ALL.DK 25. juni 2026 | 01:23
Emne Emne: Hvad er dette? (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
Kasper
Sendt: 10 Marts 2004 kl. 19:49 | IP-adresse registreret
Er det kun mig der finder denne annonce underlig?
men noget helt andet er der nogen der ved hvad det er?
http://my.qxl.dk/accdb/viewItem.asp?IDI=11214131&Listing Type=0&ListingSort=1&PageNum=1&Catg=10448
Til top Vis Kasper's Profil Søg efter andre indlæg skrevet af Kasper
Autechre
Bruger siden: 10 Oktober 2003
Sendt: 10 Marts 2004 kl. 20:00 | IP-adresse registreret
Taget fra: http://www.beoworld.co.uk/:
The Ambiophonic Stereo Adaptor System produced an ambiophonic, or 'pseudo-surround' sound to your Bang & Olufsen passive loudspeaker system when used with separate rear speakers. In the mid 1970's there were quite a few of these units from various manufacturers available; Bang & Olufsen produced this non-powered unit to provide the same ambiophonic effect when you couldn't afford, or didn't want to afford, one of the quadraphonic music systems which were on sale.
Receivers and amplifiers with the 'ambio' function were products which, apart from stereo, could also reproduce the ambience or sound information of a room. Ambient information was included on most stereo vinyl recordings but could not be reproduced by a sound system with two loudspeakers or an ordinary stereo amplifier. Bang & Olufsen systems with the 'ambio' function had facilities which electronically subtracted the difference signal (i.e. the difference between left and right channels) which contained ambient information. This information was fed into two extra loudspeakers which were placed as side speakers in a room. Ambiophony was an extension of stereo reproduction and enhanced the sense of realism. It could be used with nearly all stereo programme materials.
Produced from 1974 - 78, the unit could be used with such stereo receivers as Beomaster 4400 which was Bang & Olufsen's last model to incorporate with ambiophonic circuitry.
Til top Vis Autechre's Profil Søg efter andre indlæg skrevet af Autechre
Kasper
Sendt: 10 Marts 2004 kl. 20:56 | IP-adresse registreret
jeg er ikke helt sikker på at jeg forstår hvad der står, men er det noget med at den genererer "falske" kanaler til surround?
kyhn
Bruger siden: 05 Februar 2004
Sendt: 11 Marts 2004 kl. 13:50 | IP-adresse registreret
Ja du kan betragte det som DINO surround, altså fra før tingene blev som de er i dag...
Spøg til side, det var noget der var hot i 70´, altså inden man begyndte med dolbys surround systemer
Skobbolop
Bruger siden: 29 Maj 2003
Sendt: 11 Marts 2004 kl. 14:12 | IP-adresse registreret
haha.... herlig sælger:
"En Box fra B&O til stereo anlæget .men hvad den skal bruges til ved jeg ikke."
Til top Vis Skobbolop's Profil Søg efter andre indlæg skrevet af Skobbolop
Kurt von Kubik
Bruger siden: 14 Oktober 2003
Sendt: 11 Marts 2004 kl. 15:24 | IP-adresse registreret
Halløjsa!
Ambiofoni var aldrig rigtig hot.
B&O og enkelte andre producerede recievere med denne funktion, som er et sæt dæmpede sidehøjttalere, som derfor ikke behøvede at være særligt kraftige.
Ambiofoni betyder kort og godt, at ambiencen (rumklangen) blev fremhævet på den måde.
Det var altså et trick for at understrege det rumlige aspekt ved stereo.
Omkring samme tid hærgede quadrofonien, som var et 4 kanals system. Det druknede dog bare totalt i en formatkrig af kaliber.
CD4, Matrix systemerne SQ og QS.
Læs engang dette sjove site om krigen ale tabte.
http://personal.riverusers.com/~manderso/quaddisc/quadfrmt.h tm
Nautilus
Bruger siden: 09 November 2003
Sendt: 11 Marts 2004 kl. 15:51 | IP-adresse registreret
Jeg må sige at der er nogle gamle kloge hoveder herinde...
Til top Vis Nautilus's Profil Søg efter andre indlæg skrevet af Nautilus
Kasper
Sendt: 11 Marts 2004 kl. 15:59 | IP-adresse registreret
Mange tak for svarene, det er altid rart at blive klogere
