Tilbage til HIFI4ALL.DK 29. juni 2026 | 05:09
Emne Emne: pa mellemtone til dipol (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
lille_smed
Bruger siden: 08 Januar 2007
Sendt: 10 Maj 2009 kl. 18:44 | IP-adresse registreret
hej har kigget lidt på denne enhed
men er lidt usikker på om den kan det jeg gerne vil med den..  jeg ønsker at den skal spille fra 80 hz til ca 1400 hz.. i et dipol setup
nogen der kender den  eller ahr andre forslag til enhed .. det skal være en 12"
12'' højttaler TRUVOX-1225
Varenummer: 104990 | TRUVOX-1225
Klik for større billede
Printvenlig
CELESTION
is one of the most appealing names in the world of speakers and the most interesting speakers of this traditional company are now available from MONACOR INTERNATIONAL. These speakers perfectly complete the wide product range offered by IMG Stage Line in some areas and thus an overall product range is now available which perfectly meets all requirements.
Professional PA bass-midrange speaker, 500WMAX, 250WRMS, 8O
30cm (12") bass-midrange speaker vom CELESTION of very high power capability. Stable steel basket, equipped with a Kevlar fiber reinforced cellulose cone. A wide frequency response with good attenuation, suitable for all general PA applications, with good limit frequency in BR cabinets of medium size.
TEKNISKE DATA:
Impedance (Z) 8O
Resonant frequency (fs) 62Hz
Max. frequency range f3-4,000Hz
Music power 500WMAX
Power rating (P) 250WRMS
SPL (1W/1m) 99dB
Suspension compl. (Cms) 0.13mm/N
Moving mass (Mms) 46g
Mech. Q factor (Qms) 6.57
Electr. Q factor (Qes) 0.52
Total Q factor (Qts) 0.48
Equivalent volume (Vas) 57 l
DC resistance (Re) 5.3O
Force factor (BxL) 13.72Tm
Voice coil induct. (Le) 0.8mH
Voice coil diameter Ø 63mm
Voice coil former Kapton
Linear excursion (XMAX) ±2.4mm
Eff. cone area (Sd) 551cm2
Magnet weight 50oz.
Weight 3.9kg
musicus
Sendt: 11 Maj 2009 kl. 00:32 | IP-adresse registreret
Synes at Qts på 0.48 virker besynderligt højt for en enhed med 99db følsomhed - det mindes jeg ikke at have set nogensinde
Men det er Celestion, og en af deres 10" modeller har ry for god mellemtone
Men så længe du ikke forventer mirakler er den vel brugelig
Men Truvox er Monacor, og jeg synes deres prissætning på mange enheder er helt hen i vejret
lille_smed
Sendt: 11 Maj 2009 kl. 10:34 | IP-adresse registreret
Men Truvox er Monacor, og jeg synes deres prissætning på mange enheder er helt hen i vejret. hvorfor syntes du det..
det jeg forventer at den mellemtone .. er at den skal spille godt ..  det jeg savner i mit setup lige nu er lidt smæk i mellem tonen .. det har jeg bare ikke hørt nogen hifi enheder kunne give ..
 har du et forslag til valg af enheder
Søren Korsgaard
Bruger siden: 20 Januar 2006
Sendt: 16 Maj 2009 kl. 22:08 | IP-adresse registreret
Jeg er lige hjemkommet fra et besøg hos Steen Thorhauge og han har bygget et sæt Dipol højtalere med noget af det billigste Monacor der kan skaffes og jeg må sige jeg blev blæst omkuld af overraskelse. De lød fænomænalt godt og rumfornemmelsen var helt sublim. Tag og kontakt ham og få at vide hvilke enheder han har brugt for jeg synes han har ramt plet i forhold til dipol lyden.
MVH
Søren Korsgaard
Til top Vis Søren Korsgaard's Profil Søg efter andre indlæg skrevet af Søren Korsgaard
Jakobsen
Bruger siden: 18 Maj 2003
Sendt: 16 Maj 2009 kl. 22:58 | IP-adresse registreret
