| Sendt: 29 November 2008 kl. 22:21 | IP-adresse registreret
Sakset fra avsforum " Q. Why isn't the Dolby TrueHD / DTS-MA light turning on when I play
a Blu Ray on my PS3?? I set up everything correctly but all is says is
"MULTICH IN". What the heck does that mean?
A. The PS3 cannot bitstream the new hi-definition audio codecs: Dolby
Digital Plus, Dolby TrueHD, and DTS-HD and DTS-MA. You will NEVER EVER
see the "Dolby TrueHD" or "DTS-MA" light up on the receiver when using
a PS3 as your only Blu Ray player.
In order to hear these new codecs from the PS3, the PS3 must decode
them internally and output them as Multichannel PCM (also sometimes
referred to as MPCM or LPCM). Make sure that you change your PS3 audio
settings to enable multichannel PCM output (please refer to the PS3's
instructions or the PS3 sections of AVSForum for specific questions on
the PS3).
Please refer to the PS3 FAQ, and scroll down to the “AUDIO SETTINGS” section:
http://www.avsforum.com/avs-vb/showthread.php?t=1058533
If you have set everything up correctly, the Denon display will light
up as "MULTICH IN", indicating that you are receiving multichannel PCM.
If you hit "Status" on the Denon, the display should say something like
"PCM 48kHz 3/2/.1" indicating that you are receiving 5.1 channel PCM (3
fronts / 2 surrounds / .1 LFE track).
You can also check the info on the PS3 to verify that it is outputting
the correct soundtrack. Note that sometimes a Blu Ray will default to
the standard DD/DTS track, so you might have to manually select the
TrueHD/DTS-MA soundtrack.
If you want to disable the tone controls and any processing, you can
hit the "DIRECT" button on the Denon remote, and the display will now
read "MULTICH DIRECT". This is exactly analagous to the "DIRECT" vs
"STEREO" modes for listening to 2-channel music, like that from a CD.
You can still enable Audyssey EQ'ing when listening in "MULTICH DIRECT"
mode, but all other processing options (like tone control) are disabled." Fandt det her i denne faq http://www.avsforum.com/avs-vb/showthread.php?t=1050097 Er selv lidt lun på denne forstærke som alternativ til onkyo og sony..
