Tilbage til HIFI4ALL.DK 2. juli 2026 | 21:05
Emne Emne: Urgent: Sanyo Z2 and Pal material (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
Edgler Vess
Bruger siden: 02 Februar 2004
Sendt: 02 Februar 2004 kl. 22:01 | IP-adresse registreret
Hi
This is my first post ... and
... sorry for this English post ...
It seems that around here there´s a lot of useful information for Europpen users of Sanyo Z2 and PAL material ...so please help me on the following ...
and if possible summarize the most important info that exists in other threads .
My questions are :
1) Are there any general problems for Pal material ?
1) Are there any problems with DVI output 720p and 50Hz ?
( with a dvdplayer , not HTPC )
3) I have a Yamakawa dvdplayer with a DVI output . Has anyone try this one ?
4)Is it better to use 576p output or 720p 50Hz output ?
Thanks in advance
Edgler
Til top Vis Edgler Vess's Profil Søg efter andre indlæg skrevet af Edgler Vess
Guldberg
Bruger siden: 11 Januar 2004
Sendt: 02 Februar 2004 kl. 23:28 | IP-adresse registreret
Im not an Z2 owner, but i considered one when buying resently so i spend tons of hours reading around the web, and it seams that a lot of users is having problems with jitter when feeding it its native resolution because it only accepts 60Hz. As far as i remember it accepts 50Hz at 576p, so maybe it would be an better idea, even though it would be using the internal scalar
Til top Vis Guldberg's Profil Søg efter andre indlæg skrevet af Guldberg
Guldberg
Sendt: 02 Februar 2004 kl. 23:39 | IP-adresse registreret
Have you checked out avsforum yet? There's a couple of threads regarding your questions, here's one f.x http://www.avsforum.com/avs-vb/showthread.php?s=ff45e64da403 532d3305e4121c59336e&threadid=345340&perpage=20& highlight=pal%20AND%20z2&pagenumber=1
Thue K
Sendt: 03 Februar 2004 kl. 10:00 | IP-adresse registreret
Firmware release 1.04 fixed the bug with 50hz and 720p. Sanyo will update your Z2 to the newest version without charge.
tranum1
Bruger siden: 05 Oktober 2003
Sendt: 03 Februar 2004 kl. 10:22 | IP-adresse registreret
According to avsforum there is still jitter with 50hz and 720p, even with firmware 1.06. It was reported that 1.06 should have fixed the problem, but it has now been testet and shows that it is still a problem. So I guess no fix yet.
Til top Vis tranum1's Profil Søg efter andre indlæg skrevet af tranum1 Besøg tranum1's Websted
Terning
Bruger siden: 23 Oktober 2003
Sendt: 03 Februar 2004 kl. 10:51 | IP-adresse registreret
Hvor skal man henvende sig hvis man gerne vil have opdateret sin Sanyo Z2 projektor?
Til top Vis Terning's Profil Søg efter andre indlæg skrevet af Terning
