Tilbage til HIFI4ALL.DK 29. juni 2026 | 11:33
Emne Emne: surround 7.1??? (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
jimmi80
Bruger siden: 02 Marts 2008
Sendt: 02 Marts 2008 kl. 15:34 | IP-adresse registreret
Samsung AV-R720R overvejer at købe denne, men vil høre om det er muligt at afvikle stereo på den? og hvad betyder det at den ikke kan afvikle true hd sound og ddp?
Teknik:
Remote Control Is an Infra-red remote control included?  Yes
Pro-Logic/pro-Logic 2/pro-Logic 2x Analogue surround sound system - for TV and video. Pro-Logic 2 features stereo effect rears, whilst Pro-Logic 2x can output in 6.1 or 7.1  No/Yes/Yes
5.1/6.1/7.1 The number of channels. 5.1 is the basic standard. 6.1 adds a rear centre. 7.1 adds side effect speakers.  7.1
Dts/dts-Es Digital Theatre System - a rival to Dolby Digital. DTS-ES is a 6.1 format that offers a rear centre speaker.  Yes/Yes
Thx Select 2/thx Ultra 2 Is it THX Certified? A specification requirement from Lucus Studios of Star Wars fame. THX Select 2 is the required standard for small/medium sized rooms, THX Ultra 2 is for larger rooms.  No/No
Video Inputs Inputs for visual sources - DVD, video etc - on rear of unit.  4
Audio Inputs Inputs for hi-fi sources - CD, aux etc - on rear of unit  5
Built-In Tuner Built-in analogue or digital radio?  FM/AM
Coaxial Outputs Number of coaxial digital outputs to loop digital information through.  0
Coaxial Inputs Number of coaxial digital inputs to input digital sources such as DVD player  1
Optical Outputs Number of optical digital outputs to loop digital sources through.  0
Optical Inputs Number of optical digital inputs to input digital sources such as DVD players  2
Sub Out Does it have a seperate connection for subwoofer  Yes
6-Channel Input Does it have a 5.1 analogue input? - uses 6 RCA phono sockets  Yes
Power Rating (Wpc) Maximum power output per channel - RMS into 8 ohms  100 x 7
Hdmi Interface Is HDMI included? HDMI offers the highest quality, digital connection. The number given relates to the number of HDMI inputs fitted - a single output is standard unless otherwise stated.  Yes - 2
Dolby Digital Plus/dolby Truehd Are DDP or TrueHD included? Dolby Digital Plus is the next-generation, "better-than-DVD" sound processor and works up to 7.1 channels. TrueHD is Dolby's current ultimate system and has been designed specifically to get the full potential from HD-DVD and Blu-ray.  No/No
Dts High Res Audio/dts Master Audio Are DTS HRA or MA included? DTS-HD High Resolution Audio delivers sound even more accurate and consistent than standard DTS. It has been designed to extract the most from HD-DVD and Blu-ray. DTS-HD Master Audio takes this one step further and is capable of delivering audio that is bit-for-bit identical to the original.  No/No
Til top Vis jimmi80's Profil Søg efter andre indlæg skrevet af jimmi80
