Tilbage til HIFI4ALL.DK 5. juli 2026 | 15:01
Emne Emne: Ortofon MC Windfeld (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
king
Montør i Fona - 3/3 advarsler
Bruger siden: 15 Oktober 2003
Sendt: 13 September 2007 kl. 18:50 | IP-adresse registreret
 Uha ... denne her pickup skal jeg bare høre - den må vi lave en test på
Ortofon is launching the MC Windfeld, a newly developed moving coil cartridge using state-of-the-art technology. This highly advanced design, which is the world’s most hi-tech analogue cartridge, may be seen as a tribute to Ortofon’s departing engineer Per Windfeld, who has for more than 30 years been a feature of the high-end culture as the head of development behind amazing cartridges such as the Ortofon MC 20, Concorde, Rohmann, Jubilee, Kontrapunkt, etc.
Ortofon MC Windfeld TECHNICAL DATA
  • Output voltage at 1000 Hz, 5cm/sec. 0,3 mV
  • Channel balance at 1 kHz < 0,2 dB
  • Channel separation at 1 kHz > 28 dB
  • Channel separation at 15 kHz > 22 dB
  • Frequency range at - 3dB 10-80.000 Hz
  • Frequency response 20-20.000 Hz + / - 1 dB
  • Tracking ability at 315Hz at recommended tracking force 100 μm
  • Compliance, dynamic, lateral 16 μm/mN
  • Stylus type Nude Ortofon Replicant 100, special polished
  • Stylus tip radius r/R 5/100 μm
  • Tracking force range 2,3-2,8 g (23-28 mN)
  • Tracking force, recommended 2,6 g (26 mN)
  • Tracking angle 23°
  • Internal impedance, DC resistance 4 Ohm
  • Recommended load impedance > 10 Ohm
  • Cartridge body material Stainless steel/special alloy
  • Cartridge colour Black/Black
  • Cartridge weight 13,0 g
    Ortofon MC Windfeld Download Brochure PDF
    Milu
    Sendt: 13 September 2007 kl. 19:11 | IP-adresse registreret
    Uha den ser spændende og smuk ud - 13 g, så er den tungere end min Dyna!
    Ok, den og Jubilee kunne være spændende at høre.
    Er der pris på den endnu?
    king
    Sendt: 13 September 2007 kl. 19:49 | IP-adresse registreret
    Ja... men prøv lige og se hvad flot den spore ..... 100My
  • Her kan Dynavector ikke være med !
    Jakobsen
    Bruger siden: 18 Maj 2003
    Sendt: 13 September 2007 kl. 19:57 | IP-adresse registreret
  • He He king så blev du lige 20.000kr. fattigere der
    den ser fin ud...... hvis den slår Jubilee så er det en konge PU
    og mon den ikke gør det.......
    Wauw... det bliver spændende og høre den.......
    Milu
    Sendt: 13 September 2007 kl. 19:58 | IP-adresse registreret
    Ja det er sgu' nogle gode tal!
    Ortofon lavede/laver en serie i Tyskland som jeg synes kunne være spændende at høre top-modellen fra! Var det Venice den hed?
    krenzler
    Sendt: 13 September 2007 kl. 21:26 | IP-adresse registreret
    Windfeld bliver testet i danske High Fidelity på et tidspunkt. Forhåbentlig inden alt for længe.
    Prisen herhjemme er 23.000,-kr. (High End Sound).
    3.400,-$ hos Needledoctor.
    krenzler
    Sendt: 13 September 2007 kl. 21:42 | IP-adresse registreret
    Vienna.
    Oh Vienna!
    Milu
    Sendt: 13 September 2007 kl. 22:43 | IP-adresse registreret
    krenzler skrev:
    Vienna.
    Oh Vienna!
    Ja du har ret, det er vist top modellen i den serie, men jeg mente egentlig denne, da jeg synes den er ret smuk:
    Venice
    janils
    Pladespilleren.dk
    Bruger siden: 02 Januar 2004
    Sendt: 13 September 2007 kl. 23:57 | IP-adresse registreret
    Ja, den Winfeld er spændende. Så og hørte den i München.
    Har snakket med Ortfon om at få en til test, men den er dog ikke kommet endnu. De snakkede om ultimo august. Måske der er kommet så meget gang i high-end analog lyd, at de har lidt svært ved at følge med
    Jan Nielsen
    gli-
    Highend Sound
    Bruger siden: 18 April 2003
    Sendt: 15 September 2007 kl. 02:07 | IP-adresse registreret
    De der tyske model navne, er det ikke de som for vi andre hedder Kontrapunkt?
    king
    Sendt: 15 September 2007 kl. 08:39 | IP-adresse registreret
    Hejsa Gli
    Nej ..... de er lavet kun til det tyske marked , og der er lavet en del om på selve opbygningen  - så de er ikke de samme som Kontrapunkt serie !
    Ps... man kan nemlig også købe Kontrapunkt serie i Tyskland !
    krenzler
    Sendt: 15 September 2007 kl. 08:47 | IP-adresse registreret
    Nej - kontrapunkt modellerne sælges også i Tyskland.
    PhonoPhono.de.
    Jeg mener at kunne huske at der engang blev testet en Ortofon MC fra "V" serien i danske High Fidelity men jeg mindes ikke lige hvilken model.
    krenzler
    Sendt: 15 September 2007 kl. 08:49 | IP-adresse registreret
    Ups! King du var hurtigere. (havde ikke set dit indlæg).
    gli-
    Highend Sound
    Sendt: 16 September 2007 kl. 00:08 | IP-adresse registreret
    OBS, troede det var Kontrapunkt serien med et tysk navn, men Vienna og Venice den ligge også over Jubilee, i pris om ikke andet. Du har ret King data er anderledes, så specielt for die Deutche, hatten af............
    men hvornår er Windfelt klar, Janils har vel lovning på en til test
    trapez
    Dobbeltprofil: Slowon
    Bruger siden: 24 Januar 2007
    Lokalitet: Fyn Øst
    Sendt: 16 September 2007 kl. 01:20 | IP-adresse registreret
    Jubilee er nu ikke hverken prins eller dronning,kun en smule bedre end rohman som heller ikke er noget særligt udover overvurderet!
    Generelt er ortofon ikke pengene værd imho,måske med om40 og mc70 som undtagelser...og ja jeg har haft dem jeg taler om.
    Til prisen på den ny kan man erhverve en Audio Note IO som gør det slemme ved alle ortofoner.
    Til top Vis trapez's Profil Søg efter andre indlæg skrevet af trapez
    king
    Sendt: 16 September 2007 kl. 07:41 | IP-adresse registreret
    Oki.... hvilken arm og hvilken værk og Riaa kørte du med du da havde Ortofon Jubbili og Rohman ??
    Jakobsen
    Sendt: 16 September 2007 kl. 09:38 | IP-adresse registreret
    OK det er så din mening.....
    men jeg kan da meddele dig at der er mange der er uenige
    Jubilee er da en super PU...... ellers må der være noget galt med det grej der er brugt
    eller dårlig justering.....
    trapez
    Lokalitet: Fyn Øst
    Sendt: 16 September 2007 kl. 10:39 | IP-adresse registreret
    der skal da nok være nogen uenige derude...det er typisk folk der aldrig har betalt så meget for en pickup,og derfor ingen referencer har!
  • den der nedladende holdning med "ellers må der være noget galt med det grej der er brugt
    eller dårlig justering....." er patetisk,da man (eller ialtfald jeg aldrig ville investere så mange penge i noget jeg ikke havde forstand til at udnytte - ville du?
    du skriver jubilee er en super pickup - hvor ved du det fra?har du en?
  • Til top Vis trapez's Profil Søg efter andre indlæg skrevet af trapez
    trapez
    Lokalitet: Fyn Øst
    Sendt: 16 September 2007 kl. 10:44 | IP-adresse registreret
    mission 774 - micro seiki 505 - helius orion - micro seiki 2000 samt bl77 med 5 kilo acryltallerken - steen thorhauge samt en mere vellykket DIY,plus diverse seriøse stepups.
    king
    Sendt: 16 September 2007 kl. 10:53 | IP-adresse registreret
    Ortofons dyre MC pickuper lyder bedst med MCTrafo som stepup - da de har en Internal impedance under 10 ohm....... !!
