Tilbage til HIFI4ALL.DK 16. juni 2026 | 13:17
Vintage
 HIFI4ALL Forum : Vintage
Emne Emne: Quadrofoni (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
Hackenberg
Bruger siden: 16 Januar 2005
Sendt: 11 April 2007 kl. 23:21 | IP-adresse registreret
Hej alle.
Jeg kom lige en postgang for sent til den første firekanalsbølge. Er der derfor nogen der kan hjælpe mig med følgende spørgsmål: Havde quadrofoniforstærkere firekanalsindgange på line-niveau? Var der andre signalkilder end gramofonen? Måske spolebåndoptagere?
Mvh Claus.
Hackenberg
Til top Vis Hackenberg's Profil Søg efter andre indlæg skrevet af Hackenberg
r-l-b
Sendt: 11 April 2007 kl. 23:41 | IP-adresse registreret
her lidt  der måske kan kaste lys (jeg kan kun huske ambiofoni)
http://www.sansui.us/images/Quad/qrx5500_6.jpg
http://www.oaktreeent.com/web_photos/Stereo_Tape_Decks/Dokorder_MC-70A_4-channel_Stereo-Quadraphonic_8-Track_Cartridge_Tape_Player_collage.jpg
Sony SQA-2030 Decoder/Rear Channel Amplifier. RM, SQ. 18 watts ch. $240 '74\**<br></font></b></i></td>
<td><center><font face=Quadraphonic Formats
< bgcolor="#008000" ="ALTERNATE"> Decoders
3-30-1999 VERSION 1.3
Please send any additions or corrections to this list to :
* /|\ * Mark Anderson
/ | \ * multichannel AT cox.net
This list can be accessed from :
http://members.cox.net/surround/
  • Quad 8-track head layout
  • JVC's CD-4 Quadraphonic Compatable Disc Format
  • CD-4 Quadraphonic Equipment
      There were several so called "matrix" systems, where the four
    channels of quadraphonics were encoded into two channels and decoded
    back to four. At least this was the intention. But the egg theory
    applies: If you take four chicken eggs and break them in a bowl, you
    can see at the bottom, four yellow rounds and the clear stuff around
    them. The moment you stick in your fork and mix them, the yellows get
    broken and it becomes VERY difficult to put them back together again.
    You possibly could portion the yellow stuff in four equal cups, but
    the other stuff is mixed with the yellow already. This was the sad
    state of the early quad matrix decoders.....many of them resembled four-
    channel MONO or at best DOUBLE-STEREO upon decoding/playback.
    Interchannel separation was 3-10db (worse than the average 25db of a
    normal stereo recording). It took years of development to perfect
    the "Logic" circuits required to properly decode the matrix , and by
    the time the really good logic decoders came to market, it was around
    1979 and way too late to save quad from doom! But, the end-stage
    decoders like the TATE II, Audionics Space & Image Composer, and the
    Sansui Vario-Matrix units are capable of 35-40db of separation!
    Although multi-channel sound has been experimented with both for
    audio and in movies since at least the 1930s, it wasn't until 1969
    that technology and the audio industry were ready to commercialize it.
    At the AES meeting in 1969 Vanguard records demonstrated DISCRETE
    four-channel sound on a four-channel reel to reel deck. Heads turned,
    production geared up and the first home quad recordings on open reel
    tape were released in 1970.
    Immediately following this...two developments are key, the
    introduction of quadraphonic 8-track tapes (easily re-engineered from
    the stereo 8-tracks of the day) and the quest for some way to get
    quadraphonics into the commercial medium of the day........the lp.
    Peter Scheiber is credited with inventing the basic mathematical
    matrix to encode four-channels into two, and then decode them back to
    four which he demonstrated in 1970 at the annual AES meeting. CBS
    bought the rights and named it SQ for Surround Quadraphonic. CBS
    went immediately to developing encoders/decoders and re-mixing albums
    into quadraphonic from their master-tape library. SQ rolled out in 1972
    to great fanfare with units from Sony, Fisher, Lafayette, Marantz and
    Pioneer just to mention a few.
    With CBS as the largest record producer in the US holding the rights,
    the other record labels were hesitant to pay "royalties" to their
    competitor...so the quest was on for something "better" and "owned" by
    ANYONE else.
    JVC of Japan, then a subsidiary of RCA worked on developing a
    different method of encoding which resulted in the CD-4 system
    (compatible-discrete 4 channel). CD-4 used a deeper more sharply angled
    groove in the record capable of carrying frequencies of 20hz - 45khz to
    carry all four channels of information with a 30khz "carrier" frequency
    to demodulate the signals back into four channels. This is the same
    method used for FM broadcasting which works great on the radio. But,
    vinyl was a different story! Shibata of Japan developed a stylus
    capable of reading the 20-45khz signal, and the encoder/demodulator was
    developed....but they had significant problems with the vinyl itself
    being able to hold the signals, and degradation due to playing was a
    real problem. JVC then invented their "super" vinyl, and the wear issue
    was finally overcome. Introduction was in late 1973. RCA now had a
    competing format without the royalty headaches..........us consumers now
    had the problem! Also, the "minor" record labels including Number 3,
    ABC Records STILL had a problem...pay royalties to RCA or CBS?
    At the same time Peter Scheiber was refining his matrix system,
    Isao Itoh of Sansui was developing a very similar system which Sansui
    named QS for Quadraphonic-Stereo. They were really "leading" the pack,
    producing their first matrix "synthesizer" in 1970, and following in
    1971 with a commercial encoder. But, being a hardware manufacturer was
    both a help and a hindrance! They couldn't produce any music for the
    format! Sansui offered QS to any and all record producers without any
    royalties.......they would make their money on the audio equipment and
    decoders! The minor labels flocked to Sansui.....Vox, Turnabout, Ode,
    Ovation, and yep.....ABC! The War was on...........
    Sansui along with all the other quad encoded formats were submitted
    to the Electronic Industry Association of Japan and the Japan Phonograph
    Association in 1972 to try and clear up the pending disaster. After
    much animosity the EIA-J and JPA designated the Sansui QS system as the
    "regular-matrix" or RM matrix for quadraphonics. Of course, this was
    immediately rejected by CBS and RCA who had too much time and $$
    invested in developing their own systems. And their industry clout in
    the US prevented ANY system from being designated the standard in the US.
    The RM designation did have one significant downside for Sansui though.
    It allowed all the other "hardware" manufacturers to include an RM
    decoder on their units without any royalty being paid to Sansui!
    So, now you know why your Pioneer, or Marantz, or JVC, or just about
    any manufacturer OTHER than Sansui has an RM decoder and not a QS
    decoder. The battle raged.........The record producers pushed their
    artists and formats. The hardware manufacturers were stuck trying to
    guess which system would prevail and who they should pay for the rights
    to produce the decoders in their unit. And those of us as consumers
    busy swapping decoders and trying to hear something great (as we were
    told) from the lousy, poor separation SQ and QS decoders of the early
    seventies. Or the alternative, the expensive and difficult to calibrate
    CD-4 system that gave us overly sensitive cartridges with plenty of
    noise and pops! Most of the hardware manufacturers lined up behind a
    format and prayed that it would make it,and then offered outboard units
    for the other formats....just in case they were wrong!
    By 1975 the writing was on the wall.......the Record producers
    wouldn't give in, and the Audio companies were willing to do anything to
    keep the dream alive. So it was then that the "second-generation" quad
    receivers hit the market....all included SQ, QS (or RM), and CD-4
    decoders built-in! Set up the rest of your system, add your Pioneer
    QX-949 or 747, Sansui QRX-7001/8001/9001, Kenwood KR-8840/9940 and play
    any of the quad formats in mostly poor SQ, noisy CD-4, or the almost
    hidden QS quadraphonic records on your system!
    Quadraphonic record production slowed.......RCA didn't introduce any
    new Quadradisc (CD-4) titles after 1975, SQ and QS held on...barely,
    with EMI/Angel finally stopping their classical series of SQ in 1979.
    And, the last QS titles were probably the DBX encoded Vox/Turnabout
    titles of 1979/80.
    "Quad" Bob
  • __________________
    pqrannes
    Lukket efter eget ønske!
    Sendt: 11 April 2007 kl. 23:45 | IP-adresse registreret
    Hackenberg skrev:
    Hej alle.
    Mvh Claus.
    Nemlig, ja. Der fandtes firekanals spolebånd med quadrofonioptagelser. Men det er mit indtryk at quadrofoni hovedsagligt blev afspillet med en almindelig grammofon, sådan at den plade man afspillede svarede til den decoder (cd4, qs, sq m.fl), som ens quadrofoni forstærker magtede. Jeg har forstået det sådan at netop den manglende enighed omkring quad-formaterne var med til at tage livet af firkanalslyden.
    Der findes et amerikansk quad forum som når rundt om alt dette: http://www.quadraphonicquad.com/
    Peter
    Jeg glemte at skrive at jeg har både en lille sansui quad receiver og en sansui quad bagforstærker, som desværre kun formår at aftaste og dekode det sjældne qs format (jeg har ikke fundet nogle plader endnu).
    Masser af vintage grej.
    www.vintagehifi.dk
    Til top Vis pqrannes's Profil Søg efter andre indlæg skrevet af pqrannes
    RogueAgent
    Bruger siden: 09 Januar 2004
    Sendt: 12 April 2007 kl. 00:00 | IP-adresse registreret
    Stings "The Soul Cages" er indspillet i Qsound.
    krenzler
    Sendt: 13 April 2007 kl. 00:49 | IP-adresse registreret
    Og en pick-up med Shibata nåleslibning.
    pqrannes
    Sendt: 13 April 2007 kl. 06:50 | IP-adresse registreret
    De quad systemer jeg har hørt om krævede ikke nogen særlig picktup såvidt jeg har forstået. De to ekstra kanaler er 'gemt' i særlige frekvensområder i det almindelige lydbillede. Quadrofoniforstærkeren/-receiverens dekoder blotlægger så disse kanaler og spiller dem i baghøjttaleren. Jeg har hørt det virke på mit eget lille quadrofoni-anlæg.
    En anden syret ting at lade quad dekoderen skabe firkanalslyd ud af almindelige plader eller cd'er, det kan nogle gange gå rigtig godt. Jeg kan huske at the Egde fra U2 altid trådt markant ud af lydbilledet og blev smidt over i den ene baghøjttalere. Fedt.
    Jeg har en Sansui bagkanalsforstærker i mit setup. Den styrer baghøjtalerne i mit vintage Scandyna/Dynaco 5.1 surround (det er en lang historie) og kan således også styre quadrofoni. Jeg mangler lige at få baghøjttalerne (Scandyny A-10ere) permanent på plads v. bagvæggen.
    Peter
    www.vintagehifi.dk
    krenzler
    Sendt: 13 April 2007 kl. 14:37 | IP-adresse registreret
    Shibata nåle havde netop dengang den særlige egenskab at de har et meget bredt frekvensområde - op til 50.000Hz.
    Wikipedia.
    QuadraDisc.
    Quadibloc.
    tubefreak
    Bruger siden: 31 Maj 2004
    Sendt: 13 April 2007 kl. 14:52 | IP-adresse registreret
    Jeg er da ejer af en Pioneer QX949A og ja der er linie indgange til lidt af hvert. Selv DR sendte i 4 kanaljer en gang. Jeg bruger den ikke men jeg har da en Pioneer båndspille der kan afspille i 4 kanaler og jeg har en del bånd, det kræver kun to forstærkere og 4 Ht´ere som jeg selvfølgelig har.
     Systemet døde på grund af producenterne ikke kunne blive enige om en standard og som så var der et hav af dekodere og standarter som folk ikke kunne hitte ud af. Det har man da lært i snurre runt lyd. Du kan se min båndoptager her.
    http://www.sitecenter.dk/maxie
    Til top Vis tubefreak's Profil Søg efter andre indlæg skrevet af tubefreak Besøg tubefreak's Websted
    pqrannes
    Sendt: 15 April 2007 kl. 16:29 | IP-adresse registreret
    Wikipedia.
    QuadraDisc.
    Quadibloc.
    Da lærte jeg lige noget. Tak.
    Peter
    www.vintagehifi.dk
    Raskolnikov
    Sendt: 15 April 2007 kl. 19:33 | IP-adresse registreret
    Det er et fantastisk format. Ærgerligt det aldrig rigtig blev til noget...gad godt at høre multikanal på LP
    Tror jeg vil prøve og sætte min Denon 2200 ( det kræver 4 KABLER sony!...) og høre min Pink Floyd DSOTM i 4.0. Det bliver dog først i næste mdr., da jeg mangler et sæt kabler...
    Vil også have fat i Deep Purples Machine head som oprindeligt er indspillet i Quadrofoni.
    micma18
    HM Elektronik
    Bruger siden: 29 Januar 2004
    Sendt: 15 April 2007 kl. 20:05 | IP-adresse registreret
    Hvordan forholder den gode gamle dolby surround og pro-logic sig til dette? Er det ikke nogenlunde det samme de gør?
    kanvas
    Bruger siden: 03 Juni 2005
    Sendt: 15 April 2007 kl. 20:19 | IP-adresse registreret
    Der var faktisk 3 Quadrofoniformater . CD-4 hvor de to bageste kanaler var indspillet i et højfrekvent område og derfor skulle afspilles med en specielslebet nål. I en CD-4 decoder blev signalet konverteret til to bagkanaler.
     De to andre formater var Sonys SQ samt Sansuis QS og de byggede på faseforskydninger på nøjagtigt samme måde som senere anvent i Dolby prologic, dog uden centerkanal. Jeg har stadig et par plader indspillet i SQ og de kan faktisk afspilles via en prologic decoder med et nogenlunde resultat.
    Til top Vis kanvas's Profil Søg efter andre indlæg skrevet af kanvas
    r-l-b
    Sendt: 15 April 2007 kl. 20:25 | IP-adresse registreret
    hvad var forskellen på SG/QS og det som nogel europæiske producenter tilbød som ambiofoni?
    kanvas
    Sendt: 15 April 2007 kl. 20:35 | IP-adresse registreret
     Såvidt jeg husker var ambifoni en boks man satte ind og ud fra tilfældige faseforskydninger på materialet kunne skabe en rumfornemmelse. I SQ/ QS  var faseforskydningerne "styret" af producenten. Jeg har en gammel SQ indspilning hvor man tydelig høre nogle musikere komme ind bagfra til venstre og bevæge sig op foran i midten (uden centerhøjtaler) Når dette afspilles som ambifoni kommer lyden bare fra alle 4 højttalere.
    Hans J
    Bruger siden: 25 Maj 2005
    Sendt: 29 Juli 2007 kl. 00:26 | IP-adresse registreret
    Jeg er faldet over en Quadrofoni LP i SQ.
    Billede er fra nettet.
    Er sådan en noget værd ? (gerne en milliardmillion )
    Er der interesse for sådanne plader ?
    Fanatisme er den største trussel mod mennesket.
    HD-DVD: Fordi livet er for kort til regionskoder
    PS3 fordi Bluray 24fps og HD-lyd er nice
    Til top Vis Hans J's Profil Søg efter andre indlæg skrevet af Hans J
    Nilau
    Sendt: 29 Juli 2007 kl. 01:44 | IP-adresse registreret
    Hmm...det er vist ikke lige Q-Sound, som "pqrannes" tænker på i denne sammenhæng...!
    Niels
    RogueAgent
    Sendt: 29 Juli 2007 kl. 15:29 | IP-adresse registreret
    Fair nok - jeg har bare i andre sammenhænge set Q-sound forkortet som qs i flæng med Quadrophonic stereo som om det var indbyrdes kompatibelt, så gik ud fra det var det der mentes.
    Hvis det ikke er q-sound  eller quadrafphonic stereo der hentydes til, hvad er det så..?
    bjørn
    Sendt: 29 Juli 2007 kl. 20:51 | IP-adresse registreret
    http://www.qsound.com/corporate/overview.htm
    SQ 4kanal og QS 4 kanal systerne (CBS / Sansui) er gamle slut 60'erne /70'erne systemer til afspilning via LP plader men der var flere, bl.a. Denon og så selvfølgelig diskerte 4 kanal systemer (bånd)
    emilblicher
    Bruger siden: 14 Juli 2008
    Sendt: 15 December 2008 kl. 18:48 | IP-adresse registreret
    Lige et lille sidespørgsmål. Hvad er det for en mikrofon eller sådan noget, der sidder omme bagved? Jeg har nemlig også engang set det på en NAD forstærker, men der stod ikke noget om det.
    Til top Vis emilblicher's Profil Søg efter andre indlæg skrevet af emilblicher
    Jehg
    Bruger siden: 31 Oktober 2003
    Sendt: 15 December 2008 kl. 19:06 | IP-adresse registreret
    Den lille dims er en AM antenne.
    Jehg
    Til top Vis Jehg's Profil Søg efter andre indlæg skrevet af Jehg
