Tilbage til HIFI4ALL.DK 28. juni 2026 | 22:50
Emne Emne: Kan Isfkalibrering betale sig? (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
Red Devils
Bruger siden: 05 September 2006
Sendt: 13 September 2006 kl. 07:53 | IP-adresse registreret
Kan man ikke bare bruge dette http://www.plasmatvbuyingguide.com/plasmatvreviews/pioneer-p dp4270hd-plasma-review.html
I stedet for at bruge 2000/2500 kr på at få en mand til det?
Til top Vis Red Devils's Profil Søg efter andre indlæg skrevet af Red Devils
Harritz3257
Tidl. gichael3257
Bruger siden: 11 Juni 2003
Sendt: 13 September 2006 kl. 08:09 | IP-adresse registreret
Jeg forstår ikke helt dit link. Du linker til en masser reviews?
Red Devils
Sendt: 13 September 2006 kl. 08:20 | IP-adresse registreret
Har sakset lidt derfra:
The following table contains the picture settings for the PDP-4270HD after its ISF calibration. We highly suggest that, if you own or purchase a Pioneer PDP-4270HD, you imitate these picture settings and save yourself several hundred dollars by doing so (rather than having a calibration specialist set it the same way). By configuring the television to the settings found below, we were able to maintain the color temperature in between D6400K and D6600K depending on the picture's brightness—a virtually flawless calibration. Using the below settings to regulate the color temperature and white balance virtually perfects the picture of the PDP-4270HD:
Pioneer PDP-4270HD Optimal Picture Settings
AV Selection User
Contrast 32
Brightness +3
Color +5
Tint -2
Sharpness -4
PureCinema Off
Color Temperature Low
CTI Off
DNR Low
MPEG NR Low
Figure 1. Optimal picture settings for the Pioneer PDP-4270HD using ISF Calibration.
To move any closer to D6500K would require modifying the television's service menus—a method which could potentially destroy the television. This would be essentially pointless because of the accuracy of the calibration.
The higher Color Temperature settings make the picture's white balance too bluish. Because our tester PDP-4270HD was calibrated with ISF-certified equipment, using Pioneer's proprietary picture improvements, such as PureCinema, is not necessary. According to our research, other measures such as Digital Noise Reduction (DNR) actually seem to degrade the picture of these upper-tier plasma televisions.
Wow, we thought that the picture on the PDP-4270HD looked good after our initial adjustments, but the picture is truly amazing after the ISF-calibration. Using our reference Toshiba HD-XA1 HD-DVD player, we watched the Scarface DVD upconverted to 1080i. As Tony Montana (played by Al Pacino) brutally takes over as Miami's drug kingpin, the PDP-4270HD uses its Advanced Pure Cinema 3:3 pulldown technology to flawlessly display the dazzling scenes of early 1980's Miami Beach. Dark matter detailing in the night scenes of the movie is superb—one can easily see the details in the outfits of each character.
DenUkendteFisk
Bruger siden: 01 Marts 2006
Sendt: 13 September 2006 kl. 08:39 | IP-adresse registreret
Jeg vil da klart sige du skal prøve de settings af og så se hvor tilfreds du er.
Er ikke helt inde i ISF-kalibrering, men er det ikke noget med at dit tv bliver indstillet efter dine omgivelser ? Altså hvor lys/mørk din stue er ?
Don't ever argue with an idiot, he will bring you down to his level and beat you with experience
Til top Vis DenUkendteFisk's Profil Søg efter andre indlæg skrevet af DenUkendteFisk
Harritz3257
Tidl. gichael3257
Sendt: 13 September 2006 kl. 10:37 | IP-adresse registreret
Problemet er at ISF-kalibreringen går ud på at customize vær enkelte fladskærm. Hvilket vil sige at ikke alle skærme er ens.
Det er lidt ligesom når f.eks Intel laver processorer. De laver en stor omgang, og tager de prøver og ud fra det kan de bestemme hvad alle sammen skal yde i hastighed. Det kan godt være nogen kan kører 20% hurtigere, men det tager for langtid at teste og priserne vil blive alt for høje.
Lidt det samme med fladskærme. Alle er instillet til det samme, men vær enkelt skærm er anderledes.
Pioneer
Produktchef
Bruger siden: 10 Oktober 2003
Sendt: 13 September 2006 kl. 11:33 | IP-adresse registreret
Hej Red Devils
En ISF kalibrering justerer farvebalancen på dit tv til at være perfekt. Men faktisk er det ikke så meget tvets afvigelser der tages højde for, men i langt højere grad de udefra kommende ting. Selvom det er tvets kontroller man rent fysisk justerer , så er det rummets og det øvrige udstyrs fejl man korrigerer for. Her er nogen af de ting der kan påvirke:
- Lysindfald i stuen - der er en separat dag og nat indstiling. Hvis TVet flyttes over til en anden væg bør det kalibreres igen. Faktisk spiller væggens farve også ind, da det manipulerer med vores opfattelse af farven på et givet objekt på skærmen.
- Det aktuelle panels variationer - som Gichael3257 siger: Der kan være små forskelle på hvert enkelt panel, men det er ikke meget.
- Den benyttede forbindelseskabels påvirkning - hvis dit componentkabel f.eks. er med 50ohms impedans istedet for 75 ohm kan du få forkert signalniveau, hvilket giver forkert farvebalance.
- Den benyttede kildes variationer - f.eks. er en 5% afvigelse i komponenterne i bufferkredsløbet for rød og grøn, så den ene er 10% kraftigere, ikke unormalt. Med HDMI går det bedre, men der er stadig forskelle. Der bør kalibreres separat for hver kilde - DVD, VHS, sat modtager etc.
Som du kan se så er der så mange faktorer, at man ikke kan bruge et andets tvs farveindstillinger til noget som helst. En ting er forskelligheden i de rum de står i, men selv to DVD-afspillere af samme model kan afgive forskelligt billede pga. komponent tolerancer.
Man kan selvfølgelig godt selv komme noget af vejen med diverse test-discs, men vores øjne 'tilgiver' ligeså nemt som vores ører, så vores hjerne rent faktisk tilpasser sig til den aktuelle gengivelse.
Så derfor er man nødt til at benytte ISF kalibreret måleudstyr, hvis man vil være sikker på korrekt farvebalance. Og en ISF uddannet tekniker kan helt sikkert kalibrere til korrekt farvebalance bedre og hurtigere end en selv.
N.B: Du refererer i indlægget ovenfor til den amerikanske udgave af PDP-427XD tilpasset til det amerikanske marked. Den model der i Europa har navnet PDP-4270XA/XD er ikke magen til, og har ikke ISF mode. I 7.generation er det modellerne PDP-427XD/XA og PDP-507XD/XA der har ISF mode. Bare lige for at rydde den misforståelse af vejen inden man køber.
Med venlig hilsen
Henrik Skinbjerg
Pioneer Danmark
Til top Vis Pioneer's Profil Søg efter andre indlæg skrevet af Pioneer Besøg Pioneer's Websted
