Tilbage til HIFI4ALL.DK 10. juli 2026 | 06:53
Emne Emne: Bi-amping with Thule, help for Belgium 2 (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
bramdo
Bruger siden: 22 Juli 2006
Sendt: 31 August 2006 kl. 11:43 | IP-adresse registreret
Dear all,
Once again a question from Belgium because I'm so alone with my Thule upgrade-itis
I have a thule IA 150B and would like to add a PA 150 B because there is a recent pricedrop and I can have it for less than 800 euros. My main speakers are the kef reference two floorstanders which are biwirable-bi-ampable
Are there people who are using this combination?
Would you recommend this upgrade?
thanks
Bram
Til top Vis bramdo's Profil Søg efter andre indlæg skrevet af bramdo
Sveske
Bruger siden: 22 Januar 2006
Sendt: 31 August 2006 kl. 12:38 | IP-adresse registreret
Can't you borrow it for at few days and then have a listen in your own house? I know many peo0ple do that here in Denmark
Guide til billedupload
bramdo
Sendt: 31 August 2006 kl. 12:59 | IP-adresse registreret
Well, that's part of the problem. Since Thule isn't the most popular brand in Belgium it's hard to get their more specialised electronics in demo.
regards
Bram
Svend P
Bruger siden: 15 Oktober 2003
Sendt: 31 August 2006 kl. 13:36 | IP-adresse registreret
Unless you want to play really loud, I wouldn't recommend the upgrade. I tried biamping a pair of Dali 850 with 1200 W pr. speaker, but didn't find much improvement sonically.
If you have problems with distorition from the amplifier due to to much load, of course it will help. But one amplier doesn't sound better than two automatically. They just have more power combined. Usually though, you don't need that much power.
I've tried to compare a 25 W amplifier with a 250 W. If you don't overload either, it's almost impossible to tell which is which.
