Tilbage til HIFI4ALL.DK 27. juni 2026 | 18:08
Emne Emne: High End Racks (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
micjac
Sendt: 20 August 2005 kl. 18:48 | IP-adresse registreret
Er der nogen der har prøvet nogle af de dyre racks?
F.eks er dette rack blevet reference mange steder.
Pris ca. 30.000 kroner.
http://www.finite-elemente.de
Pagode Master Reference - The features
The pagode hi-fi rack system harmoniously combines unadulterated music reproduction and functionality. The ever-present problem of sound-influencing resonances has been solved without compromise using specially selected materials, efficient design and measuring engineering investigations.
Lightweight construction in conjunction with non-magnetic materials such as aluminium and solid Canadian maple wood form the basis of a modular system that results in a model range offering the widest range of combination possibilities.
Three model variants, available in four heights and four widths, provide the perfect hi-fi rack for just about every conceivable application.
Spike, absorber and resonator technologies ensure a neutral resonance environment, where the audio components can demonstrate their sound capabilities without any restriction.
The pagode° HD Master Reference displays its know-how in the design of
high-quality hi-fi rack systems.
The attractive optics and the excellent
finish represent only the
external qualities.
innovative resonator technology for effective resonance
attenuation
outstanding sound properties
excellent finish
high design quality
available in 60 cm height with 2 or 3 levels or 85 cm height
with 4 or 5 levels
Finishes: Canadian maple wood, natural or with black pearl
structure, side uprights in anodized aluminium or with
high-gloss polished finish.
The optional extra-wide design allows audio components to be placed next to each other which is a method suitable for living rooms, but without detracting from their actual purpose, namely the natural reproduction of music at the highest level.
Individual shelves provide best decoupling of the audio components placed hereon. Each shelf is adjustable in height and level.
Pagode Master Reference - The Resonator Technology
The new "pagode° Master Reference" is a further successful step in the well-established tradition of finite elemente in its efforts to achieve absolute sound quality. For the first time a hi-fi rack designer is using scientifically based arguments in its fight against sound-distorting resonances.
What is a "Resonator"?
A "Resonator" is a miniature component where its own natural frequency is designed for the excitation frequency or system natural frequency. By integrating or adapting a "resonator" vibration amplitudes caused by the walls in technical systems, which can be excited by air-borne or solid-borne noise, can be clearly reduced. A great deal of the kinetic energy - with self-excitation up to 90%, with constrained excitation up to 70% - is converted silently into heat by the "Resonator" due to its relatively small sound radiation surface.
Six resonator types (220 Hz, 486 Hz, 512 Hz, 550 Hz, 670 Hz and 882 Hz.)are distributed in two possible variations across the whole rack. Each wooden frame is fitted with four resonators to ensure a linearised natural resonance behaviour. The coupling of the shelves is effected using height-adjustable cone-shaped
Til top Vis micjac's Profil Søg efter andre indlæg skrevet af micjac
Mumrik
Bruger siden: 27 December 2003
Sendt: 22 August 2005 kl. 13:30 | IP-adresse registreret
Galskab...
Til top Vis Mumrik's Profil Søg efter andre indlæg skrevet af Mumrik
janils
Pladespilleren.dk
Bruger siden: 02 Januar 2004
Sendt: 22 August 2005 kl. 14:08 | IP-adresse registreret
Der findes glimrende (og billigere) skandinaviske alternativer fra Audio Magic og Solid Tech.
Fra sidstnævnte har jeg set langt mere imponerende kuver for dæmpning af resonanser.
Jan Nielsen
jdg1
Bruger siden: 18 Juli 2003
Sendt: 22 August 2005 kl. 14:14 | IP-adresse registreret
Jeg læste en gang en anmeldelse af et meget dyrt rack i "What Hifi". Anmelderen skrev, at rack'et var godt, at det også gav "bedre og renere" farver på hans tv
Det er vidst kun HF's anmeldelser af Nordost kabler, der kan matche dette niveau
vilmann
Nerds
Bruger siden: 01 April 2003
Sendt: 22 August 2005 kl. 17:25 | IP-adresse registreret
30K... Det nærmer sig galskab, ikk?
Så længe du holder dig fra glas, kan du fomodentlig komme en hel del af vejen for langt færre penge.
/vilmann
Rizzo
Bruger siden: 31 Marts 2004
Sendt: 22 August 2005 kl. 17:45 | IP-adresse registreret
Som nogle af de andre har været inde på, vil jeg også argumentere imod dette rack... Totalt uvidende som jeg er, og bondejyde tilmed, vil jeg simpelthen aldrig (!!) blive i stand til at relatere mig med folk, der bruger 30k på et rack. - Skulle produktet være designet af en stor og berømt designer og være genopfindelsen af den dybe tallerken, ville det muligvis være en anden sag...
AV M3 Avantgarde
Densen B-100 mKv + B-400 Black
Samsung LE32M51
Pioneer DV668AVi
Vil mægtig gerne ha B300XS
Mit anlæg?
Til top Vis Rizzo's Profil Søg efter andre indlæg skrevet af Rizzo
Bass
Bruger siden: 26 Oktober 2004
Sendt: 23 August 2005 kl. 16:06 | IP-adresse registreret
Jeg bemærker at der ret meget træ i konstruktionen, hvilket ikke er særlig heldigt mht resonanser osv.
En kombination af masse og absorberende materiale (hvad pengepungen tillader) samt skærm mellem de enkelte hylder må være at foretrække. Med 30k som udgangspunkt kan du nok få en designer og en møbelsnedker til at lave noget fornuftigt.Big smile
Det gør en forskel hvilket underlag CD`en eller pl.spilleren står på. Egenlyden fra CD drevet begrænses og lyden bliver klarere. Pladespilleren er langt mere hysterisk.......
Til top Vis Bass's Profil Søg efter andre indlæg skrevet af Bass
micjac
Sendt: 23 August 2005 kl. 19:14 | IP-adresse registreret
/vilmann
Jo, det er mange penge. Det er ikke engang særligt pænt
efter min smag.
De har skam også billigere ting på programmet
Som denne pladespiller hylde.
"the manufacturer Finite Elemente put all his knowledge into this superb piece of
wood what defeats resonances intrusing through floor and air: resonators, spiked
high-absorption shelf, 3-point ceramic ball coupling and ball thrust bearing
adjustment. The attachment to the wall is realized by two 10 mm (!) Allen screws
that fit into metal sleeves anchored inside the wall by means of an injection
mortar. This professional fixing system is supplied by the German company
Fischer and holds easily more than the suggested 120 pounds load capacity."
Pris ca. 15.000  (ikke en joke)
micjac
Sendt: 23 August 2005 kl. 19:28 | IP-adresse registreret
Mærket kan endda købes i danmark.
Fandt lige de danske priser her:
http://www.radioactiv.dk/priser/Finite.pdf
blackhawk
Sendt: 23 August 2005 kl. 19:33 | IP-adresse registreret
På den anden side, folk betaler gladeligt 50.000,- i ledninger.. UPS..
Kabler..
Med venlig hilsen
Aslak C. Vind
full blown
Bruger siden: 05 Oktober 2003
Sendt: 23 August 2005 kl. 19:59 | IP-adresse registreret
Er der nogen i flokken der har erfaringer med solid tech´s rack?.
Til top Vis full blown's Profil Søg efter andre indlæg skrevet af full blown
blackhawk
Sendt: 23 August 2005 kl. 20:11 | IP-adresse registreret
Søg og du skal finde, en fin nordmand ved ting om Solid Tech:
http://www.hifi4all.dk/forum/forum_posts.asp?TID=25687&K W=blackhawk
Med venlig hilsen
Aslak C. Vind
micjac
Sendt: 23 August 2005 kl. 20:12 | IP-adresse registreret
Billeder (også nærbilleder) fra en gut oppe nordpå:
http://www.euphonia-audioforum.se/forums/index.php?showtopic =1357
Hvad er det med de kabel-løftere ......
full blown
Sendt: 23 August 2005 kl. 20:26 | IP-adresse registreret
UOTE=blackhawk]
[/QUOTE]
Jamen der var det jo...,uha det er for blæret!. Det kunne jeg godt affinde mig med,hvis det ik kan være anderledes
blackhawk
Sendt: 23 August 2005 kl. 20:30 | IP-adresse registreret
Sig det til ham thomand3, så bliver han glad!
Brug linket
Med venlig hilsen
Aslak C. Vind
micjac
Sendt: 23 August 2005 kl. 20:51 | IP-adresse registreret
Ja, hvis man er til spider stilen er det Rack of Silence da flot.
Super finish. Flot rum også.
Når man går tæt på de dyrere racks er der en del forfinede
tekniske løsninger som til dels må kunne retfærdiggøre prisen.
Og det løber jo op. Jeg prøvede engang at lave sådan et flexeye
rack og det løb op mod 1.000 kr. bare i materialer og uden
finish. Finish koster kassen. Men ok der er da et stykke vej.
Btw, det rack blev en katastrofe. Men det skyldtes mine diy-evner.
Er der egentlig ikke nogle high-end racks der ligner flotte
træ-stuemøbler? Altså noget der ikke ligner en slagter-huggeblok,
reol fra lagerhal, kubiks terning, pult fra Star Trek, eller en
udstillingsmontre med skilte.
micjac
Sendt: 23 August 2005 kl. 21:05 | IP-adresse registreret
Der er også dem her.
Østrigske Hutter. Det er et gammelt møbelfirma der har slået sig på
hifi-møbler da han selv er hifi-freak.
Det ser egentlig ikke så tosset ud. Men det er ikke billigt.
Lidt slebne kanter ville nu have været pænt.
Her er en kanon præsentationsside. Bedre end firmaets egne.
http://www.soundscapehifi.com/hutter.htm
3DX
Lukket efter ønske fra bruger
Sendt: 24 August 2005 kl. 13:37 | IP-adresse registreret
/vilmann
hvad er der galt med glas ?
Henrik300
Bruger siden: 22 Februar 2004
Sendt: 01 Januar 2006 kl. 21:55 | IP-adresse registreret
Hejsa
Jeg er den lykkelige ejer af et af de "dyre" rack. Pris ca. 1.650 Pund, altså ca. 20K. Det er købt brugt til en fin pris. Det har i lang tid været mit uopnågeligt rack, men pludselig så var det der på brugtsiden, og så var det med at slå til med det samme.
Kik evt her: http://www.hifichoice.co.uk/archive/perl/29_printreview.htm for at læse mere om racket.
Hilsen Henrik
Sven Palvig
Bruger siden: 13 April 2003
Sendt: 01 Januar 2006 kl. 22:48 | IP-adresse registreret
Træ er er det bedste materiale til at bære stereon. Jeg har lige bygget mig et system hvor jeg har brugt en køkkensplade fra Silvan. Stavlimet bøgetræ som tit er på tilbud. 850 kr. måtte jeg slippe for 3 meter x 60 cm. inkl. tilskæringer. Stavlimet bøg dæmper vibratiomer hver gang der er limet.
Lyden af hylderne gav et markant løft på lyden med nøgleord som renere og mere åbent.
Om det skyldes at det giver færre refleksioner end det Impeire trebenet rack der stod i midten før, ligesom når fjernsynet fjernes; eller det skyldes at der ikke mere er jern i racket, hvilket ikke er særlig smart i forbindelse med hi-fi, ved jeg ikke. Men det er heller ikke så vigtigt. Det vigtigste er at det bare lyder bedre.
Mvh. Sven Palvig
Mvh. Sven
