Tilbage til HIFI4ALL.DK 15. juli 2026 | 03:55
Emne Emne: Nogen der har erfaring med disse Pioneer (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
MeLVIS
Bruger siden: 19 Juni 2005
Sendt: 18 Juli 2005 kl. 18:00 | IP-adresse registreret
http://www.pioneer.no/no/product_detail.jsp?product_id=9648& amp;taxonomy_id=428-442
A/V Høyttalersett
With a wide frequency range — up to 100 kHz for the front speakers and 50 kHz for centre and rear speakers — this magnetically shielded speaker set is an ideal partner for creating brilliant DVD-Audio and SACD sound.
Thanks to the 130 W front floorstanding 4-way speakers' deep, rich bass reproduction, you get a versatile audio performance, well suited for a home cinema, as well as a stereo environment. Finished in real beech veneer, they harmonise with any interior.
The S-V810A set consists of the S-H810V front floor-standing speakers, S-C80 centre speaker, S-F80 rear speakers and the powerful 250 W active subwoofer S-W250S . This subwoofer has an exeptional acoustic design, with a D-class amplifier separated from the acoustic cabinet.
< ="product_detail.jsp" method="post">
Key features S-V810A
Attractively finished in real beech veneer
Brilliant DVD-Audio and SACD reproduction
Deep bass sound reproduction
Magnetically shielded
General S-V810A
Centre speakers style Bookshelf or floor-standing
Front Speakers style Floor-standing
Rear speakers style Bookshelf
Maximum power 130 Watt
Maximum power Subwoofer (RMS) 250 Watt
Magnetically shielded for video use Ja
Speaker woofer size Front: 13 cm cone woofer (x2)
coaxial units; 13 cm cone medium
Speaker tweeter size 2.5 cm dome tweeter, super tweeter: Riffel type
Rear speaker cone woofer size 13,0 cm
Rear speaker dome tweeter size 2,5 cm
Centre satellite cone woofer size 13 cm cone woofer (x2)
coaxial units: cone medium 13 cm
Centre satellite dome tweeter size 2,5 cm
Subwoofer module S-V810A
Subwoofer module 30 cm cone woofer
Subwoofer Enclosure Rear passive radiator
Built-in Amplifier Ja
Stereo (Screw Terminal) Ja
Mono (Pin Jack) Ja
Speaker level Input Sensitivity/Impedance (100 Hz) 1.6 V + 1.6 V / 15 kOhm
Line level (RCA Jack) Input Sensitivity/Impedance (100 Hz) 160 mV / 50 kOhm
Power Consumption 56 Watt
Power Requirements AC 220 - 230 V, 50/60 Hz
Specifications S-V810A
Speaker frequency Range 35 - 100 000 Hz
Rear speaker frequency Range 50 - 50 000 Hz
Centre speaker frequency Range 45 - 50 000 Hz
Subwoofer frequency range 23 - 1000 Hz
Sensitivity (1 W / 1 m) 89 dB (front, centre) / 88 dB (rear)
Impedance 6 Ohm
Speaker dimensions (WxHxD) 250 x 1190 x 300 mm
Rear speaker dimensions (WxHxD) 190 x 350 x 290 mm
Centre speaker dimensions (WxHxD) with base: 560x 215 x 300 mm
without base: 560 x 190 x 300 mm
Subwoofer dimensions (WxHxD) 430 x 480 x 430 mm
Speaker weight 25,00 kg
Rear speaker weight 7,30 kg
Centre speaker weight 15,60 kg
Subwoofer weight 34,50 kg
Til top Vis MeLVIS's Profil Søg efter andre indlæg skrevet af MeLVIS
MeLVIS
Sendt: 18 Juli 2005 kl. 22:30 | IP-adresse registreret
er der virkelig ik nogen der ved om det er hit eller skidt det der sæt ??
finn52
Bruger siden: 29 April 2004
Sendt: 19 Juli 2005 kl. 10:12 | IP-adresse registreret
Jeg har læst tests i både HighFidelity og HiFi og Musik af hovedhøjttalerne (de høje søjler). Begge steder er de imponerede over hvor meget vellyd man får for pengene.
Jeg har desværre ikke selv hørt dem.
MeLVIS
Sendt: 19 Juli 2005 kl. 17:59 | IP-adresse registreret
nogen der har link til tests af dem ???
