Tilbage til HIFI4ALL.DK 23. juni 2026 | 23:59
Emne Emne: Antique Sound Lab ? (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
Jamez
Bruger siden: 12 Juni 2003
Sendt: 03 Juni 2005 kl. 12:25 | IP-adresse registreret
Nogen der ved hvor man købe ovennævnte enten i DK, norden eller EU ??
Er primært interreseret i AQ1006 (845) DT MONO BLOCK POWER AMPLIFIER ...
1 x 22 watts
Single-Ended Triode 845 Output Tube
6L6, 3 x 6SN7 all Triode Frontend
(0 NFB)
Point-to-Point Wiring
Tube Regulated
Choke Filtered Power Supply
TECHNICAL SPECIFICATIONS
Output Power
Frequency responsible at 1 W
Frequency responsible at full power
Distortion at 1W
Distortion at full power
S/N Ratio / Noise level mV
S/N Ratio with A weighting
Input impedance
Output Impedance
Input sensitive
Power request
Fuse
Power cord - Detachable /Fixed
Input Sockets
Output terminal
Chassis Finish
Front Panel Finish
Tube Complement
Dimension W x D x H in inches
Shipping Dimension W x D x H in mm
Net Weight
22W
12Hz - 21KHz
25Hz - 18KHz
< 0.2%
< 3%
81 db /1.2mV
89 db (0.5mV)
100K
4,8,16 ohm
850mV
210W
5A Slow blow
Detachable
RCA Gold Plate
Heavy duty gold plate 5 ways speaker post
Polished Steel
Aluminum /Gold /Silver or Black Anodizing
845 x 1,6L6 x 1,6SN7 x 3
12x17 x 10
350 x 470 x 333
19Kg
Tak
Til top Vis Jamez's Profil Søg efter andre indlæg skrevet af Jamez
