Tilbage til HIFI4ALL.DK 12. juni 2026 | 05:05
Emne Emne: B&W DS6 S3 og DS7 (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
D.B.M.
Bruger siden: 03 Maj 2003
Sendt: 06 September 2003 kl. 20:27 | IP-adresse registreret
Nogen der ved hvornår de to modeller kommer på det danske marked og til hvilken pris?
Her er lidt info fra B&W's egen hjemme side.
Technical Specifications : DS6 S3
Description 2-way closed-box selectable dipole/monopole surround system
Dimensions Height: 249mm (9.8 in)
Width: 380mm (15 in)
Depth: 153mm (6 in)
Net Weight 5.2kg (11.5 lb)
Freq. Response 85Hz – 22kHz ±3dB on reference axis (monopole mode)
85Hz – 10kHz ±3dB power averaged over front hemisphere (dipole mode)
Freq. Range -6dB at 63Hz and 42kHz (monopole mode)
-6dB at 63Hz and 15kHz (dipole mode)
Sensitivity 89dB spl (2.83V, 1m)
Nominal Impedance 8Ω (minimum 3.3Ω)
Power Handling 25W – 100W into 8Ω on unclipped programme
Drive Units Unit 1: ø130mm (5 in) woven Kevlar® cone bass / midrange
Unit 2: 2x ø80mm (3 in) midrange / high frequency
Unit 3: ø25mm (1 in) alloy dome high-frequency
Finish Cabinet: Black or white
Grille: Black or white cloth
Dispersion Description: Dipole mode: horizontal figure of eight
Effective null zone ±20º (250Hz – 15kHz)
Monopole mode: within 2dB of reference response
Horizontal: over 40º arc
Vertical: over 10º arc
Harmonic Distortion 2nd and 3rd harmonics (90dB, 1m)
<1% 130Hz – 20kHz
Crossover Frequency 250Hz (dipole mode)
4kHz (monopole mode)
Cable Impedance 0.1Ω
Technical Specifications : DS7
Dimensions Height: 302mm (11.9 in)
Width: 383mm (15.1 in)
Depth: 200mm (7.9 in)
Net Weight 8.5kg (19 lb)
Freq. Response 80Hz – 22kHz ±3dB on reference axis (monopole mode)
80Hz – 10kHz ±3dB power averaged over front hemisphere (dipole mode)
Freq. Range -6dB at 60Hz and 42kHz (monopole mode)
-6dB at 60Hz and 15kHz (dipole mode)
Nominal Impedance 8Ω (minimum 3.0Ω)
Power Handling 25W – 120W into 8Ω on unclipped programme
Drive Units Unit 1: ø165mm (6.5 in) woven Kevlar® cone bass/midrange
Unit 2: 2x ø100mm (4 in) midrange/high frequency
Finish Cabinet: Black or white paint
Effective null zone ±30º (250Hz – 15kHz)
<1%110Hz – 20kHz
Til top Vis D.B.M.'s Profil Søg efter andre indlæg skrevet af D.B.M.
D.B.M.
Sendt: 10 September 2003 kl. 12:43 | IP-adresse registreret
Er der slet ikke nogen der ved noget om de to modeller eller har nogen kommentarer til mit indlæg?
Finn29
Sendt: 10 September 2003 kl. 12:54 | IP-adresse registreret
DS7 står til 4995,- i hfk's prisliste   så den burde kunne bestilles nu
Hilsen Finn / Finn29
tonka
Hi-Fi Klubben
Bruger siden: 05 Maj 2003
Sendt: 10 September 2003 kl. 13:16 | IP-adresse registreret
De to modeller er endnu ikke klar til levering fra B&W og forventes at være at finde  Hi-Fi Klubben i løbet af Oktober måned.
hilsen Tonka
Til top Vis tonka's Profil Søg efter andre indlæg skrevet af tonka
H_DK
Bruger siden: 30 September 2003
Sendt: 14 November 2003 kl. 01:49 | IP-adresse registreret
Er der nogen der har hørt mere om disse højtalere??
jeg skal snart have købt noget, og vil gerne have DS6 S3, men kan ikke finde noget om det andet end det på B&W's egen side
Til top Vis H_DK's Profil Søg efter andre indlæg skrevet af H_DK
Finn29
Sendt: 14 November 2003 kl. 04:08 | IP-adresse registreret
Tlf: 70104434
Fax: 87432140
online@hifiklubben.dk
Prøv at ringe/skrive til hifiklubben, de må kunne give nærmere besked
H_DK
Sendt: 15 November 2003 kl. 00:40 | IP-adresse registreret
De er lige kommet på lager til en stk. pris på 2499kr.
Så dem også lige i HIFI-klubben i Slagelse, men de var desværre ikke sat op endnu da de lige havde fået dem
Mlarsen
Bruger siden: 12 September 2003
Sendt: 20 September 2005 kl. 18:53 | IP-adresse registreret
Jeg går og overvejer at købe et sæt af en af disse to baghøjtalere.
Er der nogen som har erfaringer med dem og om man får noget ud af at købe DS7'eren i fht. DS6 S3'eren?
Med venlig hilsen
Michael Larsen
Min hjemmebio: http://www.hifi4all.dk/forum/forum_posts.asp?TID=18095&KW=ml arsen
Til top Vis Mlarsen's Profil Søg efter andre indlæg skrevet af Mlarsen
Lestat
Bruger siden: 01 Januar 2004
Sendt: 21 September 2005 kl. 08:25 | IP-adresse registreret
Hmm... Jeg var nede i HiFiKlubben for at prøve at høre dem, da jeg stærkt overvejer at købe DS6 S3, og sælgeren sagde at de ikke havde dem på lager da det var en bestillingsvare, og de solgte meget få af dem - han kunne faktisk ikke huske at have solgt et par. Ikke så mærkeligt hvis de først er kommet i deres sortiment nu...
Han ville se om nogle af de andre butikker havde et sæt de kunne få hjem så man kunne høre dem inden man købte dem - jeg er ikke helt vild med tanken om at købe et sæt højttalere jeg ikke har hørt spille.
L.
Til top Vis Lestat's Profil Søg efter andre indlæg skrevet af Lestat Besøg Lestat's Websted
Mlarsen
Sendt: 21 September 2005 kl. 08:47 | IP-adresse registreret
De er heller ikke lige kommet i sortiment nu, det er bare en lidt gammel tråd jeg lige har taget op, da den passede så godt ind i mine overvejelser.
Men ja man skal da lige have lov til at prøve dem først. Bare lidt mærkeligt at de ikke sælger mange af dem, folk må jo så bare bruge alm. højtalere som baghøjtalere??!
Med venlig hilsen
Michael Larsen
Lestat
Sendt: 21 September 2005 kl. 11:13 | IP-adresse registreret
W00ps, jeg havde ikke set det var en gammel tråd.
Men nej, jeg forstår heller ikke de ikke sælger flere. Efter sælgeren at dømme var det rimeligt anstændige højttalere, og de fylder mindre end at bruge stander højttalere bagtil, hvilket er en fordel i mange rum.
L.
