Tilbage til HIFI4ALL.DK 21. juni 2026 | 17:21
DVD, HD-DVD, Blu-ray
Emne Emne: HELIOS HVD2085 (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
Sten
Bruger siden: 19 April 2003
Sendt: 19 April 2006 kl. 09:48 | IP-adresse registreret
Hvad siger I til denne nye og spændende afspiller?
The HELIOS HVD2085 is currently the only player in the market with the capacity to upscale standard DVDs to as high as 1080p resolution through component output. The player also has the capacity to upscale to 1080p resolution via HDMI output, and 1280x1024 resolution via VGA output. To cater to NeoDigits’ growing European market, the player is now able to support 480i and 576i resolutions. With 11 different resolutions to choose from, you have an even greater chance of getting the right match with your high-definition television for dazzling images with smoother and more pronounced details. What more, the player is region-free out-of-the-box. This means that it can play all your DVDs regardless of which part of the world you bought them.
SRP: US$ 199.00
Læs mere her:
http://www.neodigits.com/new/body/products/HVD2085/overview. asp
http://www.hkflix.com/hardware/xq/asp/pid.112/qx/details.htm
Til top Vis Sten's Profil Søg efter andre indlæg skrevet af Sten
Boye
Bruger siden: 18 Juli 2003
Sendt: 19 April 2006 kl. 10:01 | IP-adresse registreret
Hep, der
Den lyder godt nok spændende - en mulig Oppo-killer.
Vi skal dog - som Otto, TC har forklaret - være opmærksomme på at de afspillere der fungerer godt i NTSC ikke altid kan overføre ders kvaliteter hvad angår de-interlacing og scaling til PAL-land.
Men den er da bestemt et kig værd.
Secrets of Home Theatre and Hifi giver dog ikke så meget for den (NeuNeo-versionen) i deres benchmark:
http://www.hometheaterhifi.com/cgi-bin/shootout.cgi?function =search&articles=125
Der klarer Oppo DV971H sig betydeligt bedre.
Sten
Sendt: 19 April 2006 kl. 12:27 | IP-adresse registreret
Okay, knap så god i funktion som den lyder på papiret... især i PAL-lande.
Håber der snart kommer en prisbillig afspiller med samme funktioner, der virkelig er en "killer" afspiller.
Lukman
Bruger siden: 10 Marts 2005
Sendt: 21 April 2006 kl. 12:10 | IP-adresse registreret
Den har desværre heller ikke 3:2 pull down detection hvilket resulterer i jaggies (sjovt så mange vendinger jeg lærer på nettet ) men om det så har nogen dårlig indflydelse på mit nyindkøbte Pana PV60 hænger vel sammen med om panelet kan ?? måske Otto ku`svare på det ?
Det er vist også den eneste anke, i flg hometheatermag.com som giver den en god anmeldelse
Til top Vis Lukman's Profil Søg efter andre indlæg skrevet af Lukman
Japer
Bruger siden: 25 Februar 2005
Sendt: 21 April 2006 kl. 12:17 | IP-adresse registreret
Lukman tror du ikke snart du skal ha sat nogle flere billeder op i din tråd
Lukman
Sendt: 21 April 2006 kl. 13:20 | IP-adresse registreret
Tjo, men det er jo såmænd det samme setup, men jeg kan selvfølgelig åbne lågerne så du kan se det beskedne PJ/Jamo Dvd-Reciever og den lille sub der på magisk vis har forvandlet konen`s skænk til en rigtig `Boom box`  er faktisk helt tilfreds med lyden og billed via Komponent @576p, eneste der mangler nu er en Oppo eller Helios der kan upscale
