Tilbage til HIFI4ALL.DK 19. juni 2026 | 16:44
Emne Emne: Ny forstærker (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
Svoldgaard
Bruger siden: 31 Oktober 2008
Sendt: 06 Juli 2013 kl. 08:31 | IP-adresse registreret
Hej forum
Jeg har en næsten ny Hegel H1 Mk4 som jeg gerne vil sælge men jeg ved ikke rigtig hvad den er værd??
den er købt d.18-1-2013 og alt er som nyt.
Den kostede 12995-vejledende udsalgspris. men det er jo også en model der er udgået.
Håber på lidt HJÆLP.
The H1 mk4 is based on technology from the H200 integrated amplifier. The H1 mk4 has got the new digitally controlled active preamp stage from the H200 and the new and improved Sound Engine amplifier technology from the H200 amplifier. The reduction of dynamic distortion all over the audible frequency range together with complete elimination of "transistor sound" makes the H1 mk4 sound smooth, warm and transparent without losing any details. The integrated amplifier H1 mk4 is the entry level amplifier among the Hegel products. It has now been upgraded with new technology from the H200 amplifier. The H1 has got the characteristic Hegel-curve in the front panel, and both input source and volume can be controlled from the Hegel remote control. The H1 mk4 has got a relay switched input source selector and can be connected to different types of music sources. The amplifier has got very high power output and will happily drive demanding loudspeaker loads. The H1 mk4 can deliver an output signal current in excess of 70 amperes. The amplifier is very dynamic and will drive the speakers with a deep powerful bass and a high resolution smooth midrange with a detailed soundstage. The H1 mk4 integrated amplifier is using the new and improved SoundEngine technology from the Hegel H200, H2A mk2 and H4A mk2 amplifiers. To be able to offer an unsurpassed audio performance at a very competitive price point the H1 mk4 is using the Hegel SoundEngine amplifier technology. The H1 mk4 has got connectors for both unbalanced and balanced signal cables. The speaker connectors are gold plated terminals of the highest quality available.
Morell
Tidl. Neon^
Bruger siden: 28 Februar 2005
Sendt: 06 Juli 2013 kl. 08:34 | IP-adresse registreret
Hey :)
Passer den ikke rigtigt ind i dit ellers fine setup?
Jeg vil da gætte på at den kan sælges for ca. 1/2 af nypris. Oprindelig køber må også have fået en klækkelig rabat siden da det er en udgået model,
så derfor mit gæt.
Svoldgaard
Sendt: 06 Juli 2013 kl. 09:33 | IP-adresse registreret
Morell skrev:
Hey :)
så derfor mit gæt.
Hej Morell jo den spiller fint sammen med Revel men jeg har lidt kik på en H200 måske H300
Var til Hegel demo hos Audiovision hvor jeg hørte H300 med de nye Revel performa 3 f208
Morell
Tidl. Neon^
Sendt: 06 Juli 2013 kl. 15:26 | IP-adresse registreret
Det lyder da rigtigt fedt! Er da bare sådanne et setup du skal have :D Hvaaa er han ved at have lavet ombygningen færdig?
Svoldgaard
Sendt: 06 Juli 2013 kl. 15:45 | IP-adresse registreret
Ja det er færdig Hvis altså du mener den nye facade.
Morell
Tidl. Neon^
Sendt: 06 Juli 2013 kl. 15:49 | IP-adresse registreret
Yes lige nøjagtigt, snakkede nemlig med ham ang. besøg fra klubben, at han lige skulle være færdig med det inden vi kom...
Så nu skal vi da en tur ud til ham! Kunne forfærdeligt godt tænke mig at høre den nye Avid spille.
