Tilbage til HIFI4ALL.DK 19. juni 2026 | 18:03
Emne Emne: TviXiE Hjælp (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
moose74
Bruger siden: 14 Februar 2010
Sendt: 26 Februar 2011 kl. 15:08 | IP-adresse registreret
Hi,
I guess I haven't been clear, I can use the default templates, but if I add more templates in the folder: C:\Program
Files\TViXiE\Templates\Movie\ these new templates are not visible in the tvixie program. I can open them in the template
editor, but I can't render them there. So the question is how can I get new templates to be visible in the tvixie
program(Interface enhancer)
Have the same F******G !!! problem CANT Add a new template, I F*****G Hate windows i can render and save them in the
template editor, but cant se them in the tvixie program(Interface enhancer)        &nb sp;         &nb sp;     got dammit.
C:\Program Files\TViXiE\Templates\Movie\ ???
where do i find that folder ?
the only one i have is under programs, there is a tvixie folder whit the program and the editor...
You put the templates into the TVIX folder.
EG: c:\program files\tvixie\templates\movies\
Then just load TVIXIE, select a folder to open, right click, movie information > get movie information
Select your template, select your providers where you want to get the info, it should then show the info, select the info and
click done.
It should then be rendered (make sure u tick the box "folder view" in TVIX main screen as well)
Kan bare ikke få lagt en ny template ind i tvix programmet ???
Til top Vis moose74's Profil Søg efter andre indlæg skrevet af moose74
