Tilbage til HIFI4ALL.DK 19. juni 2026 | 18:06
Vintage
 HIFI4ALL Forum : Vintage
Emne Emne: Technics SE-A7, Technics SU-A8 (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
MathiasFB
Tidl. BOWA HiFi
Bruger siden: 02 Januar 2008
Lokalitet: Fyn Syd
Sendt: 21 Februar 2008 kl. 16:56 | IP-adresse registreret
Da jeg overvejer at købe ovenstående, vil jeg meget gerne høre, om I kan hjælpe mig med at finde lidt data/fakta angående disse komponenter. Der er tale om følgende:
Technics SE-A7
Forstærker
http://www.audio-heritage.jp/TECHNICS/amp/se-a7.html
Technics SU-A8
Forforstærker
http://www.audio-heritage.jp/TECHNICS/amp/su-a8.html
en dertil matchende tuner.
Billedelink:
http://peecee.dk/uploads/022008/tech78_big_thumb.jpg
En vurdering af disse ville være meget fint.
Mvh Mathias B
Mvh Mathias Boesgaard
Til top Vis MathiasFB's Profil Søg efter andre indlæg skrevet af MathiasFB
r-l-b
Sendt: 21 Februar 2008 kl. 18:04 | IP-adresse registreret
Explanation
New class A system and the stereo of the 1U size which loads the linear feedback circuit/the mono DC power amplifier.
Theoretical value strain = 0, the linear feedback circuit which actualizes output impedance = 0 is loaded in addition to the synchronizer bias circuit which cancels the switching strain and the crossover strain.
With the switch change of the rear panel, monaural drive is possible.
As you change the tap of high power trance according to load impedance, same as 8 Ω time you make the calorific value decrease substantially even at the time of 4 Ω load as the rated output of 60W + 60W, radiator capacity is held down to former 70%.
Super thin-shaped trance 2 is used to trance. The trance 2 is arranged, in order to cancel electromagnetic radiation mutually, prevents external induction.
By the fact that the high efficiency radiator which uses the heat pipe is adopted, the heat where the output transistor occurs, in cross direction is made dispersed.
The FL display tube of 12 segmented logarithmic compression indications is adopted to power meter.
The meter range has become 2 gradual system for change-over of the ×1 and the ×0.01.
For the amplifier circuit protection the speaker terminal short for and the speaker protection for the abnormal operation of the amplifier, the pure electronic type protection network which uses relay is equipped.
Furthermore, we equip the thermal detection protection network, when internal temperature of the amplifier rose abnormally, we make gain knock down automatically, lead to stability operation.
Rating of type
Type Stereo/mono DC power amplifier
Effective output (20Hz - 20kHz) Stereo: 60W + 60W (8 Ω, 0.003%)
Mono: 120W (8 Ω, 0.007%)
Total height harmonic wave distortion factor
(20Hz - 20kHz, 8 Ω)
Stereo: At the time of 0.003% (rated output)
0.0015% (rated output -3dB time)
Mono: At the time of 0.007% (rated output)
TIM Measurement failure
Frequency characteristic 20Hz - 20kHz +0 -0.1dB
0.7Hz - 200kHz +0 -3dB
Signal-noise ratio (IHF-A) 115dB
Residual noise 0.2mV
Damping factor 100 (8 Ω)
Output meter indicating range 0.001W - 1C$w
0.1W - 100W
Input sensitivity/impedance 1C$v/47k Ω
Load impedance Main or remote (stereo): 4 Ω - 16 Ω
Main and remote (stereo): 8 Ω - 16 Ω
Main and remote (mono): 8 Ω - 16 Ω
Power source AC100V and 50Hz/60Hz
Electric power consumption 145W
External size Width 430× height 53× depth 365mm
Weight 9.5kg
Footprint of audio
The picture of SU-A8
Technics SU-A8
¥70,000 (1981 October sale)
Explanation
The stereo DC control amplifier of the 1U size which adopts all stage A class operations, all stage ICL constitution and the pre- setter bull electronic selector.
Low noise FET parallel you use the equalizer circuit, the differential motion you have become MC high gain basic design which combines the advanced operational amplifier to input of the cascade connection which is expanded.
Completely to DC we adopt the flat/tone amplifier which is converted even to the tone circuit, raise the fidelity of waveform transmission.
With all stage A class operations, the switching strain and the crossover strain are cancelled.
Furthermore, everything to ICL it converts the basic circuit, as for フォノ input one coupling condenser it is passed only, as for high gain input it forms the straight DC amplifier which does not have the fact that all condenser is passed.
The electronic selector is adopted to the input selector.
In addition, the selector of Phono and High-Level pre-sets that button by pushing in strongly, (MM ⇔ MC, tuner ⇔ aux) it has become 2 way pre- setter bull electronic selectors.
Sliding type volume and the touch fader which can fade in volume and can fade out - it is on-board.
The tape deck is 2 connections possible.
Rating of type
Type Stereo DC control amplifier
Input sensitivity/impedance Phono MC: 170 μ V/220 Ω
Phono MM: 2.5mV/47k Ω
Tuner, Aux and Tape: 150mV/22k Ω
(20Hz - 20kHz, VR-20dB and 2V output)
Tuner, Aux, Tape and Phono MM: 0.002%
Phono MC: 0.01%
Signal-noise ratio Tuner, Aux and Tape/ straight DC: 102dB
Phono MM: 88dB (2.5mV)
Phono MC: 73dB (250 μ V)
Frequency characteristic Phono MM: 20Hz - 20kHz and RIAA ±0.2dB
Phono MC: 20Hz - 20kHz and RIAA ±0.5dB
Tuner, Aux and Tape: DC - 20kHz +0 -0.2dB
DC - 100kHz +0 -3dB
Maximum permissible input (1kHz and RMS) Phono MM: 160mV
Phono MC: 11mV
Tone control Bass: ±10dB (50Hz)
Treble: ±10dB (20kHz)
Filter Subsonic: 20Hz, -12dB/oct
Loudness control (VR-30dB) +9dB (50Hz)
Output voltage/impedance Pre out: 1C$v/2 Ω (rating), 10V/2 Ω (maximum)
Rec out: 150mV
Electric power consumption 14W
Weight 4.5kg
data hermed oversat fra Japansk med AltaVista Babel Fish http://world.altavista.com/
noget af det bliver ret abstrakt når det bliver maskinoversat men data kan man da få ud af det - jeg har aldrig hverken set eller hørt sættet så det må vi overlade til andre
MathiasFB
Tidl. BOWA HiFi
Lokalitet: Fyn Syd
Sendt: 21 Februar 2008 kl. 18:07 | IP-adresse registreret
Tak for hjælpen til oversættelsen  Var en stor hjælp.
Ja vi overlader resten til dem, der har kendskab til sættet.
Mvh Mathias
MathiasFB
Tidl. BOWA HiFi
Lokalitet: Fyn Syd
Sendt: 25 Februar 2008 kl. 10:02 | IP-adresse registreret
Er der nogen der kender noget til sættet?
Hvor kraftigt er det?
Værdi?
Finn29
Sendt: 25 Februar 2008 kl. 11:57 | IP-adresse registreret
Sættet kender jeg ikke, men storebroderen su-a6 + se-a5 har jeg haft
SU-A6
SE-A5
på et sæt B&W 802 S80 det spillede rigtig godt, men der manglede kræfter til B&W'erne
så lillebror som du spørger til skal nok ikke sættes til nogle alt for krævende højttalere.
Hilsen Finn / Finn29
MathiasFB
Tidl. BOWA HiFi
Lokalitet: Fyn Syd
Sendt: 25 Februar 2008 kl. 12:27 | IP-adresse registreret
Det skal sættes til et sæt System Audio SA510 + en SubElectro 175 subwoofer.
Er det mon tilstrækkeligt? Sammenligning med min Yamaha RX-V620RDS?
Bond
Bruger siden: 05 Juni 2003
Sendt: 25 Februar 2008 kl. 17:20 | IP-adresse registreret
MathiasFB skrev:
Er der nogen der kender noget til sættet? Kan godt huske "slimline" modellerne, og ikke mindst "new Class AA" fænomenet...de må være et sted fra 80érne, men langt fra Technics hifi-tid.
Apropos Technics hifi, havde de et kort come back omkring år 2000 med SU-C3000/SE-A3000 forstærker sættet - dobbelt mono konstruktion af effekt-delen og 2 separate 12V batterier i forforstærkeren for støjfri forsyningsspænding...det forsvandt ud af, i hvertfald det Danske, markede næsten hurtigere end det kom ind...prisen var også i den meget tunge ende, så nok derfor .....
Hvor kraftigt er det? - forstærkeren, er i følge ovenstående, opgivet til 60W og kan trække 145W fra lysnettet så hvis effektiviteten er omkring 50%?, holder det jo lige ....men vi er langt fra Technics monster forstærkere.
Dog springer vægten lidt i øjnene....selv om de kun er 5,3 cm. høje (dog de norm. 43 cm. i bredden) vejer de aligevel hhv. 9,5 og 4,5 Kg ? - hvis vi gætter på at tuneren vejer 3 Kg får vi en samlet vægt på 17 Kg !......samlignet med mange af de nye Surround-Receiver på markedet i dag, (som jo skal håndtere min. 7.1) er der ikke mange som vejer meget ?
Værdi? - nej, selv om de er pæne og i ok-stand, vil der højst være tale om en "foræringspris"
Bond
Haves : Bond-babe.....
Ønskes: Flere..!!
Til top Vis Bond's Profil Søg efter andre indlæg skrevet af Bond
MathiasFB
Tidl. BOWA HiFi
Lokalitet: Fyn Syd
Sendt: 25 Februar 2008 kl. 19:47 | IP-adresse registreret
Tak for indlægget. Var flot besvaret.
Det som springer mig mest i øjenene, er også det pæne slimline design, og bestemt vægten.
Det skal evt. fungere i en byttehandel med mine Pioneer HPm-110. Er dette mon ikke rimeligt?
MathiasFB
Tidl. BOWA HiFi
Lokalitet: Fyn Syd
Sendt: 02 Marts 2008 kl. 16:09 | IP-adresse registreret
Er der nogen der kan hjælpe med at give mig lidt informationer angående følgende:
Beomaster 1100
Beocord 1900
Beovox S25 - højttaler
Rank Arena 2000 GT - Forstærker med indbygget Garrard Model SP 25 MK III pladeafspiller
Rank Arena L720CP - kompakthøjttaler
Beogram 1000 - pladeafspiller
Sansui SE-8X - stereo graphic equalizer
DUX TA4000- forstærker
Ste-ma 600 - højttaler
Wharfedale e.seventy(E70) - stor gulvhøjttaler fra 80'erne
Binatone "rack" - hifiskab med forstærker, effektforstærker og pladeafspiller
Sumax STR-1010 - forstærker
Tak
r-l-b
Sendt: 02 Marts 2008 kl. 16:32 | IP-adresse registreret
Der er ikke rigtigt noget af det B&O grej du nævne der rigtig rykker - de er alle mindre modeller - kan sagtens spille - men de vil ikke rykke bukserne af dig.
Beogram 1000 har det også med at rumle lidt og nye pick up er er svære at få
DUX tror jeg er Philips i andre klæder og derfor er det bare konsum 70er-stads der lige netop opfylder DIN normens hifi krav men så heller ikke meget mere
dine wharfedale
Wharfedale Eenty
er vist fra en periode med meget pynt og mange enheder - jeg har aldrig lyttet til dem og vil derfor ikke kommentere dem
Er det noget du har fået tilbudt Mathias?
Garrard 25 er ikke noget at råbe hurrar for :-( og Rank Arena var et engelsk firma som fik lavet en masse OEM - nogle Rank Arena kunne du købe med fx. Fona Badge og så Rank Arena pladespillere med Garrard værk - Automatisk med sinlge plade stacker så man bare satte to plader over og så var der underholdning i i halv times tid
MathiasFB
Tidl. BOWA HiFi
Lokalitet: Fyn Syd
Sendt: 02 Marts 2008 kl. 16:37 | IP-adresse registreret
Tak for det fine svar
Det er alt sammen noget jeg har fået tilbudt.
Nej desværre er B&O grejet en smule trist.
Garrard 25 holder jeg mig fra så
Har netop oprettet en tråd angående Wharfedale E.Seventy (E70). Den er dog lidt overflødig nu: http://www.hifi4all.dk/forum/forum_posts.asp?TID=62684
