Tilbage til HIFI4ALL.DK 17. juni 2026 | 00:23
Emne Emne: Spadestik er for små! (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
flemsemand
Bruger siden: 07 Maj 2004
Sendt: 20 Juni 2011 kl. 11:24 | IP-adresse registreret
Jeg har et Voodoo Ultralinear højttalerkabel jeg er rigtig glad for.
Problemet er at jeg efter højttalerskift er rendt i det problem at de monterede spader desværre er for små til de stik der er på de nye højttalere.
Spaderne har en indvendig bredde på 7 mm.
Er der nogen der evt. har erfaring med at sætte spaderne på løse bananstik?
Jeg har selv nogle liggende, men de passer ikke i størrelsen, desværre.
Nogle forslag?
Til top Vis flemsemand's Profil Søg efter andre indlæg skrevet af flemsemand
Bond
Bruger siden: 05 Juni 2003
Sendt: 20 Juni 2011 kl. 11:41 | IP-adresse registreret
Nå, det er åbenbart et generelt problem...
The Ultralinear speaker cables ($1200 per eight-foot single-wire pair, $1400 per eight-foot biwire pair) look a heck of a lot like the interconnects, but they are much more difficult to work with. At 14mm in diameter, the cables are thicker than the interconnects and also incorporate active shielding. The Ultralinear speaker cables make use of 13 conductors in three groups. The conductors are made of the same silver/copper material found in the interconnects and have the same Teflon dielectric. The speaker cables incorporate Cardas spades made of copper with a silver plating and coated with rhodium for protection, but herein lies a problem. These spade lugs are among the smallest I have seen, so unless your speakers sport very narrow binding posts you may be forced to use the hole in the center of the post (or go with bananas). Combine this with the fairly stiff wires and you have a surefire recipe for frustration. I'm sure that VooDoo Cable offers other spades; they should consider making those standard equipment. The conductors, shielding, and connectors all get the same cryogenic treatment as the interconnects.
du skal finde nogle som kan spændes fornuftigt på spaderne (god anlægsflade) kunsten er at finde dem passende både på inder- (7 mm) og samtidig på yderside...
Kan du ikke (forsigtigt) udvide spaderne ?
Bond
Haves : Bond-babe.....
Ønskes: Flere..!!
Til top Vis Bond's Profil Søg efter andre indlæg skrevet af Bond
flemsemand
Sendt: 20 Juni 2011 kl. 14:15 | IP-adresse registreret
Jeg tør ikke rigtig forsøge at udvide dem, der skal lidt for meget til før de passer.
Jeg har selv bananstik med skrue i, men de er desværre også for store til de bananstik der er monteret.
Bond
Sendt: 20 Juni 2011 kl. 14:30 | IP-adresse registreret
Jeg kender ikke navnet på mine (er efterhånden gamle) men der er kun en vej, ud i butikkerne og se om du kan finde nogle med de rette mål - det behøver ikke være dyrt men det tager måske lidt tid
i mellemtiden kunne du jo gøre som anmelderen foreslår:"you may be forced to use the hole in the center of the post" altså stikke det ene (spade)ben ind i hullet og spænde forsigtigt...
Bond
Ønskes: Flere..!!
nhj4
Sendt: 20 Juni 2011 kl. 17:08 | IP-adresse registreret
hej der !
prøv at se om du ikke kan sætte den i fra siden af i stedet for nede fra, håber du forstår hvad jeg mener
Sendt: 20 Juni 2011 kl. 17:57 | IP-adresse registreret
Hvis der er et hul i terminalen på højttalerne til afisolerede kabelender, kunne du jo prøve om ikke den ene spids på spaden kan komme i der og så spænde godt til med efter kontrol over de næste par dage/uger.
flemsemand
Sendt: 20 Juni 2011 kl. 18:25 | IP-adresse registreret
Her prøvet, men det er meget svært at få den til at holde spaden fast.
Ville også gerne finde en løsning der kan give lidt bedre kontakt.
Jeg er ikke helt vild for at skulle skifte stik.
CARS10
Bruger siden: 15 Juli 2009
Sendt: 20 Juni 2011 kl. 21:46 | IP-adresse registreret
Tag dog de spade stik af,og så sno kablet omkring terminalerne,så kører det
     carsten
Gammelsmølf
Bruger siden: 30 Marts 2008
Sendt: 20 Juni 2011 kl. 22:49 | IP-adresse registreret
Det er da bare et spørgsmål om at tage en fil. I skruestikket med kablet og fil til det passer.
Det er 0,5 mm i hver side af stikket. Uden betydning.
Til top Vis Gammelsmølf's Profil Søg efter andre indlæg skrevet af Gammelsmølf
bantan
Bruger siden: 16 Marts 2011
Sendt: 20 Juni 2011 kl. 22:51 | IP-adresse registreret
flemsemand skrev:
Jeg har et Voodoo Ultralinear højttalerkabel jeg er rigtig glad for.Problemet er at jeg efter højttalerskift
er rendt i det problem at de monterede spader desværre er for små til de stik der er på de nye højttalere.Spaderne har en
indvendig bredde på 7 mm.Er der nogen der evt. har erfaring med at sætte spaderne på løse bananstik?Jeg har selv nogle
liggende, men de passer ikke i størrelsen, desværre.Nogle forslag?
Mange skrueterminaler er en smule smallere på tværs at hullet og der kan du evt få det henover
