Tilbage til HIFI4ALL.DK 16. juni 2026 | 05:57
Emne Emne: Jumper til Nordost (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
sirhish
Bruger siden: 01 Januar 2009
Sendt: 06 August 2011 kl. 20:41 | IP-adresse registreret
Skal ha lavet nogle jumper til mine højttaler, bruger et Nordost blue heaven leif højttalerkabel. Hvilken højttalerkabel der kan købes i løs-meter matcher Nordost bedst ???
StarTrek
Eks. Jamwa
Bruger siden: 25 April 2007
Sendt: 06 August 2011 kl. 20:52 | IP-adresse registreret
Mene at havde set original Nordost Jumper kabler, de skulle kunne findes til Nordost blue heaven, ved ikke om de også er
komme til Nordost Leif serien.
Ellers laver Nordost disse Jumper kabler, det er så mere et sprsmål om man skal havde dem med bana stil eller med spade,
der afhænge af hvad der sidde på de kable man bruge nu.
http://high-
performance.dk/product/175/1/Kabler/Diverse-kabler/nordost-n orse-jumpers.html
Norse Series Bi-Wire Jumpers
- Dedicated bi-wire jumper replaces stock items.
- Micro mono-filament technology
- Silver-plated OFC solid-core copper conductors
- Lightweight connectors in multiple configurations ensure optimum results
Although Nordost has always offered matching bi-wire jumpers for each of its speaker cables, now, for the first time, they
are offering a dedicated design that offers superior performance for the price.
Based on micro mono-filament technology, each pair of jumpers takes a straight-line, low-loss approach to the problem of
replacing the bent metal plates or generic wires supplied with most loudspeakers. Using high-quality, low-mass terminations,
the standard configuration is spade to 4mm Z-plug.
Here, simplicity really is the key: replace standard bridging plates with Norse Series Jumpers and you'll be astonished at the
difference. Do it with a speaker that's already hooked up with Nordost micro mono-filament speaker cable and that difference
will be even more apparent.
The Norse Series Jumpers are supported by a detailed installation guide. This outlines and illustrates the various options
when it comes to connecting bi-wirable speakers, ensuring that you get every last ounce of performance from your Jumpers
sirhish
Sendt: 06 August 2011 kl. 21:14 | IP-adresse registreret
Ja de ser fine ud, men 1400 kr. er også en slags penge mine højttaler er af den slags der er udstyret med tri wire terminaler, så det kan godt blive dyrt med de nordost jumper, håber lidt på at kunne finde et kabel i løs-meter jeg selv kan lave nogler af.
