Tilbage til HIFI4ALL.DK 17. juni 2026 | 15:44
Vintage
 HIFI4ALL Forum : Vintage
Emne Emne: snyde quadiofhonie (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
grummemikkel
Bruger siden: 16 Maj 2009
Sendt: 16 Maj 2009 kl. 22:58 | IP-adresse registreret
Hey-jeg ka huske at der var noget med at man ku lave en serieforbindelse af 4 højtalere-fra plus hele vejen rundt- og minus ditto- og -vupti-snydesorround- er der en der kan fortælle konkret hvordan man gjorde ?  peace Mik
outer and inner space
Til top Vis grummemikkel's Profil Søg efter andre indlæg skrevet af grummemikkel
Sund
Bruger siden: 07 Januar 2005
Sendt: 16 Maj 2009 kl. 22:59 | IP-adresse registreret
In the 1970's Hafler promoted "passive pseudo-quadraphonics", an inexpensive method of recreating ambient sounds at the rear from ordinary stereophonic recordings. Known as the "Hafler hookup", this consisted of two similar additional rear speakers, connected in series (typically 8 + 8 or 16 ohms total) between the live feeds to the front speakers. The crosstalk or loss of stereo separation in the front speakers was generally less than 2 dB while the rear sound level in a typical recorded live performance was about 7 dB below the front, but clearly audible. This passive method was almost as good as any of the matrix decoders which attempted to reconstruct a surround sound field from a two channel recording. It has been observed that ambient sounds in a concert, such as applause or coughs from the audience, are generally received in a non-correlated phase by the stereophonic microphones, while sounds from the musicians are generally in a more or less synchronous phase. Thus, if rear speakers are fed with the difference between the stereo channels, audience noises and echoes from the auditorium can be heard from behind the listener.
mvh sund,
I'm only in it for the music.
grummemikkel
Sendt: 16 Maj 2009 kl. 23:22 | IP-adresse registreret
thanx man- jeg roder rundt med 10-12 fede speakers,som jeg vil hooke up sjovest muligt... jeg spiller på 800 watt biamp Seamour Duncan- over MesaBoogie bund-2 stk.18"el.voice"freetless'JP bass,mman ,Stick.  hihi..kh MIK
Sund
Sendt: 16 Maj 2009 kl. 23:25 | IP-adresse registreret
Anytime, lyder som om der er mulighed for at prøve noget sjovt, spændende og lærerigt.
God fornøjelse.
mvh sund,
