Tilbage til HIFI4ALL.DK 13. juni 2026 | 19:48
Emne Emne: Spændende patenter? (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
D A O
Bruger siden: 08 Februar 2010
Sendt: 05 September 2013 kl. 19:54 | IP-adresse registreret
Det kunne være sjovt med en tråd om patenter inden for audio,
fordi det giver inspiration og fordi private godt må efterligne men ej sætte i produktion (lave profis af)
Håber det har interesse og at I har en mening om dem!
Plus det er sjovt at se at meget inden for AUDIO er af meget gammel dato
vh Hans Lund
D A O
Sendt: 05 September 2013 kl. 19:55 | IP-adresse registreret
Speaker system with subwoofer US 8428291 B2
Abstract
A speaker system includes an enclosure defining a resonance chamber, a loudspeaker received in the resonance chamber, and a sound wave reflecting member. The enclosure includes a front panel and a base. The loudspeaker is exposed at the front panel. The base includes a back panel facing the front panel, an inner tube, and an outer tube. The back panel defines a back bass port. The inner tube and the outer tube extend from the back panel and are received in the resonance chamber. The inner tube surrounds the back bass port. The outer tube surrounds the inner tube. The sound wave reflecting member is coupled with the outer tube and the inner tube. The sound wave reflecting member, the outer tube, and the inner tube cooperatively form a resonator. The resonator communicates with the resonance chamber and the back bass port.
Mon det virker ? for mig er det bare en anden måde at lave en lang bas port på og tror jeg har set det før!
vh Hans Lund
Hans Mortensen
Bruger siden: 12 September 2007
Sendt: 05 September 2013 kl. 20:49 | IP-adresse registreret
En god idé med denne tråd.
For nogen tid siden blev jeg interesseret i Tor Forsmans "vertical split" højttalersystem og fandt hans norske patent. Det er her: https://dbsearch2.patentstyret.no/PDF/1989/B1/19891387_28687 .pdf
vh
Til top Vis Hans Mortensen's Profil Søg efter andre indlæg skrevet af Hans Mortensen
D A O
Sendt: 06 September 2013 kl. 16:06 | IP-adresse registreret
Tor Forsman 1989/B1/19891387_28687
Hans Mortensen takker, spændende princip, handler vel om strålingsimpedansen for membranen ?
altså koblingen mellem membran og rummet, er der nogen der kan forklare hvorfor det er sådanne?
vh Hans Lund
D A O
her er et andet patent fra, nok en af de første dynamiske højttaler (den store stemme)
US2014621
P.L.JENSEN 1934 2. jan
Peter L. Jensen er Dansker fra Falster
vh Hans Lund
D A O
Sendt: 06 September 2013 kl. 16:12 | IP-adresse registreret
1930 - Albert L. Thuras filed patent No. 1,869,178 on Aug. 15, 1930, granted July 26, 1932, for the bass-reflex principle while working at Bell Labs.
bass-reflex
vh Hans Lund
Modifix
Bruger siden: 02 Maj 2003
Lokalitet: Øerne
Sendt: 06 September 2013 kl. 17:19 | IP-adresse registreret
http://images3.freshpatents.com/pdf/US20120181105A1.pdf
Til top Vis Modifix's Profil Søg efter andre indlæg skrevet af Modifix Besøg Modifix's Websted
D A O
Sendt: 03 Oktober 2013 kl. 02:56 | IP-adresse registreret
Modifix dit link virker ikke
vh Hans Lund
