Tilbage til HIFI4ALL.DK 23. juli 2026 | 20:46
Emne Emne: Kenwood KC-X 1 & KM-X 1 Highend-THX-Surr (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
dr0zie
Bruger siden: 16 April 2005
Sendt: 06 Marts 2006 kl. 16:35 | IP-adresse registreret
Hej, jeg står på randen til at købe en denon 2106 forstærker men nu får jeg et tilbud jeg vil hører jeg om holder...
Det handler om et tilbud på følgende udstyr:
Kenwood THX® Subwoofer SW-X1
Kenwood DVF-5020 (DVD)
Kenwood CD afspiller
Kenwood KC-X 1 & KM-X 1 Highend-THX-Surround
Men så er mit spørgsmål er (Kenwood KC-X 1 & KM-X 1 Highend-THX-Surround) bedre end danon eller er det dårligere
Udstyret er ca 4 år gammelt og i følge forhandleren er der kun solgt 10 styk i danmark..
Lidt info om hver:
Bass (Kenwood THX® Subwoofer SW-X1)
Large subwoofer designed to Home THX® specifications
Large open duct enclosure to avoid wind noise and turbulence
30cm high-strength, injection-molded polypropylene cone
150W peak input power
87dB sensitivity
Second subwoofer output terminal
Sturdy gold-plated input terminal accepts banana plug or 45mm cable
Forstærker:
A few years ago the KC-X1/KM-X1 amp/preamp combination
was Kenwood's flagship THX system. The KM-X1 6-channel
amplifier is capable of 100W rms per channel or 130W
per channel in stereo mode. The KC-X1 preamp has
several DSP modes for Dolby Pro Logic, stereo and THX
Cinema. As well as the usual array of audio inputs it
has several VCR input/ouput connections and has
on-screen menus. It also has a tuner.
Description
This is a high-end Kenwood KC-X1 THX Dolby home theater surround preamp/ tuner.
This receiver is in truly EXCELLENT condition, with no dents, no chips, no cracks, no damage; little surface wear or scuffs from normal use.
The black faceplate is clean and perfect, with crisp, unfaded lettering and text. The LED display is clear and bright, and all buttons, knobs, and jacks are intact and solid. The flip-down front panel is intact and solid --opening smoothly and closing securely.
This preamp has been tested in full working order, and it sounds GREAT!
This unit is a full-function audio-video control center! It's ideal for anyone looking for an affordable way to integrate and control their home entertainment sources.
It has a built-in tuner, and inputs for SEVEN line-level sources (VCR/ Satellite/ DVD/ TV/ CD, etc), and phono, so this is a receiver for all your media needs!
It offers convenient features like an easy-to-read LED display and a variety of sound modes to enhance your listening experience, whether it's stereo music or home theater movies.
From essential controls like bass, treble, and balance adjustments to full THX Dolby Pro Logic, this receiver lets you tailor your sound to fit your preference.
Whether your preference is Hollywood blockbusters action movies or good old rock and roll, this fits the bill.
This system is a great way to integrate all your audio and video sources together in one highly functional system.
Its stylish and tasteful design means it will look great in any room in your home. A multi-purpose receiver like this may quickly become one of your most-often-used piece of entertainment equipment.
The Kenwood name and reputation for quality and durability really speaks for itself.
Kenwood introduces the next stage in the evolution of home theater: the world's first THX Controller/Tuner/Video Switcher. The KC-X1 builds on the sonic accuracy of Dolby Pro-Logic surround sound by incorporating the re-equalization, decorrelation and timbre-matching advances of Lucasfilm THX technology.
The KC-X1 is a complete home entertainment control center. It lets you connect as many as four video and five audio components. Specific connections on the back panel allow you to connect other Kenwood components and command them using the unit's Learning Remote Control (NOT included).
A tuner with 30 random presets gives you instant access to your favorite broadcast sources. And a large fluorescent dot-matrix readout, plus on-screen display capability, make it easy to monitor all functions.
Digital Signal Processing (DSP) capabilities provide a variety of home theater modes. Choose from full Home THX Cinema®, standard Dolby Pro-Logic, DSP Logic, or Dolby 3 stereo, as well as stereo and mono audio modes. No matter what the sound source or the sophistication of the rest of your current system, the Kenwood KC-X1 delivers a performance of unprecedented clarity and dynamic impact.
AUDIO section
Total hermonic distortion
........................ 0.002 % (20 Hz- 20 kHz, 1.2 V)
.................................... 0.002 % (1 kHz, 1.2 V)
Frequency response
LINE (CD, TAPE1, 2, VIDEO1)
.......................... 15 Hz- 100 kHz, + 0 dB,- 3 dB
PHONO"RIAA"response
.................................. 20 Hz - 20 kHz, ± 0.5 dB
Signal to noise ratio (IHF'66)
PHONO (MM)........................................................ 78 dB
LINE (CD, TAPE 1-2, VIDEO 1-4)................... 100 dB
Input sensitivity/impedance
PHONO (MM)........................................ 2.5 mV/47 kQ.
LINE (CD, TAPE 1-2, VIDEO 1-4) .... 200 mV/47 kn
Tone control
BASS.............................................. + 8 dB (at 100 Hz)
TREBLE.......................................... ± 8 dB (at 10 kHz)
Output level/impedance
Front channel preout.............................. 1.2 V/390 Q
Sub woofer, center
channel preout....................................... 1.2 V/390 Q.
Surround channel preout...................... 1.2 V/390 Q
VIDEO section
Television format...................................................... ......... NTSC
Input level/impedance
VIDEO (Composite)................................ 1 Vp-p/75 a
Input (VIDEO 1, 2, 3, 4)
S-VIDEO (Luminance signal)............... 1 Vp-p/75 Q.
(Chrominance signal).... 0.286 Vp-p/75 Q
Input (VIDEO 1, 2) Output level/impedance
output (VIDEO 1, 2, 3, MONITOR OUT 1, 2)
S-VIDEO (Luminance signal)................ 1 Vp-p/75 Q.
(Chrominance signal).... 0.286Vp-p/75 LI
output (VIDEO 1, 2, MONITOR OUT)
FM tuner section
Tuning frequency range.......................... 87.5 MHz-108 MHz
Usable sencitivity (MONO at 75 LI).......... 0.95 u V/10.8 dBf
Total hermonic distortion (at 1 kHz)
MONO.......................................... 0.1 % (65 dBf input)
STEREO..................................... 0.2 % (65 dBf input)
Signal to noise ratio (at 1 kHz)
MONO ........................................ 80 dB (65 dBf input)
STEREO..................................... 74 dB (65 dBf input)
Sterao separation (at 1 kHz)
1 kHz......................................................... ............. 50 dB
Capture ratio (WIDE)...................................................... .. 1.0 dB
Selectivity (± 400 kHz)...................................................... 53 dB
AM tuner section
10 kHz step............................... 530 kHz - 1,700 kHz
Usable sensitivity..................................... 10 ^V/ (400
Signal to noise ratio (at 30% mod. 1mV input)............ 50 dB
Total harmonic distortion................................................. 0.4 %
GENERAL
Power consumption
.......................................................... ... 50 W
AC outlets
SWITCHED.......................................... 3 (940 W max.)
Dimensions..................................... W : 440 mm (17-5/16")
H : 161.5 mm (6-3/8")
D : 380 mm (14-15/16")
Weight (Net)...................................................... 10.5 kg (23.11b)
Så håber i kan hjælpe mig om jeg stadig skal holde mig til Denon AVR-2106 og så bare købe en eller anden brugt sub til 2-3000 kr. og så købe dali concept serien med concept 2 som bag højtalere..
eller om jeg skal købe ovenstående... Hele sættet for 4000 kr..
Det jeg skal bruge Lyden til er frem for alt Hjemmebiograf fra Pc + Dvd engang i mellem video men dog ikke så ofte og så bruger tuneren til musik...
Patrick B.
Til top Vis dr0zie's Profil Søg efter andre indlæg skrevet af dr0zie
KennethB
Bruger siden: 04 November 2005
Sendt: 03 August 2006 kl. 22:58 | IP-adresse registreret
Så vidt jeg kan se er der ikke DTS og DD på preampen, og det duer jo ikke
Mvh KennethB
Aurum Cantus Leisure 2 SE - Jolida 1501A
Til top Vis KennethB's Profil Søg efter andre indlæg skrevet af KennethB
