Tilbage til HIFI4ALL.DK 13. juni 2026 | 00:21
Emne Emne: Analyze og Plot Spectrum i Audacity (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
mtolesen
Bruger siden: 31 Juli 2005
Sendt: 22 August 2016 kl. 12:19 | IP-adresse registreret
Jeg har nogle lydfiler, optaget med udstyr med samplerate op til omkring 200 kHz, da jeg er interesseret i ultralyd over 20 kHz. Jeg vil gerne analysere disse lydfiler, og har brugt Audacity, og funktionen Plot Spectrum under Analyze menuen, i Audacity.
Her er mit spørgsmål, når jeg anvender skifter "Size" fra 512, til f.eks 16384, kan jeg se at opløsningen bliver bedre på plottet, men tilgængæld forsvinder de høje ferkvenser. Hvorfor har "size" indvirkning på det viste frekvens plot, og hvilke af de to plot repræsentere best frekvens indholdet i min optagelse?
martin olesen
Til top Vis mtolesen's Profil Søg efter andre indlæg skrevet af mtolesen
mtolesen
Sendt: 24 August 2016 kl. 23:03 | IP-adresse registreret
Lage ovennævnte spørgsmål ud på "Audacity Forum", og fik følgende glimrende pædagogiske forklaring, måske det kan være hjælp for andre:
Try picturing it as physical "things" rather than "frequency components:
Imagine that you are collecting berries from a bush and you have several baskets to put the berries in. While you are picking the berries you sort them according to size, so, if you have 3 baskets, then you put the biggest berries in basket #1, the medium berries in basket #2 and the smallest berries in basket #3. When you have picked all of the berries from the bush you can count how many berries are in each basket.
Now imagine that rather than 3 baskets you have 6 baskets, and again you sort the berries according to size: biggest in basket #1, next biggest in basket #2 and so on up to the smallest berries in basket #6.
Assuming the same number of berries in both cases, it's obvious that when you have 6 baskets, there will be less berries per basket than when you have 3 baskets.
A similar thing is happening with FFT analysis - the more frequency "bins", the less will be in each bin.
Boye
Bruger siden: 18 Juli 2003
Sendt: 01 September 2016 kl. 12:03 | IP-adresse registreret
Tak for den forklaring. Jeg sad nemlig også og grublede over problemet, men da jeg jeg ikke er tilstrækkelig effen i
Fouriertransformationer - hverken hurtige eller langsomme - var det ikke megen nytte til.
Jeg fandt også frem til dit spørgsmål på Audacitys forum, og der er svaret uddybet endnu mere.
Håber at dit projekt får fremdrift.
Boman
Bruger siden: 19 Oktober 2004
Sendt: 01 September 2016 kl. 13:23 | IP-adresse registreret
Hvorfor er du interesseret i ultralyd i musikfiler?
Akustiske musikinstrumenter/stemmer genererer ikke ultralyd, i hvertilfælde ikke i et niveau vi kan høre.
Vores hørelse kan ikke detektere ultralyd.
Derimod kan der være interessant, hvordan mikrofoner, forstærkere, delefiltre, mikserpulte, AD og DA konvertering, højttalere mm. håndterer
høje frekvenser, da det kan påvirke lyden længere nede i hørbare frekvensområde.
Jeg er ikke helt ung mere, og kan derfor ikke høre de allerhøjeste frekvenser, MEN jeg kan stadig høre om musikinstrumenterne/stemmerne
bliver gengivet korrekt/naturligt.
P.S. når du analyserer lydfiler ved du ikke, om de høje frekvenser - ved meget lave niveauer - skyldes musikken, eller er de bare støj, genereret
af optage/gengivekæden.
Boman
mtolesen
Sendt: 01 September 2016 kl. 13:27 | IP-adresse registreret
Hej Boman,
Det er ikke musik filer, det er akustisk støj optaget i frekvens området 15 kHz til 90 kHz, som jeg skal have analyseret.
Hilsen
Martin
Boman
Sendt: 01 September 2016 kl. 13:34 | IP-adresse registreret
Hvilken mikrofon bruger du til det?
Jeg har mikrofoner der går meget højt op (40-60 kHz), men til gengæld er følsomheden lav, dvs. signal/støj forhold er lille.
Så er det ultralyd eller støj du måler?
Boman
Boye
Sendt: 01 September 2016 kl. 16:31 | IP-adresse registreret
Relevant spørgsmål. Jeg har nævnt for mtolesen, at du nok ville vide noget om dette felt.
Lige i dette tilfælde burde det være til at finde ud af ved at lave en sammenligning af to målinger hhv. med og uden signal og dermed få en skønsmæssig vurdering af støjniveauet.
