Tilbage til HIFI4ALL.DK 19. juli 2026 | 03:32
Emne Emne: Det ser lovende ud! (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
Harritz3257
Tidl. gichael3257
Bruger siden: 11 Juni 2003
Sendt: 16 Juni 2006 kl. 13:50 | IP-adresse registreret
http://syphaonline.com/SYPHAnewsitems2006/SYPHAnews20060614- 02.html
eCinema Systems announces new LCD technology (14/6/2006)
Stunning LCD performance will make CRT monitors obsolete for evaluation
eCinema Systems has successfully demonstrated the technology behind their upcoming High Dynamic Range, High Color Depth display. NAB show-goers lined up in April for packed, back-to- back, private screenings of the jaw dropping system that most recognized will make the CRT obsolete for evaluation. Subsequent screenings have confirmed that response. This LCD-based monitor is the result of six years of research in the field. The HDR technology offers 10 to 12 bits per color channel (for 30 to 36 bit displays) or 1000 to 4000 step gray-scales. Contrast ratio is in the order of 30,000:1 which means black levels displayed are beyond the capability of current CRT monitors.
Martin Euredjian eCinema Founder & CEO is extremely excited about the response to the new technology and made the following comments shortly after NAB, "It is well known that LCD displays did not until now produce the same deep blacks that were achievable when using a CRT. Color depth is, of course, the 8 bit bottleneck issue. Images on the screen -- at the pixel level -- are limited to a best-case of 256 levels between black and white. In other words, if you painted a gray scale you could, at most, see 256 steps. The reality of the matter is that due to calibration and gamma adjustments most displays can't do much better than about 200 steps between black and white".
"It is because of this that the whole idea of viewing and evaluating 4:4:4 10 bit LOG images on an 8 bit device was less than ideal. While the source material is able to represent in the order of 4,000 levels of gray, the monitor could (on a good day) only show about 200 of those levels. Attempting to view 3D LUT's on such a monitor would be pointless. With a 200-level gray scale, LUT-based manipulation would have to be limited to very minor adjustments in order to avoid losing even more of your gray levels. However, the rules are about to change."
eCinema's DCM40HDR, will begin shipping by the fourth quarter of this year. This is a 40 inch, 1920 x 1080 LCD display with full 4:4:4 capabilities suitable for viewing and evaluating 10 bit linear and 10 bit log DI output from the highest quality cameras and systems in use today for digital cinema production as well as high-end DI and Telecine in post-production.
Euredjian continues "The good news is that the technology is scalable. We are looking into implementing it on a 57 inch 1920 x 1080 LCD as well as an 82 inch 1920 x 1080 LCD. We are also looking into implementing the technology on projectors".
1920 x 1080. Jeg kan næsten ikke vente til jeg bliver millionær og får råd til et nyt TV
TapeConnection
Lukket efter brugers ønske!
Sendt: 16 Juni 2006 kl. 14:03 | IP-adresse registreret
Ikke noget personligt, men: Det er temmeligt symptomatisk for fladskærmsmarkedet, at ud af dén pressemeddelelse er det den _mindst_ interessante oplysning, nemlig antallet af pixels, der får dig til at savle...
Mvh. TC
www.tapeconnection.dk
Rasmus Larsen
Flatpanels.dk
Bruger siden: 05 September 2005
Sendt: 16 Juni 2006 kl. 14:26 | IP-adresse registreret
Det interessante ved pressemeddelelsen er, at man har nået en ny milepæl for farve bit-dybde. Bemærk også, at det er nået ved en farveopløsning på 4:4:4 - altså "ikke-dithering" baseret.
Det giver bestemt gode muligheder for et virkelig godt billede. Kontrasten er som sådan vist før, men de 1920x1080 er, som Otto er inde på, en ret ligegyldig information i forbindelse med nyheden.
Men bemærk også, at det ikke rigtig sigter mod forbrugermarkedet i øjeblikket. Der findes allerede andre 10-bit LCD paneler til medicinalindustrien, men det først skridt mod forbrugersegmentet er i min mening taget med HDMI revision 1.3, der tillader deep color, altså farvedybde i 30, 36 og 48-bit.
Næste skridt er at få skærmene og udstyret til at håndtere datamængderne og videomaterialet til udnytte det. Det tager tid, men er en interessant udvikling.
Jeg har allerede beskæftiget mig med både den kommende HDMI standard og denne pressemeddelelse, som der kommer meget mere om i den kommende uge på Flatpanels.dk
www.Flatpanels.dk - Guide til fladskærme
Til top Vis Rasmus Larsen's Profil Søg efter andre indlæg skrevet af Rasmus Larsen Besøg Rasmus Larsen's Websted
roundsound
Bruger siden: 29 Marts 2004
Sendt: 16 Juni 2006 kl. 14:28 | IP-adresse registreret
Kan du ikke forklare hvad resten betyder, Otto?
Rasmus Larsen
Flatpanels.dk
Sendt: 16 Juni 2006 kl. 14:35 | IP-adresse registreret
Jeg ved ikke om mit indlæg er fuldstændig uforståeligt, men det står nu forklaret der.
roundsound
Sendt: 16 Juni 2006 kl. 14:38 | IP-adresse registreret
Havde ikke lige fået opdateret siden før jeg begyndte at skrive, så havde ikke set dit indlæg
Rasmus Larsen
Flatpanels.dk
Sendt: 16 Juni 2006 kl. 14:43 | IP-adresse registreret
Helt i orden
Men det kan naturligvis sagtens uddybes. Det gør jeg også i den nyhed/artikel jeg snakkede om i sidste indlæg.
Barnebarn
Bruger siden: 05 Juni 2004
Sendt: 16 Juni 2006 kl. 14:46 | IP-adresse registreret
Jeg synes da at det 1920x1080 er ret interessant i disse HD-DVD og Blu-Ray tider, hvor HD-filmene netop ligger på det niveau.
Nu ejer jeg ikke selv fladskærme - men bruger projektor - og selv om der nu efterhånden er mange announcements med 1920x1080 skærme til både plasma og lcd-skærme, så er det da stadig ret interessant for mange af os.
Nu venter jeg bare på 1920x1080 projektorerne som kommer ned i pris... Forhåbentlig de nye panasonic, sanyo eller sony modeller.
Barnebarn
Se mit udstyr: Bio Barnebarn
Til top Vis Barnebarn's Profil Søg efter andre indlæg skrevet af Barnebarn
Rasmus Larsen
Flatpanels.dk
Sendt: 16 Juni 2006 kl. 15:07 | IP-adresse registreret
Citér:
Det er da bestemt også - bare ikke i forhold til den pressemeddelelse der nævnes i første indlæg. Der er det blot en sidebemærkning. Egentlig handler den om noget langt mere relevant for billedkvaliteten i et LCD panel.
luis figo
Bruger siden: 26 Januar 2004
Sendt: 17 Juni 2006 kl. 01:13 | IP-adresse registreret
Det der ligeledes bliver spændende er prisen. Det ser ud til SED tv kan gå en svær tid i møde. Formentlig er SED udskudt fordi produktionsomkostningerne er for høje. De skal længere ned idet SED kommer til at konkurrere med teknologier der bliver bedre og bedre.
Nogen siger at deres LCD og plama tv har et dårligt billed med standard signal, men hvad hvis tvet fodres med HD TV som snart (1-3 år) bliver hverdag eller for nogen er hverdagskost?
Savner også at høre noget nyt fra motorola og deres nano tv (NED TV):
http://www.physorg.com/news4031.html
Til top Vis luis figo's Profil Søg efter andre indlæg skrevet af luis figo
notional
Bruger siden: 09 Juni 2004
Sendt: 17 Juni 2006 kl. 01:30 | IP-adresse registreret
Hvis i rent faktisk går ind på producentens side, kan i se den eneste model lige nu er en 23" med en opløsning på 1920x1200. DET er da absolut spændende at nævne opløsningen, når ikke engang Philip's overdyre wannabe B&O 32" modeller har et så højtopløst panel.
Bevares, opløsning er ikke alt, men en højere opløsning, giver alt andet lige en bedre mulighed for høj kvalitet. Mindre aliasing, mindre "digitaliseret" billedet grundet store firkantet pixels, der giver mossaik effekt osv.
At farvedybde og sortniveau er på vej op på fladskærms markedet er absolut velkomment, men det er jo ikke noget nyt. Selvom teknologien er forsinket igen, er SED stadig på vej med en lancering 2007 og en masseproduktion til OL i 2008 (i Bejing?).
Til top Vis notional's Profil Søg efter andre indlæg skrevet af notional
luis figo
Sendt: 17 Juni 2006 kl. 01:36 | IP-adresse registreret
