Tilbage til HIFI4ALL.DK 16. juli 2026 | 16:52
Emne Emne: Nyt om Lyngdorf TDA 2200 (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
donkeyshark
Bruger siden: 31 Oktober 2003
Sendt: 27 April 2005 kl. 21:55 | IP-adresse registreret
Jes Mosgaard fra Lyngdorf Audio, tidligere TacT har skrevet om TDA 2200 i forhold til TacT M/S 2150 samt om den kommende rumkorrektion. Indlægget er sakset fra Lyngdorf User Group på Yahoo.
Dear All,
From the Lyngdorf engineering team in Denmark we would like to welcome all users
to this group - and I would like to make a reply to the RCS functionality of the
TDA2200.
Currently we are strengthening the R&D resources here in Denmark, we have
invested heavily into R&D and during the next couple of months we will be a
total of 7 engineers working on development in house in our new premises that
are under rebuilding. We will focus on improving Software for the current
products, improve the current line of amplifiers and develop the new generation
"Blade" amplifiers which will incorporate a total new generation of output
stages in the amplifier section.
But for the current generation we have changed a lot of technical details in the
TDA2200 compared to the 2150. First of all many of the tweaks related to the
2150 is related to EMC issues which we have adressed in the TDA2200 where there
is a much better AC input filtering custom build and tuned to the design.
Furthermore all rectifiers are changed and filtered locally directly on the pins
and throughout the design we have optimized digital signals on the board by
tuning every lines transmission to avoid as much digital noise in the design as
possible. This together with the changed clock system is from my point of view
the main reason for the improved sound quality and more open "Millennium MkIII
sound".
In all mixed signal design the domain changes are extremely important for the
TDA2200 there are two domain changes, one in the input sample rate conversion
and one at the modulator from PCM to PWM - or Digital to analog in other words.
In order to maximize performance the clock system have been turned upside down
in the design so the modulator is running in master mode on a local high
performance clock, and it controls all timing in the amplifier - this reduces
jitter to an absolute minimun compared to transmitting a clock far to the
modulator cross the board. From the modulator the clock is transmitted in a
custom differential setup to the rest of the board where a local PLL in the new
high performance TI sample rate converter uses it for upsampling the input to
the internal approx. 100kHz sample rate which is chosen for max. performance and
to avoid 1:1 conversion problems with 96kHz inputs.
The design of the mainboard will have to be changed for implementing the
Lyngdorf RCS module, so the upgrade will be a new RCS board mounted on the
mainboard and an input module + measurement microphone. But more about this
later when we are closer to a final design.
We do not mind to be open about technical information on our products, part of
designing high performance products is good feedback from skilled users which
can lead to next generation of products - and in this process we do not gain
anything by hiding away behind epoxy shielded boards. So all input to our design
and use of the products will be welcome, and we will strive to deliver the
highest performance possible together with our business partners from NanoNord,
Texas Instruments and Dynaton.
Best regards
Jes Mosgaard
CEO,
Lyngdorf Audio
Beware the lollipop of mediocrity - one lick, and you suck forever..
Til top Vis donkeyshark's Profil Søg efter andre indlæg skrevet af donkeyshark
malkris
Bruger siden: 09 Januar 2006
Sendt: 30 August 2006 kl. 08:12 | IP-adresse registreret
Jeg har aldrig ejet en DVD og ved intet om dets digitale udgange
Er der nogen her der ved om man kan tilslutte en DVD digitalt til TDA 2200. Bliver der problemer mellem et 5.1 signal og forstærkerens 2 kanaler???
Hjælp
På forhånd tak!
Kristian
Til top Vis malkris's Profil Søg efter andre indlæg skrevet af malkris
donkeyshark
Sendt: 30 August 2006 kl. 12:12 | IP-adresse registreret
Jeg har brugt en DVD digitalt ind siden februar på min TDA 2200+ uden problemer. Man får selvfølgelig kun to kanaler ud i højttalerne, men ellers ingen problemer - bare lækker lyd.
harmonic
Sendt: 30 August 2006 kl. 12:40 | IP-adresse registreret
Hvor har du læst disse nyheder ?
jeg har ik set dem på lyngdorf forummet
Linn sonus faber og andet godt
Til top Vis harmonic's Profil Søg efter andre indlæg skrevet af harmonic
tnc99
Bruger siden: 26 Februar 2005
Sendt: 30 August 2006 kl. 12:47 | IP-adresse registreret
læs teksten, Lyngdorf User Group på Yahoo
Til top Vis tnc99's Profil Søg efter andre indlæg skrevet af tnc99
harmonic
Sendt: 30 August 2006 kl. 23:48 | IP-adresse registreret
Du er godt klar over at den såkaldt nyhed er over et år gammel Ik
jeg er lige blevet totat til grin på lyngdorf forumet
malkris
Sendt: 31 August 2006 kl. 16:06 | IP-adresse registreret
Tak for svar angående DVD+TDA2200.
Har i iøvrigt nogen idé om, om man kan bruge alle DVD-afspillere sammen med TDA 2200 eller om det bare er nogle.
Er der stor forskel på lyden alt efter hvilken afspiller man bruger???
Kristian
harmonic
Sendt: 31 August 2006 kl. 16:14 | IP-adresse registreret
Jeg vil siget at du sagtens kan bruge en simpel billig dvd/cd afspiller og få super lyd
Men du vinder helt klart noget ved at købe en god transport som en cd-1
men forskellen er ik så stor som med konventionell cd maskiner fordi det er et digitalt signal
spped six
Bruger siden: 31 Marts 2004
Sendt: 31 August 2006 kl. 16:17 | IP-adresse registreret
Det oprindelige indlæg er jo også fra april 2005.
/Henrik
Til top Vis spped six's Profil Søg efter andre indlæg skrevet af spped six
donkeyshark
Sendt: 31 August 2006 kl. 17:49 | IP-adresse registreret
Dér vil jeg nu modsige dig. Digitallyden såvel som analoglyden fra CD-1 er klasser over det meste, når du kører igennem en TDA 2200, især hvis der er RoomPerfect i forstærkeren. Selvom TDA 2200 er meget effektiv til at reducere jitter, er der stadig en næsten chokerende naturlighed over lyden med CD-1.
harmonic
Sendt: 31 August 2006 kl. 18:18 | IP-adresse registreret
Korrekt
men jeg levede på et tidspunkt med en 500 kroners dvd spiller på min tda2200 med gamut l3 i en almendelig stereo opstilling og det lød sku stadig fantastisk .
Så til spørgsmålet om man kan bruge en tda med en dvd maskine og få en  anstændig god lyd er svaret  JA abselut
Og til spørgsmåleet om en cd-1 lyder bedre end en dvd maskine svaret JA abelut
harmonic
Sendt: 31 August 2006 kl. 18:19 | IP-adresse registreret
Abelut    ja der sku så stå abselut ik
Olsen
Bruger siden: 21 Februar 2004
Sendt: 20 Oktober 2006 kl. 00:00 | IP-adresse registreret
Hvad er forskellen på "TDA 2200" og "TDA 2200+" ?
Se Lyngdorfs hjemmeside http://www.lyngdorf.com/ContentId/409/U/Default.aspx#TDA220+ RP
Jeg ved ikke helt hvad "+" står for.
Venlig hilsen
Olsen
Til top Vis Olsen's Profil Søg efter andre indlæg skrevet af Olsen
harmonic
Sendt: 20 Oktober 2006 kl. 00:21 | IP-adresse registreret
forskellen er at den har digitalt ouput
og at den har terminalen til roomperfect
Olsen
Sendt: 20 Oktober 2006 kl. 08:39 | IP-adresse registreret
Vil det sige, at den uden "+" ikke kan blive opgraderet med Room Perfect (RP) modulet nogen sinde?
Venlig hilsen
Olsen
donkeyshark
Sendt: 24 Oktober 2006 kl. 00:33 | IP-adresse registreret
Ok jo, man skifter hardware i den ved opgraderingen, og så har du én magen til + 'erne. Så vidt jeg husker til samme pris.
Coolzone
Bruger siden: 17 Marts 2004
Sendt: 09 Januar 2007 kl. 05:44 | IP-adresse registreret
Nej en TDA2200 uden(+) Kan ikke opgraderes med Room Perfect modul  som standard er derfor der kom en
TDA2200+ hvor der er lavet hardware ændringer så man kan få RP modul i en
TDA2200+/TDAI2200 men ikke i en TDA2200 uden(+)
Til top Vis Coolzone's Profil Søg efter andre indlæg skrevet af Coolzone
