Tilbage til HIFI4ALL.DK 21. juli 2026 | 01:51
Emne Emne: 12" Scheu-Analog Classic MKII arm ?? (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
r-l-b
Sendt: 09 Marts 2008 kl. 01:29 | IP-adresse registreret
The return of a classic. The predecessor of this arm sold hundreds and has almost achieved cult status. In response to demand, a redesigned Mk2 version has now been released.
den koster 490 euro = ca. 3.700 - det er da ikke så meget for en 12" arm - er her nogen herinde der kender den - har lyttet til den ?
Sveske
Bruger siden: 22 Januar 2006
Sendt: 09 Marts 2008 kl. 11:03 | IP-adresse registreret
Pæn er den da, men den ser da forfærdeligt simpel ud? Det ligner en arm der med lidt håndelag kunne efterlignes DIY. Evt. i træ
Guide til billedupload
27pH
Bruger siden: 13 Marts 2004
Sendt: 09 Marts 2008 kl. 11:17 | IP-adresse registreret
Man kunne vel også tage udgangspunkt i en af de kæmpestore tandbørster jeg kan huske fra legetøjsforretningerne. De var da mindst 12".
vH pH
Til top Vis 27pH's Profil Søg efter andre indlæg skrevet af 27pH
seansmiller
Bruger siden: 02 April 2006
Sendt: 09 Marts 2008 kl. 12:11 | IP-adresse registreret
Lidt flere oplysninger sakset fra Scheu's eget site:
The modifications are concentrated on the total redesign of the base unit for the tone arm. With high-gloss nickel finish and improved lift plus anti-skating mechanism and a lifting base that can be adjusted in two planes, it comes in black acrylic and makes the comfort of operation and the reliability much better than ever before.
The principle of a unipivot bearing and tried-and-trusted features such as the single-piece tone arm made of laser-cut sheet aluminium folded into a U-shaped profile with black powder coating, the nitrogen hardened and polished unipivot bearing for minimum friction and the standardized cabling running right through to the cinch plugs remain nevertheless as unparalleled as ever. Azimuth adjustment, lateral balance and anti-skating are built-in components of the arm.
The Classic MkII is available in two versions:. a 10-inch version with a pivot-to-spindle separation of 227 mm (effective mass 11 grams) and a 12-inch version with a pivot-to-spindle separation of 293 mm (effective mass 14 grams).
The 12-inch version of the arm is as ever the perfect partner for the Denon DL-103. A well-kept secret!
En Tandberg gi'r sig aldrig ud for mere end den er
