Tilbage til HIFI4ALL.DK 17. juli 2026 | 01:24
Emne Emne: Batteri forsyning - rev01 (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
gli-
Highend Sound
Bruger siden: 18 April 2003
Sendt: 14 April 2006 kl. 01:31 | IP-adresse registreret
http://www.tnt-audio.com/shows/bristol06r_e.html
hvis ikke den funker, så start ved TVT-audio's web og vælg "HIFI-show" og Bristol
se Living Voice's billede nr. 2, føjda batteri forsyning af Kondo grej
Der er tilføjet en besøgsartikel fra 6moons, også med batterierne
http://www.6moons.com/industryfeatures/livingvoice/definitiv e.html
Meier
Bruger siden: 19 Februar 2004
Sendt: 14 April 2006 kl. 08:59 | IP-adresse registreret
Gad vide hvad for udstyr de brugte til den forsyning?
Her er teksten:
And I haven't told you yet about the most exotic feature of this system! It was all powered from batteries! Yes, you read that right. This whole chain of fabulous hi-fi equipment wasn't connected to the mains, but got its power from 4 big gel batteries, of a size normally found in big lorries. In one of the corners of the room a large panel was installed with a complete power station. The power from the batteries was turned into 230 Volt AC by two big inverters. An equally sized charger was installed next to these. Demonstrator Kevin also played some music with the charger switched on to let us appreciate the difference. It did indeed sound better without, but I actually also enjoyed it with the charger, to be honest. And I'm not sure how representative a test it really is. But impressive it was. The main reason for this rather extreme solution is not only to get the most from a set, but mostly to enable people in areas with really bad power to still use a high-end system, or for use on (very) luxurious yachts, for example. Again, completely unrealistic, but instructive and very enjoyable. Who needs reality if you can listen to a system like that!
Meier
Sendt: 14 April 2006 kl. 09:01 | IP-adresse registreret
Normalt ville jeg ikke være imponeret over et par invertere - de genererer ofte ganske meget støj...
Det ville da også være mere "naturligt" at by-passe hele strømforsyningen, men det er bare min mening
gli-
Highend Sound
Sendt: 14 April 2006 kl. 09:42 | IP-adresse registreret
Det kommer på markedet senere, om det bliver som et Living Voice produkt ved jeg ikke. Alternativ et nyt "brand", da Living voice er forbundet med højttalere. Prisen er pt ligeledes uvis, men sikkert dansker-fjendsk.
