Tilbage til HIFI4ALL.DK 15. juli 2026 | 02:39
Emne Emne: Så er DVDO VP50 landet! (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
jdg1
Bruger siden: 18 Juli 2003
Sendt: 22 August 2006 kl. 19:43 | IP-adresse registreret
iScan VP50: high-definition video processor & hub
MSRP $2,999
DVDO iScan VP50
  Specifications
Inputs/outputs
Silver Front Panel
SDI Module
Datasheet
Product Manual
Order Online from the DVDO Store
Find an Authorized DVDO Reseller
The DVDO® iScan™ VP50 is a high-definition video processor and A/V hub that converts standard definition, high definition and PC signals from your DVD player, HD-DVD player, Blu-ray Disc player, HD DVR, game console or PC to any output resolution between VGA and 1080p, including popular HDTV resolutions such as 720p and 1080i.
The VP50 serves as your complete A/V hub, providing audio/video switching that simultaneously eliminates A/V lipsync and allows a one wire connection to display for all of your video needs.
VRS Video Reference Series Technology by ABT VRS Precision Deinterlacing™ technology by ABT - 480i/576i/1080i Motion, Edge & Source-Adaptive Deinterlacer
  • Five-field motion adaptive deinterlacing
  • Edge adaptive processing for smooth diagonal edges
  • Three frame video processing delay (Max)
  • Game Modes with very low latency
    • Sub-1 frame delay with edge adaptive processing
    • 2 frame delay with edge and motion adaptive processing
  VRS Precision Video Scaling II™ technology by ABT - 10-bit Scaling with Enhanced Sharpness Control
  ABT's Precision Gamma Correction - individual R/G/B Adjustments (0.5-2.5)
  ABT's Precision AV LipSync™ - intelligent digital audio delay technology to match Audio & Video timing
  ABT's RightRate™ - High-Performance Framerate Conversion
  ABT's AutoVFR™ - Intelligent Component Video Inputs with Automatic Video Format Routing
  ABT's AutoCUE-C™ - Automatic Chroma Upsampling Error detection & correction
  Analog HD Transcoding and Processing
  4 HDMI inputs which process up to 1080p-50/60 input signals
  Flexible Input and Output Aspect Ratio Controls
  Display Profiles – For multiple display, framerate, and image shift configurations (10)
  10-bit, 300 MHz Instrumentation Quality DACs (2x Oversampling for 1080p)
  Full-frame Timebase Correction
  High performance, multi-standard video decoder (10-bit: 480i/576i; 12-bit: 480p/576p/720p/1080i)
  High-quality super-adaptive comb filter with 2D Y/C separation
Flexible Digital and Analog Audio switching and routing – 4 HDMI audio/video inputs, 5 assignable audio inputs (4 digital, 1 analog) with 1 HDMI audio/video output and 2 active digital audio outputs.
Software Upgradeable
Ser spændende ud!!
wrong
Bruger siden: 30 August 2003
Sendt: 22 August 2006 kl. 19:49 | IP-adresse registreret
Fy for den lede da. Den ser meget seriøs ud. Nu må VP30eren jo kunne fåes for en slik. Ikke også Hr Jdg1(det var en hentydning)
MVH WRONG
Vinyl er hyl!
Skateboarding kicks ass...
jdg1
Sendt: 22 August 2006 kl. 19:57 | IP-adresse registreret
MVH WRONG
Nu er det fede jo ved DVDO, at de har et "trade-in" program.
Så man afleverer den gamle model og får en ganske pæn rabat på den nye model. Derfor kommer min VP30'er ikke på brugtmarkedet
wrong
Sendt: 22 August 2006 kl. 20:04 | IP-adresse registreret
jdg1 skrev:
MVH WRONG
Den behøver da bestemt heller ikke på brugtmarkedet. Du kan bare sende en PB til mig
MVH WRONG
Vinyl er hyl!
Raskolnikov
Sendt: 22 August 2006 kl. 20:23 | IP-adresse registreret
Et spørsmål:
Hvis man har en scaler som denne og en dvd med HDMI er det så ikke lige meget hvor god dvdens billedekredsløb er? Jeg mener det er jo DVDO der laver alt arbejdet oder?
wrong
Sendt: 22 August 2006 kl. 20:28 | IP-adresse registreret
Raskolnikov skrev:
Et spørsmål:
Nej ikke helt. Hvis du har en afspiller med SDI ryger signalet fuldstændig ubehandlet over i scaleren. HDMI bliver behandlet af den scaler der sidder i afspilleren, som så igen bliver behandlet i scaleren. Correct me if `m wrong
MVH WRONG
Vinyl er hyl!
Raskolnikov
Sendt: 22 August 2006 kl. 20:30 | IP-adresse registreret
Ok..så skal man jo "bare" have SDI
Vil en HD DVD / BD afspiller have gang af sådan en fætter som DVDO?
jdg1
Sendt: 22 August 2006 kl. 20:31 | IP-adresse registreret
Raskolnikov skrev:
Et spørsmål:
Ja, hvis du sætter afspilleren til at spytte et interlaced signal ud (480i for ntsc og 576i for pal).
Det optimale vil dog være et SDI output.
wrong
Sendt: 22 August 2006 kl. 20:32 | IP-adresse registreret
Mener du gavn? Det er et godt spørgsmål. anyone???
MVH WRONG
Vinyl er hyl!
jdg1
Sendt: 22 August 2006 kl. 20:35 | IP-adresse registreret
Det kommer an på....
Ej, hvis du har en 1080p projektor/skærm, så skal der ikke foretages skalering (dog mulig justering af timings) - så den del af dvdo'en kommer du ikke til at bruge. (Heller ikke de-interlacingen, hvis der ellers snart kommer en ordentlig afspiller på markedet - med 1080p24 output).
Men den kan jo en del mere end det - herunder foretager en del billedjusteringer osv.
Men kort sagt - hvis jeg kun så HD-DVD og Blu-Ray (med 1080p24 output) og intet andet, og jeg havde en skærm/projektor der kunne vise 1080p, så ville jeg nok ikke investere i en scaler.
wrong
Sendt: 22 August 2006 kl. 20:40 | IP-adresse registreret
1080p24???
Er det 24 frames/bit eller???? der er tale om(de dumme må jo spørge)
MVH WRONG
Vinyl er hyl!
TapeConnection
Lukket efter brugers ønske!
Sendt: 22 August 2006 kl. 22:58 | IP-adresse registreret
wrong skrev:
Raskolnikov skrev:
Et spørsmål:
Hvis du ikke er wrong, hvem er du så?  Seriøst: Du har delvist ret, men kun delvist. HDMI er ikke nødvendigvis skaleret, eksempelvis Pioneer's afspillere kan sende interlaced, uskaleret output ud via HDMI. Det betyder bare ikke at signalet er ubehandlet - strømmen fra MPEG-chippen skal stadig moduleres til et video-signal med sort og hvid-levels de rigtige steder, for nu bare at nævne én detalje. Der er forskelle på billedkvaliteten via HDMI der rækker ud over skalering og de-interlacing.
Mht. SDI, så er det stadig ikke et decideret ubehandlet signal der sendes til scaleren. Det er signalet fra MPEG decoderen der sendes ubehandlet videre. Det betyder at forskelle i MPEG decoderen, f.eks. chroma bug, stadig har indflydelse. Dvs. selv om du kører SDI, er der stadig forskel på hvilken afspiller du bruger. En HDMI lavet _rigtigt_, og med interlaced uskaleret output, kan i princippet levere et fuldt ud lige så godt signal til scaleren som SDI. At sammenligne SDI vs. HDMI ud fra en DV 989 står på to-do listen, men jeg har ikke haft tid til det endnu...
Mht. VP50, så ER der én på vej hjem i stuen...
Mvh. TC
www.tapeconnection.dk
TapeConnection
wrong skrev:
1080p24???
24 frames.
Mvh. TC
jdg1
Sendt: 22 August 2006 kl. 23:53 | IP-adresse registreret
Otto, TC skrev:
wrong skrev:
Raskolnikov skrev:
Et spørsmål:
Hej Otto
Det kunne være super cool med sådan en sammenlignende test (evt. også med andre afspillere?)
Der har været en del teoretisk snak om SDI vs. HDMI på bl.a. avsforum, men jeg tror nu ikke at det er en reel forskel så længe signalet hives ud af afspilleren lige efter mpeg dekoderen.
Men en faktisk test vil være et kærkomment initiativ!
jdg1
Sendt: 22 August 2006 kl. 23:54 | IP-adresse registreret
Otto, TC skrev:
wrong skrev:
1080p24???
24 frames.
Ja, 24 frames (48 fps output ville også være ok)
erla
Bruger siden: 29 Juli 2006
Sendt: 23 August 2006 kl. 00:07 | IP-adresse registreret
Otto, TC skrev:
wrong skrev:
1080p24???
24 frames.
Ikke fordi jeg på nogen måde vil korrekse dig, Otto - men måske er det interessant at vide hvorfor lige 24 frames, når man er vant til 25 / 50interlaced fields..:
24 frames, fordi film bliver optaget med 24 frames i sekundet - derfor har det faktisk ikke været helt nemt at scanne film til video, men vi har som brugere gennem 40-50 år vænnet os til den dårlige løsning (vi har jo heller ikke haft noget at sammenligne med).
Har ikke selv set 1080p24 endnu, men jeg tror ikke det kun er teoretisk feinschmeckeri, men er overbevidst om, at det faktisk vil gi' et super roligt billede - både pga. afskaffelsen af fields, men også fordi man ikke skal konvertere frameraten.
Otto - please correct me if I'm wrong ?
Til top Vis erla's Profil Søg efter andre indlæg skrevet af erla Besøg erla's Websted
erla
Sendt: 23 August 2006 kl. 00:13 | IP-adresse registreret
jdg1 skrev:
Otto, TC skrev:
wrong skrev:
1080p24???
24 frames.
Mener du 48 fields ?
Hvor vil ellers få de sidste frames fra - det er mig bekendt kun highspeed kameraer - der bruges til superslow ved sportsoptagelser - der kan optage mere end 25 frames, og de benyttes som sagt kun til sportsoptagelser med det formal at blive afviklet som 25fps video... findes der udstyr der kan afspille med højere framerate ? (bortset fra NTSC's 30fps, men det er en helt anden historie).
jdg1
Sendt: 23 August 2006 kl. 08:54 | IP-adresse registreret
erla skrev:
jdg1 skrev:
Otto, TC skrev:
wrong skrev:
1080p24???
24 frames.
Du gentager 2 frames pr. gang - 2:2 (nogle projektor/skærme kan ikke vise 24, men kan godt vise 48)
jdg1
Sendt: 23 August 2006 kl. 09:03 | IP-adresse registreret
erla skrev:
Otto, TC skrev:
wrong skrev:
1080p24???
24 frames.
Hej Erla - du er på rette spor
Pal film har været konverteret fra 24 fps til 25 fps med det "berygtede" Pal-speedup som følge. NTSC film har beholdt de 24 fps. men man har været nødsaget til at bruge 3:2 pulldown for, at opnå de nødvendige 60hz.
Flere scalere og skærme/projektorer understøtter nu afspilning ved 48 hz, dvs. at man med NTSC film undgår 3:2 pulldown og derved kan få et "judder-frit" billede. Lidt det samme som med 1080p24.
TapeConnection
Sendt: 23 August 2006 kl. 14:03 | IP-adresse registreret
Tænker du på forskel mellem HDMI vs. SDI, eller forskel mellem forskellige afspillere?
Mvh. TC
Side af 3 Næste >>
