Tilbage til HIFI4ALL.DK 10. juli 2026 | 12:14
Emne Emne: Bose Lifestyle 38 region free? (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
peb_si
Bruger siden: 07 Januar 2006
Sendt: 18 Maj 2007 kl. 14:17 | IP-adresse registreret
Hej forum
Har købt Bose Lifestyle 38 series III. Jeg har købt det i USA (region 1) og ønsker at gøre det regionsfrit. Hvordan gør man det og hvad koster det? Har kontakt til et enkelt firma der reparerer Bose i DK, men de vil have 1200 kr. Synes det er i overkanten -det må kunne gøres billigere?
Venligst
Peter
Til top Vis peb_si's Profil Søg efter andre indlæg skrevet af peb_si
EyeOfBeauty
Sendt: 18 Maj 2007 kl. 14:25 | IP-adresse registreret
Fra Google:
To convert this player to Multi-Region playback
1. Press the Right button on your remote control
NB: You may find that before performing this step, ensuring a Region 1 title is already in the player
2. Press the Up button on your remote control
3. Press the Shuffle button on your remote control
4. Press the Stop button on your remote control
5. Press the Mute button on your remote control
6. The disc tray should eject to confirm the region change
7. Press the Standby button on your remote control to power off your machine
8. After one minute, press the Standby button on your remote control to power on your machine
To set a specific region on this player after you have applied the above hack
1. Press the Stop button on your remote control
2. Press the Shuffle button on your remote control
3. Press the 1 button on your remote control for region 1, the 2 for region 2, and so on
4. Press the Enter button on your remote control
NB: This player supports resuming, and may take you back to the RCE region map screen after performing the above hack. Press the Stop button on your remote control twice, or if this is prohibited you may be required to insert 10 different discs to clear the resume buffer, or power off your player for a minute and perform the above procedure with a non-RCE disc in the machine.
Til top Vis EyeOfBeauty's Profil Søg efter andre indlæg skrevet af EyeOfBeauty
peb_si
Sendt: 20 Maj 2007 kl. 22:14 | IP-adresse registreret
Tak for det gode råd, men det virker desværre ikke. Ved ikke om det har noget at gøre med at mit er et "Series III". Det kan tænkes at dit forslag virker på "Series II".
Jeg håber, der er andre gode råd derude.
Venligst,
Peter
