Tilbage til HIFI4ALL.DK 12. juli 2026 | 08:53
Emne Emne: Ny Squeezecenter 7.3.1 (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
SoundMan
Bruger siden: 10 December 2005
Sendt: 25 December 2008 kl. 17:28 | IP-adresse registreret
Ja, så er der ny SC igen, denne gang ver. 7.3.1
Den kan downloades her.
7.3.1 Release Highlights (klippet fra SlimDevices, uden billeder):
Deezer
  • Improved support for playing the same music on Squeezebox players in multiple parts of your house -- "sync"
    • Improved synchronization and reliability of music streams from sync'd players
    • Sync Internet radio, music services or your music library
    • Adding/removing players for sync same on all players and Controller
    • No software limits on number of players in sync
    • Crossfade and gapless playback now supported during player sync
Amazon.com Purchase
  • Fast Forward or Rewind within a track or some streams
    • Track formats: WAV, MP3, FLAC, Ogg, Wavepack
    • Stream formats: HTTP/MP3, Rhapsody, MP3Tunes,
  • Support for Deezer Webradio and Smartradio in France, Germany, and United Kingdom
Extension Downloader
  • Buy a CD of the music you're listening to or browse the Amazon store and purchase CDs from Amazon using your Controller or Squeezebox. Available in Canada, France, Germany, United Kingdom, and the United States.
  • New Extension Downloader to simplify adding popular SqueezeCenter plugins
    • Go to Settings->Advanced in SqueezeCenter and choose Extension Downloader from drop-down menu.
    • The Extension Downloader can be redirected to third-party plugin repositories listed here.
    • NOTE: Don't forget to restart SqueezeCenter after installing a plugin.
  • First Logitech release for ReadyNAS Pro platform
  • Firmware versions
    • Squeezebox 2 and 3: 121
    • Transporter: 71
    • Receiver: 56
    • Boom: 41
    • Controller: 3476
  • New web skin optimized for use with screen readers
Squeezebox Player Support
  • Improved reliability of WMA streams
  • Turning off player also turns off digital outputs
  • "Can't find SqueezeCenter" message disappears after 30 seconds, leaving blank screen on SB2/3 and Transporter or display of current time on Boom
  • Factory Reset option (hold left arrow for firmware menu, Current Settings > Factory Reset)
  • Wake-on-LAN (WOL) sent to SqueezeCenter 10 minutes before alarm (Boom only)
  • Bass and treble controls now affect headphone output
  • New LINE OUT mode for Boom's "Headphone + SUB OUT" jack
    • Previous Modes
      • Headphone (Jack ON, Boom speakers OFF)
      • SUB OUT (Jack ON, Boom speakers ON with reduced bass)
    • New LINE OUT mode (No reduced bass)
      • Choose ON or OFF
      • Boom speakers always ON
  • Fixes loud and annoying chirp noise heard intermittently when playing Rhapsody tracks
Squeezebox Controller
  • Improved connectivity between Controller and SqueezeCenter
  • New Synchronization UI
  • Custom Wallpapers through SqueezeCenter
Controller as Player
  • Choose Player menu displays Player icons
  • Expanded System Information available through Controller
  • Artwork Size setting in Now Playing screensaver
  • Controller Audio Playback (Beta)
  • Playlist Mode/Party Mode (Beta)
More info in detailed 7.3 Squeezebox Controller Release Notes
Web User Interface
  • Now includes album artwork from your iTunes library
    • NOTE: SqueezeCenter will open iTunes while scanning the library for artwork. Please close iTunes once scanning has completed.
  • Faster scanning time for MusicIP
  • New LineOut plugin to control Boom "Headphone + SUB OUT" jack modes. Allows placement of Line Out menu item to Boom or SqueezeCenter Extras menu.
SqueezePlay
BETA SqueezePlay
SqueezePlay is a software-only Squeezebox player application for PC, Mac or Linux desktop. It performs all of the functions of a music player but does not require purchase of additional hardware. It can also control other Squeezebox players on your home network. It is a replacement for the SoftSqueeze application.
  • Currently SqueezePlay is available for SqueezeCenter 7.3 only. SqueezePlay will not work with older versions of SqueezeCenter or with SqueezeNetwork.
Ændringer fra 7.3 -> 7.3.1 (klippet fra SlimDevices):
Version 7.3.1
  • Firmware updates:
    • Boom - Version 41
      Squeezebox 2/3 - Version 121
      Transporter - Version 71
      Receiver - Version 56
      • #7814 - Glitches in some MP3 radio streams
      • #9003 - Occasional loud noises when moving to a new Rhapsody track
  • Bug Fixes:
    • #4578 - Accented characters in playlist entries don't rescan correctly
    • #5119 - Replay gain with positive gain setting can cause clipping
    • #8654 - Update to WavPack 4.50
    • #9553 - Track title metadata missing when track title contains ellipsis in cue file
    • #10009 - SC not able to read cyrillic-based name
    • #10053 - Random Mix favorites doesn't work from Controller
    • #10155 - Scanner does not find OGA files
    • #10293 - use custom-convert.conf instead of customized convert.conf on ReadyNAS
    • #10303 - WMA metadata is delayed too long
    • #10307 - build-perl-modules.pl DBD-mysql-3.002 calls wrong DBI version
    • #10315 - MusicIP Playlist names with non-ASCII characters need sanitizing on Windows
    • #10316 - MusicIP Mood names with non-ASCII characters need sanitizing on Windows
    • #10317 - Music Stores listed twice on new player
    • #10326 - Adding certain menu items to the player menu breaks the menu
    • #10331 - PrefSync from SN happens even if SN Integration is disabled in SC
    • #10334 - Typo in convert.conf for mov->mp3
    • #10379 - Pandora does not properly continue after an audio URL fails
    • #10388 - Change flac->flac to flac->wav or similar for flac/cue files on sparc based ReadyNAS
MVH Allan
Til top Vis SoundMan's Profil Søg efter andre indlæg skrevet af SoundMan
