Tilbage til HIFI4ALL.DK 10. juli 2026 | 14:24
Emne Emne: Hurtig DAC (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
David
Bruger siden: 06 Maj 2003
Sendt: 12 Februar 2009 kl. 17:11 | IP-adresse registreret
Faldte lige over denne tråd på diyaudio.com.
http://www.diyaudio.com/forums/showthread.php?s=&postid= 1742688#post1742688
Det ser ud til at hurtigs DAC er færdig.
Til top Vis David's Profil Søg efter andre indlæg skrevet af David Besøg David's Websted
phoeniks
Bruger siden: 19 Maj 2007
Sendt: 12 Februar 2009 kl. 17:33 | IP-adresse registreret
Langsom og knallerten tør ikke engang vise et diagram
/Brian
musik skal ses live - film skal høres i hjemmebioen
Til top Vis phoeniks's Profil Søg efter andre indlæg skrevet af phoeniks
Nilau
Sendt: 12 Februar 2009 kl. 20:05 | IP-adresse registreret
Ja, det er pinligt! En bruger skriver f.eks følgende til de dygtige danske designere...:
Hi KvK and Hurtig,
What I can conclude from this thread is that you guys designed nice peace of audio hardware. Later on you realized that low ground noise is the name of the game and absolute prerequisite to achieve high quality sound. In other words – no doubt that 5-6 years spent on this project has ripped benefits.
What I don’t understand is the intention of this thread:
We are all more or less aware of your findings that took you 5-6 years or R&D.
You can not really puzzle most of us by saying that you have a fantastic design.
If you don’t provide the circuit diagram and PCB layout, YOU and US are both at loss. We are both wasting time.
YOU are not going to receive our suggestions on improving your design (which you may or may not discard a priori – up to your egos…).
US will not learn absolutely anything from this thread.
This is DIY site – either share for mutual benefit, or make it commercial thru different channels.
Nogle 'sjove' fyre Kvk & Hurtig... De har slet ikke opdaget, at de er i et DIY-forum hvor man "deler" informationer til glæde for andre. Og det har da også medført en hel del syrlige bemærkninger og surhed fra andre brugere. De to 'sjove' fyre fører sig frem med tekniske banaliteter og selvhævdelse. Men holder derefter i øvrigt kortene tæt til kroppen... Munter læsning. De bliver nok banned på et tidspunkt? og
Niels
FinnC
Bruger siden: 21 Juli 2005
Sendt: 13 Februar 2009 kl. 11:15 | IP-adresse registreret
Det er da meget forståeligt, da der både findes mere end en (måske kommende) konkurrenter lige der, dernæst kan enhver lusker lige der hurtigt og skjult hugge ide og  grundlaget (overvejelser, test etc.), der kan tjenes lidt skillinger på. De er trods alt jyder og kender alt til at krejle
Jeg undrer mig mere at de gider.. de ved hvad de har gang i, og kan lave en DAC uden hjælp  - kan ikke et eneste sted i tråden se hvad deres formål er
Nogle drukner sig i problemer, andre tager sig en uddannelse, så de kan svømme imellem dem. [Mark Twain 1835-1910]
Til top Vis FinnC's Profil Søg efter andre indlæg skrevet af FinnC
phoeniks
Sendt: 13 Februar 2009 kl. 12:06 | IP-adresse registreret
så du mener altså ikke det er fordi de har "hugget" ideer, men fordi de har genopfundet den dybe - ske
/Brian
AM-E
Bruger siden: 26 Februar 2005
Sendt: 13 Februar 2009 kl. 12:19 | IP-adresse registreret
Opmærksomhed? De tror jo åbenbart, at de har revolutioneret audiobranchen med deres påfund. Bare ærgerligt at produktet lyder møghamrende ringe (efter flere personers udsagn).
Jean M Jarre
Lukket efter eget ønske!
Bruger siden: 03 Oktober 2004
Sendt: 13 Februar 2009 kl. 12:55 | IP-adresse registreret
Jeg vil starte med at sige jeg har ikke hørt denne DAC så kan ikke udtale mig om lyden, men går ud fra du heller ikke selv har hørt den.
Jeg har lige den modsatte information, flere jeg kender der har hørt den siger den er virkelig god, så jeg vil da forslå at inden du BRÆER op med andre siger den er dårlig, så tag sku da lige og tag over og hør den.
Tror der er flere der har farvet hørelse når snakken går på Hurtig og KVK, det er hvist ikke ørene de lytter med men deres holdninger.
JmJ
Det første kvinder bliver døve på er øjnene.
Verdens bedste kabel er det der kommer ind i huset med 230 volt, uden dette var der intet grej der spillede, så hermed er kabel diskutionen slut ;-)
Til top Vis Jean M Jarre's Profil Søg efter andre indlæg skrevet af Jean M Jarre
lars37
Bruger siden: 02 Maj 2003
Sendt: 13 Februar 2009 kl. 13:10 | IP-adresse registreret
JmJ
Enig JMJ, man hvis du læser den omtalte tråd igennem, så er det Knold og Tot, der endnu engang vil belære en masse mennesker (denne gang på et udenlandsk forum) om deres fortræffeligheder og ikke mindst om, hvordan lydkvalitet skal opfattes.
Det er sgu pinligt at være dansker....
Til top Vis lars37's Profil Søg efter andre indlæg skrevet af lars37
Jean M Jarre
Sendt: 13 Februar 2009 kl. 13:41 | IP-adresse registreret
JmJ
Hvad de skriver i tråden på DIY forummet er for mig ligegyldigt, jeg kommenterer kun det at man kritiserer et produkt man ikke har hørt, og kun har udtagelser fra anden hånd.
Generelt her på Hifi4all er der jo grupperinger, hvilket gør at folk ikke altid er objektive og det er bare trælst at blive ved med at se/læse.
JMJ
Nilau
Sendt: 13 Februar 2009 kl. 13:42 | IP-adresse registreret
JmJ
Ja, meget pinligt.
De to herrer undgår behændigt at svare på HVORFOR de er på omtalte DIY-forum, når de ikke vil ud med væsentlige oplysninger om deres dac. Ét sted skriver de, at forummets brugere alligevel ikke ville kunne forstå det, hvis de svarede på noget. Det er for kompliceret for forummets brugere! Så har man ligesom fået p***et på samtlige brugere!
I øvrigt har jeg hørt Hurtigs DAC, og det var ingen fornøjelse skulle jeg hilse og sige... Man må da håber at der siden er sket en totalt gennemgribende finpudsning af apparatet! ;-)
Niels
Nilau
Sendt: 13 Februar 2009 kl. 13:46 | IP-adresse registreret
JMJ
Det er ellers trådens emne!
N.
ulrikmm
Bruger siden: 09 Maj 2005
Sendt: 13 Februar 2009 kl. 14:26 | IP-adresse registreret
Hej AM-E:
DACen blev først færdig i denne uge. Mon ikke du hvad 2. håndslytteindtryk angår forveksler med den flere år gamle første
udgave af DACen?
Mvh Ulrikmm
AM-E
Sendt: 13 Februar 2009 kl. 15:17 | IP-adresse registreret
ulrikmm skrev:
Hej AM-E:
udgave af DACen?
Mvh Ulrikmm
Ulrik, jo det har du fuldstændig ret i. Det må du undskylde. Men selv da modellen var på beta-stadie, ville de to personer ikke anderkende at majoriteten ikke gav meget for, hvordan den lød. Vi havde ikke mandat til, at bedømme hvad der var godt eller skidt. Kort sagt: Vi aner ikke en skid om elektronik, PCB og SMD osv. og den slags selvhøjtidelig snak (men det var jo også lyden, som skulle bedømmes eller??)....
Mastervol
Bruger siden: 02 August 2005
Sendt: 13 Februar 2009 kl. 18:47 | IP-adresse registreret
Det her er personfnidder og har intet med selve DAC'en at gøre, derfor lukkes tråden.
