Tilbage til HIFI4ALL.DK 14. juni 2026 | 16:54
Emne Emne: Rep. af kantophæng, En Guide. (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
edge
Edge Audio Solutions
Bruger siden: 21 Februar 2009
Sendt: 27 September 2009 kl. 23:11 | IP-adresse registreret
Da jeg syntes et seriøst forum som dette ikke kan tillade sig ikke at have en Guide i hvordan man reparere ophæng på sine elskede enheder i ens lækre højtalere, vil jeg beskrive hvordan jeg laver enhederne i mine højt elskede Infinity Reference 60.
The pictorial image of Reference 60
The speaker system of the Tallboy type which adopted the double Woofer drive scheme.
A 20.3cm cone type unit is adopted as low-pass.
Polypropylene and a high rigidity graphite fiber are combined with a diaphragm material, and the IMG (Injection Molded Graphite) cone which raised a moderate internal loss and intensity is adopted.
A 12.7cm IMG cone type unit is adopted as the mid range.
The IMG cone adopted as the mid range chose the mixed ratio of polypropylene and a graphite fiber, and has attained high rigidity by the low-mass.
Furthermore, the dust cap which strengthens rigidity is adopted as the cone center which a physical stress concentrates.
The EMIT-R type unit which improved the EMIT type tweeter by a technology original with Infiniti is adopted as the high region.
A planar diaphragm 3cm in diameter is adopted, and the Tran Gent property, low distortion, and wide-range play which are the special features that an EMIT type tweeter is big are realized.
It is attached in two gilding input terminals corresponding to by amplifier, and the metals foot of the letter of a spike is attached.
Højtalerene er fra 1993 og har spillet fantastisk i 12år, indtil ophængene gav op hvorefter de blev stillet til side til en dag hvor pengene sad løst igen. det skete bare aldrig for min bror hvis højtalere det var oprindeligt, og jeg købte dem af ham for at Refoame dem.
Enhederne er lidt anderledes i disse højtalere, da membranen er lavet af Polykarbonat (en slags plastik) og Grafit fiber, så de er lidt nemmere at gå til med en refoaming end enheder med papmembran (fremgangsmåden er dog næsten den samme).
Skumkanterne hang i laser, så det eneste jeg har gjort, udover at skrue den ud af kabinettet, er at støvsuge resterne op.
På enheden her er en pyntekant af plast, den er man nødt til at fjerne da den nye skumkant limmes på fladen i chassiet af enheden under plastkanten. Det gøres lettest med en smørkniv, den ridser/skærer ikke i plastkanten og er robust nok til at den kan holde til arbejdet. Sørg for at komme helt ud til kanten af chassiet (kanten ses på næste billede af enheden) da plastkanten er limet helt ude ved denne kant. Der kan være alle mulige slags pyntekanter på enheder, pap, skum osv. Pap og skum fjernes med hobbykniv, skær den forsigtigt af da den skal bruges igen.
Værktøj. Fra en ende af: klud, skruetrækker, hobbykniv, japanspartel, sandpapir, vatpinde, smørkniv, 3M
Scotch-Brite og pensel.
Der udover Deminiraliseret vand og Acetone.
Enheden ser nu sådan ud, kanten jeg snakkede om er den helt yderst. Alt hvad der er af limrester skal renses af så der laves en ren flade for limen til den nye skumkant at hæfte på.
Vi starter med membranen, jeg bruger hobbykniven men jeg bruger enden af klingen, jeg har osse rundet hjørnet på klingen med sandpapir for ikke at lave ridser i membranen.
Skumresterne er nu væk, men limresterne er der stadigvæk og her kan jeg tillade mig at bruge Acetone, fordi membranen er i plast. Jeg vil ikke anbefale det til papmembraner. Husk at nutralisere Acetonen med vand (for en sikkerheds skyld).
Så gælder det resterne af skumkanten på chassiet, det grove tages med hobbykniven.
Limresterne kan tages med et stemmejern, gør det dog kun hvis du ved hvordan det skal slibes igen.
Resten af limresterne slibes væk med sandpapir/ 3M Scotch-Brite.
Enheden er nu klar til det nye skumophæng. der er dog en ting vi mangler...
Plast pyntekanten skal osse lige renses for limrester.
Hilsen Flemming
EAS will rise again...
Til top Vis edge's Profil Søg efter andre indlæg skrevet af edge Besøg edge's Websted
edge
Sendt: 27 September 2009 kl. 23:14 | IP-adresse registreret
Så er der kommet Skumophæng hjem, og jeg kan  fortsætte. Ligesom til afrensning af enheden skal der bruges noget værktøj:
Foruden skumophæng og lim, Acetone, pensel, tusch, vatpinde og skruer til enheden.
9V batteri med krokodillenæb og højtlerlednng med krokodillenæb og 3,5mm jackstik.
Jeg har tapet et søm på tuschen, så den danner en sat afstand, så det er til at mærke membranen op ens hele vejen rundt
Så er det nemt....
Så skal der limmes, pensel limen på tyndt både på membranen og skumkanten
Når limen er halvt klar, halvt hvid, og er let klistret er det tid til at sætte de to sammen
Måden jeg centrere på er ved at trykke bælgen på skumkanten ned så jeg kan se kanten på membranen under skumkanten.
Når limen er klar hele vejen rundt langs kanten af skumkanten, kan den fjernes med en hobbykniv, en lille skruetrækker eller andet. Vent ikke til limen er helt tør, da den da er næsten umulig at fjerne uden at ødelægge membranen.
Når limen på membranen er helt tør, kan jeg limme skumkanten til chassiet/kurven af enheden. Her bruger jeg 9V batteriet til at centrere membranen i spolegabet, og sætter derefter 4 tøjklemmer på kryds på kanten af skumkanten.
Test om membranen er fri af spolegabet ved at trykke ned på membranen, er den det høres ingen skrabelyde når man trykker. Så kan der limmes mellem klemmerne, på både skumkant og kurv. Jeg limmer mellem klemmerne og flytter derefter klemmerne og limmer der hvor de sad.
Så sættes der en masser klemmer på for at holde membranen mens den tørrer. Nu sætter jeg enheden til min computer og bruger en sinustone på 40HZ til at centrere spideren, og sikre at membranen har fuld bevægelighed.
Når limen er tør, er enheden færdig og alt der mangler er at limme pyntekanten på igen. Jeg bruger sort Silicone på tube, fordi det er nemt at fjene igen hvis det skulle ske om 10-15år det er tid til at refoame igen.
Hilsen Flemming
jesper olsen
Bruger siden: 09 Oktober 2004
Sendt: 27 September 2009 kl. 23:37 | IP-adresse registreret
Fed guide. Her følger jeg med.
Har selv en del enheder liggene der mangler re-coaning.
Hilsen
Jesper
Til top Vis jesper olsen's Profil Søg efter andre indlæg skrevet af jesper olsen
santashooter
Bruger siden: 08 Januar 2008
Sendt: 28 September 2009 kl. 01:05 | IP-adresse registreret
Hilsen
hvis de mangler at blive recoanet, kan du ikke følge guiden ovenfor, da du her, skal isætte helt ny membran, spider og spole...
hvis det derimod er ophænget den er gal med (en såkalt re-foaming) er det her guiden du skal følge...
Mit setup
Til top Vis santashooter's Profil Søg efter andre indlæg skrevet af santashooter
anse
Bruger siden: 05 Januar 2009
Sendt: 28 September 2009 kl. 01:34 | IP-adresse registreret
Lækker gennemgang.
vh.
Anders
erlingt
Sendt: 28 September 2009 kl. 09:44 | IP-adresse registreret
Meget fin gennemgang - jeg har også nogle enheder liggende, som skal have nye kanter. Så lidt "hint & tips" er jo altid dejligt at få med.
Hvor køber du dine nye kanter?
Cesse
Bruger siden: 25 Juni 2008
Sendt: 28 September 2009 kl. 10:34 | IP-adresse registreret
Så lærte vi også noget idag...
Hilsen
Hilsen Cesse ;)
Nakamichi og DIY
madsen
Bruger siden: 02 April 2003
Sendt: 28 September 2009 kl. 11:26 | IP-adresse registreret
Rigtigt godt indlæg, har selv gjort det en del gange, men man kan altid lære nyt.
Til orientering er der en udmærket vejledning HIGHfidelity nr. 5 side 78 2009, det eneste irriterende er at de danske forhandlere ikke er så "glade" for at sælge kantophæng, jeg har dog kunnet købe hos AT Højtalerværksted i Sdr. Borre, hvor har du bestilt de nye ophæng.
VH. Madsen
Nyd musikken, glæd dig over teknikken
Til top Vis madsen's Profil Søg efter andre indlæg skrevet af madsen
santashooter
Sendt: 28 September 2009 kl. 13:21 | IP-adresse registreret
jeg køber tit kits fra USA... helst nogle der er lavet specifikt til enheden...
(ebay)
jeg er spændt på at se, hvilken fremgangsmåde du benytter når du skal have kanter på, der bruger jeg altid et lille batteri for
at centrerer det hele imens så monterer jeg på membranen først.
det virker bare, og så bruger jeg en sinustone når den tørrer, så den svinger imellem plus og minus, og på den måde får jeg
centreret spideren også...
mvh.
Søren
Mit setup
edge
Sendt: 28 September 2009 kl. 16:28 | IP-adresse registreret
Jeg har købt hos Audiofriends. nl http://www.audiofriends.nl/foam-surrounds/
Sendte dem en mail om hvilke højtalere jeg manglede kanter til (sendte et par billeder med for en sikkerheds skyld) Og de svarede med uforpligtende tilbud, 42 Euro for ophæng til 6 enheder (skal skifte mellemtoner osse) lim 4 tuber, men man betaler kun for en. Så for Ca. 350kr får disse højtalere liv igen.
Jeg har osse tænkt mig metoden med batteri og sinustone, så ved man enheden er centreret og har fuld bevægelighed.
Hilsen Flemming
madsen
Sendt: 28 September 2009 kl. 16:42 | IP-adresse registreret
Smart måde til centrering, jeg limer først ophænget på membranen, lader det tørre, sætter så enheden så den står 100% vandret, bevæger så membranen frem - tilbage og venstre - højre sætter et mærke i alle yderpositioner og placerer derefter ophænget imellem disse, fikserer med en klemme tjekker derefter og limer.
VH Madsen
BoPtiljudrop
Bruger siden: 24 Januar 2009
Lokalitet: Fyn Syd
Sendt: 28 September 2009 kl. 17:20 | IP-adresse registreret
Top notch guide. Jeg fyrer straks et link til én der aktuelt står med problemet.
Et "nuldregummi" kan være en god hjælp. Det er blot en stump ægte rågummi, det kan nuldre limen af, dog ikke så anvendeligt på membran.
Til top Vis BoPtiljudrop's Profil Søg efter andre indlæg skrevet af BoPtiljudrop
X-ray
Bruger siden: 04 Marts 2008
Sendt: 28 September 2009 kl. 17:28 | IP-adresse registreret
Vil blot tilføje, at et eller andet sted i Tante Berg's Tandberg-tråd - ligelides er en ret fin guide i "refoaming / reconing" - hedder det vistnok. Som jeg husker det, var der nogle meget fine billeder - samt nogle "FIF" jeg ikke har set nævnt her. Det ligger langt tilbage - og mine søge-færdigheder er usle - måske en Guide i SØG ville være populær. Så jeg kan desværre ikke link'e til noget - men prøv selv at søg lidt.... .
angute
Bruger siden: 27 Maj 2008
Sendt: 28 September 2009 kl. 22:45 | IP-adresse registreret
Der er noget her
Til top Vis angute's Profil Søg efter andre indlæg skrevet af angute
edge
Sendt: 10 Oktober 2009 kl. 16:40 | IP-adresse registreret
Så er der opdateret!
Hilsen Flemming
tonykart007
Forever!
Bruger siden: 23 Januar 2009
Sendt: 10 Oktober 2009 kl. 16:50 | IP-adresse registreret
hvor finder man en mellemtone til ovennævnte ht
Til top Vis tonykart007's Profil Søg efter andre indlæg skrevet af tonykart007
edge
Sendt: 10 Oktober 2009 kl. 16:54 | IP-adresse registreret
Det bliver svært, da de ikke laves mere. Men erstatnings enheder kan bruges, endda enheder der er bedre end den orginale
Hilsen Flemming
tonykart007
Forever!
Sendt: 10 Oktober 2009 kl. 16:56 | IP-adresse registreret
oki har nemlig et sæt infinity reference der står stille på grund af mellemtonerne
edge
Sendt: 10 Oktober 2009 kl. 17:05 | IP-adresse registreret
Jeg har overvejet at modde mine med disse:
http://www.monacor.dk/produkter/hoejttalerenheder-hifi4-5/vn r/102410/
Hilsen Flemming
tonykart007
Forever!
Sendt: 10 Oktober 2009 kl. 17:08 | IP-adresse registreret
Har du data på de originale
