Tilbage til HIFI4ALL.DK 13. juni 2026 | 23:30
Emne Emne: DTQWT - design by Troels Gravesen (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
deepseas
Bruger siden: 14 Oktober 2009
Sendt: 16 November 2009 kl. 20:28 | IP-adresse registreret
På opfordring dette indlæg om et 14-dages DYI-byggeprojekt.
Da jeg tidligere har bygget højtalere selv (F3/LYD's satellitter) - og gerne sparer lidt på lønudbetalingerne besluttede jeg efter nogen overvejelse at bygge et par af Troels Gravesens DTQWTer.
Vender tilbage med mere tekst og fotos ASAP.....
Vh.
Peter
Til top Vis deepseas's Profil Søg efter andre indlæg skrevet af deepseas
deepseas
Sendt: 16 November 2009 kl. 20:31 | IP-adresse registreret
Til indledning lidt fra min blog (på Engelsk):
So after at lot of investigations and many thoughts I’m going to build my own High Fidelity loudspeakers, following the DIY (Do It Yourself) path from the F3/Lyd loudspeakers I made back in the 80ties.
On the path to the decision I have been listening to 3 different B&W (Bower and Wilkins) loudspeakers in the shop HiFi-klubben in Elsinore. The CM07, XT8 and 804S, speakers in the price range from DKK 6.000 to 15.000 each. B&W are a very serious loudspeaker firm manufacturing reference speakers to studios and other high-end business. The top speaker costs a stunning DKK 72.300. There were no doubt in my mind, the 804S were the better of these, but I’m not ready to pay DKK 30.000 for a pair of speakers at this time, though they sound brilliant, with well defined sound in the mid- and high-range, and also plays a fairly solid bass.
The DTQWT are designed by Troels Gravesen in 2008 and are, in his own words, the best speaker to date. Troels have been experimenting and developing speakers for several years and have an impressive range of speakers behind him, based on his informative website I would guess Troels have made at least 30 speakers to date. The DTQWT are not a small speaker with a volume on almost 150 l. and two 10” bass units. The bass units are mounted in the back of the cabinet, and on the front there’s a tweeter and an 8” midrange unit. The midrange speaker JA8008 developed also by Troels in collaboration with SEAS, a well renowned Norwegian loudspeaker manufacture.
So based on specifications and drawings on Troels website in will take on this project, the cabinet are not easy to build and I will need all my handicraft skills in the process, but this is a very important part of the process, and I’m looking forward to this. I expect, based on the quality, feedback from users around the world and expenses going in this project that the DTQWT overall will play far better than the B&W 804S.
I might tweak the dimensions on the cabinet to reduce the depth of the cabinet a bit. I have been emailing Troels a few time, and he was kind enough to reply and comment on my questions about the DTQWT and also on some alternative baffle speakers projects I have been looking at. So I want to thank Troels for sharing his design and skills, and also for his time answering my questions.
anse
Bruger siden: 05 Januar 2009
Sendt: 16 November 2009 kl. 20:48 | IP-adresse registreret
Tror de er et rigtigt godt valg.
Jeg tænker at bygge den lille TQWTér, den uden de to 10".
Er ret sikke på det er en højtaler som sparker røv på den gode måde.
God byggelyst, vil følge dit projekt.
vh.
Anders
deepseas
Sendt: 16 November 2009 kl. 20:54 | IP-adresse registreret
vh.
Anders
Hej Anders - tak i lige måde.
En fordel ved TQWTerne er at de kan opgraderes til DTQWT senere, delefilter, twetter og mellemtone/bas er de samme....
Vh.
Peter
Bull
Bruger siden: 10 November 2009
Sendt: 16 November 2009 kl. 21:14 | IP-adresse registreret
Glæder mig til at følge med på sidelinien her.
Er sikker på at det er en ren vinder.
God byggelyst
Til top Vis Bull's Profil Søg efter andre indlæg skrevet af Bull
deepseas
Sendt: 16 November 2009 kl. 21:18 | IP-adresse registreret
Så efter et besøg i den lokale STARK har jeg hjembragt 2 stk 19 mm. MDF-plader og 1 stk. 6 mm. MDF.
Troels' kogebog (http://www.troelsgravesen.dk/JA8008_DTQWT_cabs.htm) foreskriver 19, 22 og 30 mm. MDF. 19 mm. til sider, top og bund, 22 mm. til bagplade og 30 mm. til front. Med de 19+6 kan jeg nå op på 25 mm. til front og bagplade, uden at skulle købe en hel plade i 30 mm.
Tanken var at lakere kabinetterne, men undervejs besluttede jeg at jeg ønskede en mere professionel  finish. Så på med traileren igen og over til STRAK efter to plader birke-krydsfiner i 4 mm. Så med de 19+6+4 mm. når jeg op 29 mm. til front og bagplade, en lidt tykkere bagplade end kogebogens anvisninger - men det er kun til det bedre, og jeg har sikret at det indvendige volumen svarer til tegningerne (147 liter).
Jeg havde nået at starte på at fræse ud til de to 10" basenheder i den ene bagplade; men en nogenlunde opmåling  af centerplaceringen på cirkelslagene, og en udfræsning med en Ø15 mm. cylindrisk fræser i brikefineren sikre at jeg kunne fange de oprindelige centerhuller for mit hjemmelavede land til overfræseren (købt hos Harald Nyborg). Hullerne er Ø260 mm. i diameter, og en cylindrisk fræser på Ø15 mm. (som fulgte med overfræseren) passer med den indvendige diameter på Ø230 mm. som de 2 stk. 10" EMINIENCE basenheder behøver.... en udfræsning med en dybde på 19 mm. i diameter Ø260 mm. sikrer at enhederne flugter smukt plant med bagpladen, og giver samtidigt 10 mm. gods til at fastspænde enhederne i.
En betydelig fordel ved at bygge i MDF-plader, og efterfølgende pålime birkefiner er at kabinettet kan skrues sammen med træskruer som holder til den hvide snedkerlim er tør.
For at få et pænt resultet skal for- og bagplade dog pålimes krydsfiner inden udfræsningen til enhederne. Husk en frisk fræser giver det bedste resultat, finer er såbar og flænser meget i let i kanterne - de 4 mm. består af 5 individuelle lag.
Bagpladen har de 19 mm. inderst og som går indenfor siderne, og derpå 6 mm. MDF og 4 mm. birke krydsfiner, som rager udenfor siderne, dette giver bedre styrke.
Troels Gravesen har udført sine kabinetter i 18 og 22 mm. "massiv" birke krydsfiner.
Der gik lidt mere end en uge fra jeg havde bestilt og overført betaling for komponenter til delefilter, diskant, mellemtone, waveguide mv. til JANTZEN Audio. Varerne kommer med GLS fra Polen, og jeg sørgede for at de blev leveret på min arbejdsplads, idet GLS er et erhvers fragtfirma, og ikke tillader at du kan afhente pakken på det nærmeste pakkeposthus his du ikke er hjemme. Desværre manglede der 2 stk.modstande ved leveringe. JANTZEN påstår det er første gang dette er sket, nuvel jeg fik de forsvundne modstande i et anbefalet brev et par dage efter....
Udover MDF-pladerne og 4 stk. 10" basenheder (DELTALITE II 2510) skal du købe følgende:
Filt, MDM-3, loddetin, sorte skruer og kabelsko til enhederne og de 2x2 stk. medfølgende højtalerstik. Hvis du vil køre basenhederne i en bi-amp konfiguration mangler du 2x2 stik.
deepseas
Sendt: 16 November 2009 kl. 21:45 | IP-adresse registreret
Forslag til leverandører:
Sorte skruer til enhederne og MDM-3:
http://frequence-shop.dk/produkter/35-diverse/
Spadesko: 4 stk. 6,3 mm. til højtalerstik, 4 stk. 4,8 mm. til mellemtone og 4 stk. 2,8 mm. til diskanter (skal udvides lidt med en tynd flad skruetrækker for at kunne nå over de lidt tykke udtag):
http://frequence-shop.dk/produkter/38-terminaler-amp-stik/
Loddetin:
http://frequence-shop.dk/produkter/11-lodde-udstyr/
Jeg købte i øvrigt også noget krympe-fleks og noget højtalerkabel hos Frequence.
Filt (10 mm. tyk) til at beklæde indvendigt finder du billigst har CARSOUND, kan købes i metermål, køb 2 meter (DKK 99,00/m.):
http://www.carsound.dk/kategori.asp?id=1025&pk=43
Spikes eller fødder da kabinetterne skal 30-40 mm. fri af gulv: Uafklaret
Bull
Sendt: 16 November 2009 kl. 22:05 | IP-adresse registreret
Harald Nyborg har billigt filt + Bitumen
deepseas
Sendt: 16 November 2009 kl. 22:50 | IP-adresse registreret
Hej Bull - tak
..og billigt er?
Bull
Sendt: 16 November 2009 kl. 23:51 | IP-adresse registreret
Hej deepseas
Bitumen (lyddæmpningspap) best.nr 1389 4 stk. a 400x500x4mm 169,-
kan ikke finde filten på deres hjemmeside men kan huske det var billigt og befandt sig lige ved siden af bitumen som var ved bilartikler.
Hvis jeg for tid i morgen køre jeg ind til HN og ser
m@dsen
Sendt: 17 November 2009 kl. 09:08 | IP-adresse registreret
Thansen har også begge dele til rimelige priser.
m@dsen
Bull
Sendt: 17 November 2009 kl. 17:18 | IP-adresse registreret
Hej deepseas
var forbi Harald Nyborg i dag var moske ikke så meget billigere prisen var 89,50,-
for 1080x1300x7mm. navn lyddæmpningsfilt best. nr. 05486
BrAvO
Bruger siden: 22 April 2004
Sendt: 22 November 2009 kl. 22:16 | IP-adresse registreret
Det her lyder spændende
Kom med nogle billeder...
Til top Vis BrAvO's Profil Søg efter andre indlæg skrevet af BrAvO
anse
Sendt: 10 December 2009 kl. 20:56 | IP-adresse registreret
Er du gået i stå eller hvad?
vh.
Anders
janils
Pladespilleren.dk
Bruger siden: 02 Januar 2004
Sendt: 10 December 2009 kl. 22:03 | IP-adresse registreret
Hvor er billederne?  ...... uden billeder, ingen DIY!
Jan Nielsen
Holger4
Bruger siden: 28 Februar 2006
Sendt: 11 December 2009 kl. 22:27 | IP-adresse registreret
Ja, hov, hvor er billederne? Billeder af mit DIY-projekt
*Membranareal does the job - små højttalere er KUN i vejen*
Til top Vis Holger4's Profil Søg efter andre indlæg skrevet af Holger4
ASML
Sendt: 12 December 2009 kl. 00:37 | IP-adresse registreret
Ja hvor er billederne ? Eller du skal måske lige have bygget et kamera først?
Til top Vis ASML's Profil Søg efter andre indlæg skrevet af ASML
deepseas
Sendt: 12 December 2009 kl. 22:13 | IP-adresse registreret
vh.
Anders
Nope - så færdig at de er spillet til ; men jeg har købt en SONOS pakke - og har været væk siden.... Genialt (SONOS).
Fotos:
http://www.flickr.com/photos/dtqwt/sets/72157622863061835/
SONOS:
http://www.sonos.com/howitworks/
Bent L
Bruger siden: 12 Maj 2004
Sendt: 13 December 2009 kl. 00:41 | IP-adresse registreret
Hej Deepseas, hvad måtte du give for ht. kittet?
Hilsen Bent
Til top Vis Bent L's Profil Søg efter andre indlæg skrevet af Bent L
janils
Pladespilleren.dk
Sendt: 13 December 2009 kl. 00:51 | IP-adresse registreret
Jeg kan stadig ikke se nogen billeder? ....
Jan Nielsen
