Tilbage til HIFI4ALL.DK 5. juli 2026 | 02:55
Emne Emne: vifa (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
lille_smed
Bruger siden: 08 Januar 2007
Sendt: 03 April 2008 kl. 20:34 | IP-adresse registreret
hejsa
 kender i denne enhed fra vifa ..
 hvordan spiller den --??
MG22WO09-08 - 8" Woofer Discontinued
Ask a question about MG22WO09-08 - 8" Woofer Discontinued
Ask a question
Code No. 7236745
Click to enlarge
MG22WO09-08 -
Click to enlarge
! 2 PIECES ON STOCK - PLEASE CONTACT US !
8 ohm version of MG22WO09-04
Magnesium basket
Glass fibre cone
The MG series is one of several new lines that take Vifa engineering one step further. The MG line combines new diaphragm materials, heavy-duty frames, and excellent build quality to produce very attractive results, both cosmetically and sonically. The MG series woofers feature yellow woven glass fiber cones, damped black dustcaps, diecast magnesium baskets, NRSC cone geometry, and low-damping rubber surrounds. The result is a quick and accurate woofer that delivers authoritative bass and outstanding midrange performance.
Nominal impedance : 8 ohm
Characteristic sensitivity (2.83V / 1m) : 88.5 dB
Recommended frequency range : 20 - 3000 Hz
Free air resonance frequency, fs : 21 Hz
DC resistance, Re : 5.5 ohm
Voice coil inductance, Le : 1.05 mH
Effective piston area, Sd : 235 cm²
Moving mass incl. air, md : 29 g
Force factor, BL : 8.85 Tm
Equivalent volume, Vas : 154 ltr.
Mechanical Q-factor, Qms : 1.60
Electrical Q-factor, Qes : 0.27
Total Q-factor, Qts : 0.23
Voice coil diameter : 40 mm
[Download datasheet]
USXX
Lukket efter eget ønske!
Sendt: 05 April 2008 kl. 15:20 | IP-adresse registreret
Køb dem! De produceres ikke mere. MG-serien blev lagt på hylden, da den ikke solgte så godt. PL-serien var langt mere populær. Det må skyldes udseendet, for MG-serien var lydmæssigt og teknisk overlegen.
Til top Vis USXX's Profil Søg efter andre indlæg skrevet af USXX
lille_smed
Sendt: 05 April 2008 kl. 22:04 | IP-adresse registreret
hej..
 jeg ved ikke om denne enhed kan det jeg vil bruge den til .. vil bruge den i dipol .. den skal spiller fra  120 hz gerne til 2500- 3000 hz.. men det er jeg ikke sikker på at  den kan
mollecon
Sendt: 07 April 2008 kl. 00:59 | IP-adresse registreret
Mange her ville sige, at 2,5 - 3 kHz er lovlig højt for en 8" enhed. men det er forsøget værd. Den skulle kunne fungere fra 120 Hz og op, trods den lave Qt-værdi.
jenson
Bruger siden: 28 Februar 2007
Sendt: 07 April 2008 kl. 10:23 | IP-adresse registreret
Det er en fin 8", men jeg ville også passe på med at bruge den for højt i frekvens, ikke højer en 2,5Khz vil jeg mene. Enheden er kun discontinued for private, OEM kunder kan stadig få den, også med en i mine øjne en noget pænere sort glasfiber menbran.
Til top Vis jenson's Profil Søg efter andre indlæg skrevet af jenson
lille_smed
Sendt: 07 April 2008 kl. 19:06 | IP-adresse registreret
tak .. for jeres svar .. jeg søger den også i sort .. men hvis man skal vælge imellem peeless hds ... og vifa ... hvad vil i så sige ... eller har i et anden forslag til en enhed som kan gå højt på .. og spiller rent ...
 den skal spiller sammen med scanspeak r2904 samt 12m
mollecon
Sendt: 07 April 2008 kl. 21:17 | IP-adresse registreret
Jamen, det er umuligt at sige, medmindre man kender de enkelte enheder..
lille_smed
Sendt: 07 April 2008 kl. 21:56 | IP-adresse registreret
disse enheder
http://www.tymphany.com/r2904-700000
http://www.tymphany.com/12m-4831g00
Diamagnetic
Bruger siden: 24 Januar 2007
Sendt: 07 April 2008 kl. 22:02 | IP-adresse registreret
Mon ikke den 12 m kan nå noget længere ned end til 2500hz.
musicus
Sendt: 07 April 2008 kl. 22:24 | IP-adresse registreret
Hvad med at prøve en 12" wideband til  27 EUR
Hvis den er ok, kunne det være værd at forsøge med 2.5vejs jeg ville nok forsøge at bruge en lille Fostex fuldtone som diskant
http://www.spectrumaudio.de/   søg efter SENON
lille_smed
Sendt: 08 April 2008 kl. 16:08 | IP-adresse registreret
jo da det ved jeg godt at den kan .. men den har ikke så stor åbning på bagsiden .. så ved ikke om det kan give nogle problemer .. vil gerne beskytte den lidt .. så den ikke skal spiller så langt ned
Diamagnetic
Sendt: 08 April 2008 kl. 16:16 | IP-adresse registreret
Du kan da roligt lade den gå ned til 700HZ
lille_smed
Sendt: 08 April 2008 kl. 17:52 | IP-adresse registreret
tak for alle jeres indlæg..
jeg spiller med den ned til 500 nu .. syntes ikke lige det er sagen .. vil gerne hvis det kan var en enhed som skulle spiller fra 120hz til 2500 .. for at slipper for deling mere ... ..
 men er der nogen som kan sige om der er sort lyd forskel på vifa fra for peerless hds  8"
Diamagnetic
Sendt: 08 April 2008 kl. 17:55 | IP-adresse registreret
Min erfaring er at vifas enheder er bedre end såvel Peerless som Scanspeak.
Groove
Bruger siden: 05 Marts 2004
Sendt: 10 April 2008 kl. 22:09 | IP-adresse registreret
lille_smed skrev:
hejsa
Ask a question
Code No. 7236745
Click to enlarge
MG22WO09-08 -
Click to enlarge
Magnesium basket
Glass fibre cone
Den kan bestemt anbefales også i tovejs, med en waveguided diskant.....det er virkelig en kvalitetsenhed....
lille_smed
Sendt: 11 April 2008 kl. 18:01 | IP-adresse registreret
hej .. det var godt .. har også lige købt den ...
super go behandling  man får ved dansk audio teknik ... (http://www.danskaudioteknik.dk/)
 jeg er også spændt på at høre den i mit dipol setup .. sammen med en peerless xxls !2"
