Tilbage til HIFI4ALL.DK 28. juni 2026 | 08:33
Emne Emne: Audiovector S3 sound quality problem (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
gojko
Bruger siden: 28 December 2006
Sendt: 08 September 2011 kl. 12:28 | IP-adresse registreret
Hi all,
First, sorry for writing in English, it is a bit easier that doing it in Danish:). If you'd like to contribute to the discussion (if there is any) please feel free to do so in Danish, google translate does wonders:).
I've been an owner of the AV S3 (not Si3) basic model for some months now. Some doubts about its sound quality have been piling up so I did some measurements. I tried first the Audiovector forum but that place is far from being lively and it seems that the AV stuff state that they avoid talking about graphs as the interpretation can be misleading so no response from them to my post. The hifi4all forum seems to be a much better place for a discussion:).
My initial complaint was about the treble and bass, or lack thereof. In general, the sound at normal listening level (I erroneously played things quite loud in the store where I was listening to speakers) lacks punch, is laid back, lacking details. It seems that there is too much mid range. The rest of the equipment is Cambridge Audio 550A amplifier, Thule CD150B CD player, non branded speaker cables (2m long, quite thick). The listening room was, at the time, around 8.3x4.3m. The intention was to divide the room and I didn't go for measurements before that was done. Now that the listening room is around 5.3x4.3m I did some measurements. I will here combine my two post on the measurement that I had posted on the AV forum.
The room is 4.3x5.3x2.5m. The distance between the speakers is around 2.5m, the listening distance from the mid point is around 4m, the toe in is around 4deg. The distance from the wall to the front of the speakers is 65cm (and can't be increased). The microphone (half inch pressure field) and the mic power supply are B&K, I would need to see the exact models if anyone is interested. WInMLS was used for the response measurement, the stimulus was a sine sweep. The measurement was not super precise but I believe it is good enough to point to any obvious problems. The magnitude responses of the right and the left speaker are at: Audiovector S3 room response.
The graphs are smoothed in 1/6octave bands. At low frequencies I can see mainly room modes as measured in the listening position, but it seems to me that there is not much output below 60Hz. Do not know how to interpret the mid and upper mid frequencies due to room interference, but it seems that there is a dip at around 3kHz in the speaker response. In my original post I complained about lack of details in the highs, actually as if the highs are missing quantity wise. My measurement shows that the tweeter starts to roll off already after 12kHz. It is the same on both speakers so it is unlikely that it is a malfunction.
The measurement results in a reverberant environment are always tricky to interpret due to room interference, especially at low frequencies where the room modes can be separated. So even if you inject a small amount of energy you may measure fairly high sound level, depending on the speaker and the microphone positions. This may be the case with the peak at around 35Hz in my measurements. However, at the highs there are many room modes, making the field more diffuse-like. In my room this happens after around 300Hz. That's why it is easy to see the speaker upper cut off even in the reverberant environment, as there is nothing to support the speaker acoustical output once it starts rolling off. Seeing that this starts already after 12kHz is not quite satisfying.
When I listened to the speakers in the store I noticed they were on the darker side. But I listened to them at a fairly loud level, not quite suitable for home listening, so I could hear more details. But, by seeing what I am seeing in the measurement I lost confidence that I can get a decent quality boost by changing any part of the equipment apart from the speakers themselves. And that was not the intention when I bought them :
So, I believe I found some explanation in the measurement for missing involvement with music. It is mainly not quite deep bass (I'd expect more considering the cabinet size) and somewhat lacking treble.
I'd like to hear the experience of other Audiovector users. S3 and S3 super share the same tweeter so the treble should be pretty much the same in the two models. Thanks.
Til top Vis gojko's Profil Søg efter andre indlæg skrevet af gojko
