Tilbage til HIFI4ALL.DK 3. juli 2026 | 04:56
Emne Emne: Dyb bas i rigelige mængder.. (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
FinnC
Bruger siden: 21 Juli 2005
Sendt: 12 September 2010 kl. 14:36 | IP-adresse registreret
Videnskabelige forsøg i England...
Hvis du hele tiden søger efter bas... mere bas, og selvfølgelig med en god klat power, så se her..   Det virker, videnskabeligt underbygget og bevist, så måske burde du flytte din seng ind i den nærmeste kirke
"It has been suggested that because some organ pipes in churches and cathedrals produce infrasound this could lead to people having weird experiences which they attribute to God," said Professor Richard Wiseman, a psychologist from University of Hertfordshire.
"Some of the experiences in our audience included 'shivering on my wrist', 'an odd feeling in my stomach', 'increased heart rate', 'feeling very anxious', and 'a sudden memory of emotional loss'.
"This was an experiment done under controlled conditions and it shows infrasound does have an impact, and that has implications... in a religious context and some of the unusual experiences people may be having in certain churches."
Sarah Angliss, an engineer and composer in charge of the project, added: "Organ players have been adding infrasound to the mix for 500 years so maybe we're not the first generation to be 'addicted to bass'."
Details of the organ infrasound study are being presented to the British Association's annual science festival, which this year is in Salford, Greater Manchester.
EDIT  Her er mere om forskeren, Sara Angliss http://www.spacedog.biz/sounds/infrasonic
Nogle drukner sig i problemer, andre tager sig en uddannelse, så de kan svømme imellem dem. [Mark Twain 1835-1910]
Til top Vis FinnC's Profil Søg efter andre indlæg skrevet af FinnC
torsteinowich
Bruger siden: 14 Januar 2010
Sendt: 14 September 2010 kl. 17:36 | IP-adresse registreret
FinnC skrev:
<span style="font-weight: bold;">Videnskabelige forsøg i England</span>...Hvis du hele tiden søger efter bas... mere bas, og selvfølgelig med en god klat power, så se
her..   Det virker, videnskabeligt underbygget og bevist, så måske burde du flytte din seng ind i den nærmeste kirke "It has been suggested that because some organ
psychologist from University of Hertfordshire."Some of the experiences in our audience included 'shivering on my wrist', 'an odd feeling in my stomach', 'increased heart
rate', 'feeling very anxious', and 'a sudden memory of emotional loss'."This was an experiment done under controlled conditions and it shows infrasound does have an
impact, and that has implications... in a religious context and some of the unusual experiences people may be having in certain churches."Sarah Angliss, an engineer and
bass'."Details of the organ infrasound study are being presented to the British Association's annual science festival, which this year is in Salford, Greater Manchester.EDIT
Det lyder da ikke så rart. Bas folket udsætter altså sig selv for ængstelse og en følelse af tab? Måske skulle jeg opgive mine drømmerier om mere bas og bare leve med de
2x6,5" pr. kanal... hmmm. En sugen i maven kan måske være OK på den anden side. Så du noget om hvor meget effekt og hvilke frekvenser der skulle til? Nogle af
linksene derinde er desværre døde nu. Måske en drillepind kunne finde på at skrue deres generator ned på den "brune" frekvens ha ha.
Til top Vis torsteinowich's Profil Søg efter andre indlæg skrevet af torsteinowich
Sveske
Bruger siden: 22 Januar 2006
Sendt: 14 September 2010 kl. 17:43 | IP-adresse registreret
Infralyd dækker over de frekvenser der ligger under der hørbare, så selv en 15"enhed fårnok svært ved at give nogle religiøse oplevelser.
Infralyd er et enormt spændende emne, i øvrigt.
Guide til billedupload
FinnC
Sendt: 14 September 2010 kl. 18:37 | IP-adresse registreret
Ja infralyd (20 Hz og nedaf) er meget lidt udforsket.. herhjemme kender jeg kun nogle skriblerier år tilbage ifm. vindmøller, som nogen klagede over de blev dårlige af. Først blev det afvist og år senere via målinger konstaterede man faktisk, der der var infralyd selv på forholdsvis lang afstand fra møllen.. derefter er emnet vist blevet overhalet af x-faktor i dagspressen
Og selv en 18" enhed kommer på arbejde, med mindre den er specialbygget og den spændes på en sag med 500-1000 watt RMS ud.. men så skulle det kunne trille.
 @torsteinowich Frekvensen i forsøget opgives til 17 Hz, men det er afrundet, da forsøget var ifm. et orgel - tonen var nok stemt ind til en gængs frekvens omkring det dybe 'C'.
Registeret dernede er 64' (fod) stemmer, og der er kun få orgler i verden der har det register - jeg kender en enkelt katedral + orgel i England, og nogle få i resten af verden.
En 64' stemme betyder, at den længste pibe er 64' høj - altså en basse på omkring 20 meter
De bruger vist ikke mere den  64' i England pga. murværket ikke er så solidt, at de tør
Jeg har et billede et eller andet sted af de her basser.. prøver om jeg kan finde det.
FinnC
Sendt: 14 September 2010 kl. 19:21 | IP-adresse registreret
Det her er kun 32' fra pedalspil i Exeter Cathedral, England. Se den lille mand ved døråbning nederst til venstre. Frekvensen omkring de 17 Hz kunne laves med piben yderst til højre - den er omkring 10 meter høj - ved 64' så fordobler vi højden og øger diameter kraftigt for hele flokken
