Tilbage til HIFI4ALL.DK 30. juni 2026 | 22:59
Emne Emne: enheder (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
lille_smed
Bruger siden: 08 Januar 2007
Sendt: 03 April 2009 kl. 21:30 | IP-adresse registreret
hej... er der nogen af jer   der kender disse enheder.. det jeg vil bruge dem til er mellemtone  fra 80 til 1500 hz
10'' højttaler TRUVOX-1020
Varenummer: 104980 | TRUVOX-1020
623,00DKK
Prisen er inkl. 25% dansk moms
Klik for større billede
Printvenlig
CELESTION
is one of the most appealing names in the world of speakers and the most interesting speakers of this traditional company are now available from MONACOR INTERNATIONAL. These speakers perfectly complete the wide product range offered by IMG Stage Line in some areas and thus an overall product range is now available which perfectly meets all requirements.
Professional PA midrange speaker, 300WMAX, 150WRMS, 8O
25cm (10") midrange speaker of high power capability from CELESTION, stable steel basket, equipped with a Kevlar fiber reinforced cellulose cone. Wide linear frequency response with excellent dynamic efficiency, suitable for all high-quality PA applications. Can be perfectly used as a bass-midrange speaker in compact sub/sat PA systems or in speaker systems for vocal sound, too.
TEKNISKE DATA:
Impedance (Z) 8O
Resonant frequency (fs) 77Hz
Max. frequency range f3-3,500Hz
Music power 300WMAX
Power rating (P) 150WRMS
SPL (1W/1m) 100dB
Suspension compl. (Cms) 0.14mm/N
Moving mass (Mms) 29g
Mech. Q factor (Qms) 4.79
Electr. Q factor (Qes) 0.43
Total Q factor (Qts) 0.39
Equivalent volume (Vas) 27 l
DC resistance (Re) 5.5O
Force factor (BxL) 13.53Tm
Voice coil induct. (Le) 0.7mH
Voice coil diameter Ø 50mm
Voice coil former Kapton
Linear excursion (XMAX) ±2mm
Eff. cone area (Sd) 363cm2
Magnet weight 42oz.
Weight 3.6kg
12'' højttaler TRUVOX-1225
Varenummer: 104990 | TRUVOX-1225
762,00DKK
Printvenlig
CELESTION
Professional PA bass-midrange speaker, 500WMAX, 250WRMS, 8O
30cm (12") bass-midrange speaker vom CELESTION of very high power capability. Stable steel basket, equipped with a Kevlar fiber reinforced cellulose cone. A wide frequency response with good attenuation, suitable for all general PA applications, with good limit frequency in BR cabinets of medium size.
TEKNISKE DATA:
Impedance (Z) 8O
Resonant frequency (fs) 62Hz
Max. frequency range f3-4,000Hz
Music power 500WMAX
Power rating (P) 250WRMS
SPL (1W/1m) 99dB
Suspension compl. (Cms) 0.13mm/N
Moving mass (Mms) 46g
Mech. Q factor (Qms) 6.57
Electr. Q factor (Qes) 0.52
Total Q factor (Qts) 0.48
Equivalent volume (Vas) 57 l
DC resistance (Re) 5.3O
Force factor (BxL) 13.72Tm
Voice coil induct. (Le) 0.8mH
Voice coil diameter Ø 63mm
Linear excursion (XMAX) ±2.4mm
Eff. cone area (Sd) 551cm2
Magnet weight 50oz.
Weight 3.9kg
Klik på billede for størrer visning
musicus
Sendt: 03 April 2009 kl. 22:51 | IP-adresse registreret
Celestion har en 10" som efter sigende faktisk skulle have en fornuftig mellemtone
Men kan ikke lige huske hvilken model
Hvad med en Beyma 12" fuldtone
lille_smed
Sendt: 03 April 2009 kl. 23:47 | IP-adresse registreret
jeg er ikke ikke lige ude efter en fuldtone enhed desværre .. men eb super go mellem tone
jan_stevns
Sendt: 04 April 2009 kl. 10:02 | IP-adresse registreret
du vil pakke en 10" mellemtone enhed - med en følsomhed på 100db -  sammen med hvad ?
"super go" ...   forstået som hvad ?
-Jan@tecdata.dk
lille_smed
Sendt: 04 April 2009 kl. 10:53 | IP-adresse registreret
hejsa .. jeg vil forsøge at lave den som en dipol system .. og der falder følsomheden meget fra ca 300 hz og ned til de stad jeg vil dele  .. ved 80 hz.. den falder ca 6 db pr oktav ..  så følsomheden vil være ca 90 92 db .. når jeg har udlinet det tab der kommer ...  til at starte med vil jeg prøve med ss 12m   4" samt r2904.....
 hvis de enheder er for svage .. må jeg jo se efter nogle andre ... og med hensyn til følsomheden -- har jeg forstærker til hver enhed .. så det skal nok kunne komme til at virke ..
 men kender du den enhed .. lyder den godt  ..
jan_stevns
Sendt: 04 April 2009 kl. 23:39 | IP-adresse registreret
nope - kender den ikke ...
Celestion lavede gode ting i gamle dage - (deres Hifi systemer) deres PA systemer var ikke meget fremme i skoene dengang,  hvordan de er i dag, aner jeg ikke
-Jan@tecdata.dk
lille_smed
Sendt: 05 April 2009 kl. 14:44 | IP-adresse registreret
oki en skam du ikke kender til det .. så er der vel kun en måde at finde ud af det på .. det er vel bare at købe dem og lytte til dem
