Tilbage til HIFI4ALL.DK 29. juni 2026 | 07:02
Emne Emne: RCA signal kabel anbefaling: (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
Claus_DK
Bruger siden: 29 April 2005
Sendt: 02 November 2007 kl. 14:07 | IP-adresse registreret
Skal bruge et par RCA signal kabler, dels fra CD, men også fra surround reciever til effektforstærker.
Har umiddelbart kig på disse:
http://www.av-connection.dk/?PNo=SUPDRCA005&SPage=Stereo -Phono-RCA_Kabler
Fra supras site om dette kabel:
Dual
Supra Dual is an Interconnect pair-cable for analogue line applications, such as signal source to preamplifier connection. The Supra Dual Design Supra Dual is designed for noise immunity and for best musical performance. The Semi-balanced connection configuration enhances the immunity to electro-magnetic interference. It means that the screens are connected to earth at only one end of the cable, so there is no signal through the screens, but they serve only as screens. The earth connection is at the end where the marking text starts. Connect the earthed end to the sorce device. Besides the good shielding properties of the Aluminum foil, the cores are symmetrically twisted to avoid the magnetic pickup. The Dual cable is a fast interconnect of low capacitance. Supra Dual is insulated with PE (Polyethylene) which makes only 52 pF/m and makes the propagation velocity to 66% of light speed.
Det er ca det prisleje jeg er villig til at betale, kan muligvis acceptere højere pris, men så skal der være gode argumenter.
Skal med det samme sige at jeg ikke har stor erfaring med kabler, men har læst mig til at afskærming er vigtig og generelt bare det er lavet ordenligt samt det her med retningsbestemt og "jordet"? eller i den dur. Så vidt jeg kan læse mig til lever dette supra kabel op til de krav.
Nogen andre gode ideer?
Til top Vis Claus_DK's Profil Søg efter andre indlæg skrevet af Claus_DK
