Tilbage til HIFI4ALL.DK 6. juli 2026 | 03:15
Emne Emne: windows vista audio (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
xo
Bruger siden: 04 April 2005
Sendt: 18 September 2005 kl. 20:33 | IP-adresse registreret
Det her er lidt perifert, men interessant. Lidt om forbedringer af lydkvaliteten i Windows Vista.
http://channel9.msdn.com/Showpost.aspx?postid=116347
Til top Vis xo's Profil Søg efter andre indlæg skrevet af xo
zerocool
Bruger siden: 19 Maj 2004
Sendt: 19 September 2005 kl. 11:13 | IP-adresse registreret
Meget interessant
Til top Vis zerocool's Profil Søg efter andre indlæg skrevet af zerocool
xo
Sendt: 24 September 2005 kl. 12:07 | IP-adresse registreret
Lidt mere teknisk info til de interesserede.
http://blogs.msdn.com/larryosterman/
Se f.eks. Windows Audio Quality Enhancements
http://blogs.msdn.com/larryosterman/archive/2005/09/20/47187 2.aspx
"The other significant change we made to ensure high fidelity audio rendering is that we converted the entire audio pipeline from dealing with 16bit integers to 32bit floating point values."
"Before Vista, the kernel audio stack set the output audio format to match the format of the audio being played.  Normally, this isn't a problem, since it means that we do less DSP of the signals.  Unfortunately, it can lead to some rather unanticipated consequences.  For instance, if you're playing a system sound (usually stereo, 22kHz), at the same time you start playing your MP3 files, then the MP3 file rendering happens at 22kHz, which is a noticeable  degradation of audio quality.  Once the audio system goes quiet, the rendering format will reset to the format of the content being played, but that may be quite some time later."
Det bliver noget af en forbedring med den nye OS! Omvendt er det også meget skidt som det ser ud nu.
Og lidt om MacVærket.
http://www.apple.com/macosx/features/coreaudio/
zerocool
Sendt: 26 September 2005 kl. 15:25 | IP-adresse registreret
Linket virker ikke
xo
Sendt: 26 September 2005 kl. 18:48 | IP-adresse registreret
Nulkold, du behøver blot gå ind på siden
Det andet link var et link til et sted nede på siden. Men led bare efter Windows Audio Quality Enhancements overskriften inde på ovenstående side.
zerocool
Sendt: 26 September 2005 kl. 19:01 | IP-adresse registreret
will do... takker
xo
Sendt: 26 September 2005 kl. 19:52 | IP-adresse registreret
Ingen årsag. Og tilføj endelig hvis du også finder info om lyd i windows.
xo
Sendt: 15 December 2005 kl. 20:00 | IP-adresse registreret
Mere fra samme skuffe. "Going Deep".
http://channel9.msdn.com/ShowPost.aspx?PostID=145665
zerocool
Sendt: 22 December 2005 kl. 09:02 | IP-adresse registreret
Takker, det skal jeg lige kigge nærmere på. Det bliver nu dejligt, at kunne bruge MCE Vista uden bekymring om resampling
