Tilbage til HIFI4ALL.DK 29. juni 2026 | 22:37
Emne Emne: Autoiris highend? (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
Spencer
Sendt: 02 Januar 2008 kl. 20:19 | IP-adresse registreret
Hvad er highend indenfor en god autoiris ?
Denne Epson hører efter min mening ikke hjemme i den kategori:
http://www.cine4home.com/reviews/projectors/EpsonTW600/Epson Review.htm
Citat: "it takes no less than 20 seconds for the adaptive iris to close completely on a dark picture. If the projector is given the time necessary, it indeed reaches the fabulous contrast ratio of just about 5500:1, in the case of our review sample even more as the technical data indicates. Thanks to the Cinema color filter this measurement refers to the absolute accurate color temperature of 6500K / D65 in all gray tones and white. When opening the iris reacts a bit faster: it takes about 8 seconds for the iris to open fully with white."
Og lidt mere:  With this high contrast value at D65 the projector impresses with its data like no other projector. However, because of its slow reaction time the value is not very telling during movie projection. In practice a dark scene does not very often last the 20 seconds the iris needs to fully close. In addition, the black level is not that dark during the transition time and shows the usual "black gray"
Hvilke projektorer excellerer i denne kategori ?
Tjek videoen af autoirisen på den Epson. Det må kunne gøres bedre.
perejvind
Sendt: 02 Januar 2008 kl. 22:37 | IP-adresse registreret
Ja, den iris forhaster sig da godtnok ikke
Dynamisk iris er og bliver noget bras. Den gør mere skade end gavn, men det ser da imponerende ud når fabrikanten kan opgive 12000:1 i kontrastforhold (eller mere)
I like techno - UNPLUGGED!
StarTrek
Eks. Jamwa
Bruger siden: 25 April 2007
Sendt: 02 Januar 2008 kl. 22:39 | IP-adresse registreret
Selfølige kan de opgive 12000:1 i kontrastforhold (eller mere), når iris er lukke hel i, og der er jo lige med nul lys og nul billde
Spencer
Sendt: 08 Januar 2008 kl. 09:50 | IP-adresse registreret
Lige netop!
LCD/DLP producenterne måler kontrasten 'Full on off', hvilket vil sige at der ikke kan være maksimum sort og maksimum hvid i samme skærmbillede, da iris må vælge om den vil være åben eller lukket.
Når det tager 20 sek. for iris at lukke helt, så svarer det til måle dynamik i et stereoanlæg, ved at man manuelt skruer op på volumenkontrollen, når det skal være højt,  og skruer ned igen når det skal være lavt. Utroligt hvis de data for kontrast kan imponere nogen, men mange hopper med på vognen, og projektorfabrikanterne er nød til at bruge denne molbo-metode at måle på, da konkurrenterne gør det.
Spencer
Sendt: 20 Januar 2008 kl. 13:44 | IP-adresse registreret
Kunne egentlig godt lide at vide hvor hurtig den bedste autoiris er til at lukke ?
StarTrek
Eks. Jamwa
Sendt: 20 Januar 2008 kl. 13:49 | IP-adresse registreret
autoiris er og blive noget bras, at der så ikke er nogle grund til at bruge det, ud over i reklame øje (man kan skrive så og så stor kontrans), JVC
har vist at det er mulig at lave en LCD med høj kontranst og unden autoiris.
