Tilbage til HIFI4ALL.DK 1. juli 2026 | 23:20
Emne Emne: Automatisk Standby i MCE workaround (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
larskb
Bruger siden: 12 Juli 2005
Sendt: 18 Marts 2006 kl. 10:48 | IP-adresse registreret
Hej alle,
Jeg og mange andre har bokset med dette problem siden RollUp2, og andre har aldrig set problemet.Her er et workaround, og det virker for mig
http://blogs.msdn.com/astebner/archive/2006/02/05/525274.asp x
3.  Media Center will not correctly enter standby mode if the TV tuner was used prior to going into standby
This is a recently discovered regression introduced in Update Rollup 2 that we are currently working on a fix for.  Once a fix is ready, it will likely be included in the next Media Center hotfix rollup package.  The only known workaround at this time is to disable Media Center sounds by navigating to Settings | General | Visual and Sound Effects and unchecking the box labeled Play sounds while navigating Media Center.
/Lars
Til top Vis larskb's Profil Søg efter andre indlæg skrevet af larskb
