Tilbage til HIFI4ALL.DK 27. juni 2026 | 04:36
Emne Emne: ANSI kontrast (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
Jonas bojer
BIIR
Sendt: 27 Marts 2008 kl. 22:50 | IP-adresse registreret
Så forstå jeg bedre at jeg syntes at LCD og D-ILA set lidt tamt ud i dynamiske sener med forskellige lys på samme tid i billedet.
Følgende er klippet fra http://www.projectorcentral.com/
BenQ W20000. The BenQ W20000 has a Full On/Off contrast spec of 20,000:1. As with the JVC RS2, this is a native specification, as there is no variable iris. Our Full On/Off measurement was 8,800:1. So as with the RS2, our measurement was quite a bit lower than the official specification.
Meanwhile, our ANSI contrast measurement on the W20000 was 560:1, which is more than double that of the JVC RS2. It is noteworthy that the W20000 is a DLP projector. We have measured two other DLP projectors thus far with similar results. The Optoma HD80 registered an ANSI contrast reading of 526:1, and the new Infocus IN83 measured 517:1. However, not all DLP projectors manifest high ANSI readings. The Optoma HD65, a lower priced and lower performance DLP projector, measured 268:1.
In addition to the models noted previously, we have also tested the Viewsonic Pro8100, a new LCD 1080p model. That unit delivered an ANSI contrast reading of 258:1, and the Epson Cinema 1080 UB registered an ANSI reading of 255:1.
Hvorfor opgiver producenterne ikke ansi kontrasten, kan ikke finde den nogle steder?
Hvad er Ansi kontrasten for en SIM2? eller Samsung SP-A800B?
Hilsen Jonas Bojer
Rahbek78
Bruger siden: 23 April 2005
Sendt: 28 Marts 2008 kl. 01:03 | IP-adresse registreret
Yep, ANSI kontrast giver altså bare et mere lifelike 3 demensionelt billede. En af de ting man virkelig skal tænke over når man vælger PJ.
Jeg har dog stadig svært ved at forstå "teknikken" bag dette.
Ta eksempelvis JVC projektorene. De er i stand til at have dyb sort sammen med et helt lysende objekt på skærmen samtidig. Og med det lysende objekt "meget" lysstærk. Trods det kan du nemt opleve samme scene fra en DLP. Dog ikke med den samme dybe sort, men alligevel ha et DLP billede med mere punch og pop. Man skulle tro at JVCen ville være overlegen når det gælder en sådan test, men det behøves ikke være tilfældet. Jeg forstår ikke dette fænomen...
Er det lumens eller hvad søren er det der gør at DLP virker mere 3D?
Er der nogen der kan komme med den tekniske forklaring på dette??
Til top Vis Rahbek78's Profil Søg efter andre indlæg skrevet af Rahbek78
Otto J
Dynaudio
Bruger siden: 04 Marts 2007
Sendt: 28 Marts 2008 kl. 12:18 | IP-adresse registreret
Det lyder simpelthen ikke imponerende i specifikationerne... Derudover vil selv en egentlig opgivelse være svær at sammenligne, da ANSI kontrast er ekstremt afhængigt af forholdene der måles under. Rummet skal være temmeligt mørklagt for at nå over 200:1 ansi-kontrast i praksis. Ikke dermed sagt at man ikke kan se forskel på en projektor med 200:1 og 700:1, men det siger lidt om hvor svært det er at bruge tallene. Det er vigtigere hvordan man oplever kontrasten i praksis, end hvad målingerne siger - for at sammenligne ansi-kontrast uden at sammenligne on/off kontrast, er reelt lige så forkert som at sammenligne on/off kontrast uden at sammenligne ansi-kontrast. I realiteten er den oplevede kontrast en kombination af de to ting.
Jeg kan ikke lige hoste op med en kilde, men der henvises typisk til omegnen af 700-900:1 alt efter model, under forhold hvor JVC'en måles til 350-400:1.
Otto Jørgensen, Dynaudio A/S
Otto J
Dynaudio
Sendt: 28 Marts 2008 kl. 12:22 | IP-adresse registreret
Jeg vil påstå at jo mere korrekt billedet som helhed virker, jo mere "3D agtigt" opleves billedet. "3D" oplevelsen er en meget subjektiv ting, der ikke kan hænges op på én bestemt faktor. Husk at billedet per definition er 2D, så der er ikke noget bestemt man kan gøre for at få billedet til at være 3D - man kan levere et bedre, mere korrekt 2D billede, som du så subjektivt oplever giver en bedre 3D effekt. Jeg har oplevet at folk har sagt at billedet er blevet mere 3D, efter udelukkende en ændring af gråskalaen. Mere korrekte farver gør at du oplever billedet mere realistisk, og dermed måske også mere "3D". Så når du oplever de DLP-projektorer du ser som værende mere "3D", er det formentligt ganske enkelt fordi de generelt leverer billedet mere korrekt. DLP er dén teknologi der er nemmest at opnå en korrekt billedgengivelse med, fordi den som den eneste er 100% lineær, så en producent der fokuserer målrettet på korrekt gengivelse, vil som regel tage udgangspunkt i DLP.
