Tilbage til HIFI4ALL.DK 26. juli 2026 | 22:41
Emne Emne: Prodigy drivere - ØV ! (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
janpal
Bruger siden: 30 Juli 2009
Sendt: 02 Januar 2010 kl. 02:29 | IP-adresse registreret
Jeg har netop installeret Prodigy 7.1 HiFi men har mange spørgsmål/problemer.
I må meget gerne byde ind med kommentarer og tips.
Det er på engelsk fordi jeg netop har e-mailet til Audiotrak support.
I'm using Vista 32-bit.
I'm using Windows Media Center to play stereo and DVD's with 5.1 surround sound.
I'm also using the Line-In because my televisons stereo-output is connected to that.
I have de-activated the drivers for the on-board sound card.
A)
The program on the cd is v 1.02.
The newest driver/control panel is v 1.08. How should I install that ? I tried running win32\Pd71HiFiPan.exe but nothing happened and when I start the program it still says v 1.02.
Pd71HiFiPan.exe is the only exe-file I see (apart from the UnInstall32.exe which I assume I shouldn't run).
B)
The test channels (where there's a robot-head) doesn't work. All speakers are greyed out. When I press "Auto" nothing happens. Why is that ?
C)
In Vistas Control Panel /Sound I have three devices:
"Loudspeakers". From here I can run the test and all of my 5 speakers works.
"Internal AUX-plug". What do I need this for ? And why is the "level" tab blank ?
"Loudspeakers QVE for Prodigy". What is this for ? And why doesn't my speakers work when I try the "test" from here ? Level is set to 100.
D)
I think the manual has very little information of how-to-setup. Maybe it's just me that's not a musician or soundtechnician, but stil..
I don't need explanations of all the effects, Directwire, QEM, QSizzle, QRumble, 3D, EQ and so on.
I don't need any explanation for setting up for recording.
I just need a simple explanation of how to 1) play HiFi music 2) play DVD with 5.1 surround 3) setting the level for LineIn via my WMC remote control.
E)
When I run the WMC setup of speakers all speakers are muted. Why is that ?
F)
What is the 4-pin connector on the board to ?
What is the 20-pin connector on the board to ?
G)
Why is there both audiotrak.net and audiotrack.net which apparently holds drivers for different products.
H)
I have connected my TV to line-in, but the volumne can't be controlled via WMC. Why not ?
Is this volume only controlled via Gain ?
Why is there a CD-input in the software when there's no where to connect a cable (there's only line-in and mic).
Thank you,
Jan
Til top Vis janpal's Profil Søg efter andre indlæg skrevet af janpal
LeGuin
Bruger siden: 19 August 2004
Sendt: 07 Januar 2010 kl. 12:53 | IP-adresse registreret
Jeg gav selv op med mit prodigy. Ville ligesom dig blot have 5.1 surround ud via spdif, men fik det aldrig til at virke. Troede at jeg havde købt det bedste dengang, men endte med at give det væk:(
Skiftede bundkort til et med et billigt onboard lydkort - det var tilgengæld plug and play og virkede med det samme....
JVC PD35D30 Plasma
Sony STR-DB 790 reciever
HTPC: Core 2 Duo E6600 4Gb Ram, 1.2 tB HD, Technotrend 1500 budget, ATI radeon 1600XT silent, AudioTrak Progidy 7.1 LT, Dign 3 case
Windows XP MCE 2005
Til top Vis LeGuin's Profil Søg efter andre indlæg skrevet af LeGuin
Zhooter
Bruger siden: 13 December 2006
Sendt: 21 Januar 2010 kl. 19:54 | IP-adresse registreret
Hejsa..
nu ved jeg selvfølgelig ikke om det kunne være en hjælp med har du været inde i Windows Lyd og vælge at dit Prodigy skal kører Digital ud ??
På mit prodigy kort skal jeg ind og vælge QVE for at det kører spdif out.
//Zhooter
Til top Vis Zhooter's Profil Søg efter andre indlæg skrevet af Zhooter
LeGuin
Sendt: 03 Februar 2010 kl. 09:24 | IP-adresse registreret
Problemet er (eller var ihvertfald for mig) at få DD/DTS passthrough til SPDIF. Stereo via spdif virker..
JVC PD35D30 Plasma
Windows XP MCE 2005
