Forfatter |
TheKingDK Forum Bruger
![Forum Bruger](forum_images/4_star_rating.gif)
![Avatar](http://www.hifi4all.dk/forum/forum_postsTID=28618&PN=1)
Bruger siden: 04 December 2003 Lokalitet: Sjælland
Status: Offline Indlæg: 52
Sendt: 22 Oktober 2006 kl. 03:46 | IP-adresse registreret
Hey folkens! her er mit surround Lir! håber på en masse Ris & Ros fra jer!
![](uploads/TheKingDK/2006-10-22_031740_000_0113.JPG)
Mit setup består af:
Højttalere:.
B&W xt4 fronter
Technical Specifications : XT4 |
Description |
3-way vented-box system |
Dimensions |
Height: 1138mm (44.8 in) (not including feet) Width: 152mm (6 i Depth: 200mm (7.9 in)
Net Weight |
24.5kg (54 lb) |
Freq. Response |
40Hz - 22kHz ±3dB on reference axis |
Freq. Range |
-6dB at 34Hz and 50kHz |
Sensitivity |
86dB spl (2.83V, 1m) |
Normal Impedance |
8 ohms (minimum 3.1 ohms) |
Power Handling |
50W - 150W into 8 ohms on unclipped programme |
Drive Units |
Unit 1: 1x 25mm (1 in) aluminium dome high-frequency Unit 2: 1x 130mm (5 in) woven Kevlar® cone midrange Unit 3: 2x 130mm (5 in) Paper/Kevlar® cone bass
Finish |
Cabinet: Natural aluminium Grille: Black cloth |
Dispersion |
Description: Within 2dB of reference response Horizontal: over 60º arc Vertical: over 10º arc
Harmonic Distortion |
2nd and 3rd harmonics (90dB, 1m) <1% 120Hz - 20kHz |
Crossover Frequency |
360Hz, 3.5kHz |
B&W xtc Center
B&W PV1 Sub
Technical Specifications : Model PV1 |
Description |
Active closed-box subwoofer |
Dimensions |
Height: 335.5mm 13.2 in) Width: 289mm (11.4 in) Depth: 347mm (13.7 in)
Net Weight |
20.5kg (45 lb) |
Freq. Response |
±3dB 21Hz – 31/110Hz adjustable (EQ at i) |
Freq. Range |
-6dB at 18Hz and 40/140Hz adjustable (EQ at i) |
Drive Units |
Unit 1: 2x ø200mm (8 in) mica / aluminium cone long-throw Unit 2: Unit 3:
Finish |
Gloss silver with grey trim Gloss black with anthracite trim Gloss white with chrome trim |
Sub Woofer Amplifier |
Description: Class-D ICEpower® Power Output: 500W Input Impedance: 100k ohms Signal Noise: >90dB Functions: Volume level Low-pass filter frequency Bass roll-off alignment Auto sense on/standby Phase switch Inputs: Line In (RCA Phono) Speaker Level In (FCC68 4/4) 10m cable with FCC68 4/4 plug supplied Outputs: Link Out (RCA Phono)
Low Pass Filter |
Active 2nd -order, variable cut-off frequency (applies only to speaker level input) |
![](http://www.bwspeakers.com/gfx/generic_gfx/spacer.gif)
Bowers & Wilkins 2002 | B&W ds6 s3 BagBanditter
Technical Specifications : DS6 S3 |
Description |
2-way closed-box selectable dipole/monopole surround system |
Dimensions |
Height: 249mm (9.8 in) Width: 380mm (15 in) Depth: 153mm (6 in)
Net Weight |
5.2kg (11.5 lb) |
Freq. Response |
85Hz – 22kHz ±3dB on reference axis (monopole mode) 85Hz – 10kHz ±3dB power averaged over front hemisphere (dipole mode) |
Freq. Range |
-6dB at 63Hz and 42kHz (monopole mode) -6dB at 63Hz and 15kHz (dipole mode) |
Sensitivity |
89dB spl (2.83V, 1m) |
Normal Impedance |
8Ω (minimum 3.3Ω) |
Power Handling |
25W – 100W into 8Ω on unclipped programme |
Drive Units |
Unit 1: ø130mm (5 in) woven Kevlar® cone bass / midrange Unit 2: 2x ø80mm (3 in) midrange / high frequency Unit 3: ø25mm (1 in) alloy dome high-frequency
Finish |
Cabinet: Black or white Grille: Black or white cloth |
Dispersion |
Description: Dipole mode: horizontal figure of eight Effective null zone ±20º (250Hz – 15kHz) Monopole mode: within 2dB of reference response Horizontal: over 40º arc Vertical: over 10º arc
2nd and 3rd harmonics (90dB, 1m) <1% 130Hz – 20kHz |
250Hz (dipole mode) 4kHz (monopole mode) |
Max. Recommended Cable Impedance |
0.1Ω |
Anlæg:.
Thule PA350B Effekt
Thule SPACE PR350B "Fully balanced signal path"
Thule DVA250B DVD
Kabler:
xlr kabler fra gamut
Dali Silver Wave two "HT kabel"
tara labs axiom "signal"
Qed qunex reference "signal"
IXOS 110 audio visual 75 ohm screened ofc "scart kabel"
tara labs prism2200i interconnect "signal fra pv1"
Og nu en masse billeder.....
![](uploads/TheKingDK/2006-10-22_032604_000_0076.JPG)
Her sidder alarmen...
![](uploads/TheKingDK/2006-10-22_032742_000_0078.JPG)
Pv1
![](uploads/TheKingDK/2006-10-22_033103_000_0086.JPG)
![](uploads/TheKingDK/2006-10-22_033130_000_0089.JPG)
![](uploads/TheKingDK/2006-10-22_033155_000_0093.JPG)
![](uploads/TheKingDK/2006-10-22_033228_000_0094.JPG)
![](uploads/TheKingDK/2006-10-22_033324_000_0096.JPG)
![](uploads/TheKingDK/2006-10-22_033403_000_0097.JPG)
![](uploads/TheKingDK/2006-10-22_033454_000_0105.JPG)
![](uploads/TheKingDK/2006-10-22_033529_000_0106.JPG)
![](uploads/TheKingDK/2006-10-22_033730_000_0110_kabler2.JPG)
![](uploads/TheKingDK/2006-10-22_033821_000_0111.JPG)
![](uploads/TheKingDK/2006-10-22_033848_000_0114cd.JPG)
![](uploads/TheKingDK/2006-10-22_033912_000_0117.JPG)
![](uploads/TheKingDK/2006-10-22_034127_000_0120skrå2.JPG)
__________________ Mvh. Thomas
Til top |
LarsGert Forum Bruger
Bruger siden: 15 Marts 2006 Lokalitet: Nordjylland
Status: Offline Indlæg: 188
Sendt: 22 Oktober 2006 kl. 08:49 | IP-adresse registreret
Det er satme i orden...
Til top |
mathias 2 Forum Bruger
![Avatar](http://www.australianmusician.com.au/mag/autumn03/stevie_ray.jpg)
Bruger siden: 03 Juni 2006 Lokalitet: Århus
Status: Offline Indlæg: 1669
Sendt: 22 Oktober 2006 kl. 09:14 | IP-adresse registreret
Til top |
Acer Forum Bruger
![Avatar](uploads/Acer/2014-01-15_144430_gti6-2.GIF)
Bruger siden: 06 Juni 2003 Lokalitet: Østjylland
Status: Offline Indlæg: 3734
Sendt: 22 Oktober 2006 kl. 09:47 | IP-adresse registreret
Det ser rigtigt godt ud, men bliver din effekt ikke varm med den center på ryggen ? ![](smileys/smiley4.gif) __________________ Fyrer De, Hr. ? Nej da, jeg har H/K
Til top |
Lestat Forum Bruger
![Avatar](avatars/anglewings.jpg)
Bruger siden: 01 Januar 2004 Lokalitet: Århus
Status: Offline Indlæg: 456
Sendt: 22 Oktober 2006 kl. 19:55 | IP-adresse registreret
Super lækkert, det er utroligt så meget af vores udstyr er ens - fronter, bag, CD rack... :)
Men det ser godt ud, og jeg ved at det også lyder godt! ;) Ville utroligt gerne selv have et godt effekt trin til mine XT4'ere så jeg kan få det optimale ud af dem, men det kommer nok lige til at vente til næste år. Måske en bette S200 hvis den kan findes til en god pris?
L. __________________ visit wireframed
Mit setup
Til top |
Sendt: 22 Oktober 2006 kl. 19:58 | IP-adresse registreret
Acer skrev:
Det ser rigtigt godt ud, men bliver din effekt ikke varm med den center på ryggen ? ![](smileys/smiley4.gif) |
Mange tak.... køle rilerne i effekt trinet starter først lige efter foden til centeren... Så den kan stadig trække vejret! __________________ Mvh. Thomas
Til top |
Emi_one Forum Bruger
![Avatar](uploads/Emione/2006-10-01_212536_profilbilleder.jpg)
Bruger siden: 08 August 2006 Lokalitet: Nordjylland
Status: Offline Indlæg: 298
Sendt: 22 Oktober 2006 kl. 20:05 | IP-adresse registreret
Det ser da ret så godt ud.![](smileys/smiley17.gif) __________________ Tømmer!
Til top |
rattanhuset Forum Bruger
![Avatar](avatars/eye_storm.jpg)
Bruger siden: 09 Juni 2003 Lokalitet: Jylland
Status: Offline Indlæg: 4050
Sendt: 22 Oktober 2006 kl. 20:11 | IP-adresse registreret
Uha da det er da bare iorden, til menneskepenge og alting. Synes dit tv ser rigtig godt ud, men er også "phillips mand" så det er der måske ikke noget underligt i. Stik vovse en kiks fra mig
Til top |
Sendt: 22 Oktober 2006 kl. 20:12 | IP-adresse registreret
L.
JA du har en super smag hr. Lestat hehe...
der er ellers en til salg i den blå avis!! sjovt nok havde jeg selv overvejet at købe netop det effekt trin til mit gamle anlæg den er super flot...
![](uploads/TheKingDK/2006-10-22_200802_46669653_08102006174622_3961_3.jpg)
de står til 10500 samlet men det kan jo være at du kan nøjes med at købe den ene del... den er jo halv dyr fra ny af. xt4'erne har godt nok brug for power... så det giver rigtig meget med et effekt trin. især til stereo...
her et link: http://www.dba.dk/asp/soegning/detail.asp?annonceid=46669653 __________________ Mvh. Thomas
Til top |
Brok Forum Bruger
![Avatar](uploads/brok/2007-09-12_172241_249998233466d1eb88086c.jpg)
Bruger siden: 05 Marts 2004 Lokalitet: Stor-København
Status: Offline Indlæg: 3132
Sendt: 22 Oktober 2006 kl. 20:14 | IP-adresse registreret
Nice ![](smileys/smiley32.gif)
Og sød hund![](smileys/smiley2.gif)
Er det et sæt cdm 70(X) der står i skammekrogen ved siden af sofaen?
Brok __________________ Skodgrej og popmusik
Til top |
Sendt: 22 Oktober 2006 kl. 20:21 | IP-adresse registreret
Brok
ja det er det... skammekrogen det er et sæt jeg har hentet hjem for en kammi... havde sat dem til forleden dag de gør det faktisk rigtig godt bare lidt old school look med den kantede top-... sød hund ja bare ikk når man skal sætte kabler til hun vil meget gerne være med når man kun er 6 mdr. gammel er der fart over feltet... __________________ Mvh. Thomas
Til top |
Sendt: 22 Oktober 2006 kl. 20:27 | IP-adresse registreret
Lestat skrev:
Super lækkert, det er utroligt så meget af vores udstyr er ens - fronter, bag, CD rack... :) | | har du så samme problem med at cd'erne rasler med når du spiller... det er frygteligt har overvejet at tage den ned igen eller flytte den, jeg plejer hænge et lille tæppe over når pv1'eren er på arbejde... ![](smileys/smiley9.gif) __________________ Mvh. Thomas
Til top |
Sendt: 22 Oktober 2006 kl. 20:29 | IP-adresse registreret
Brok
Hehe kender det, så har du et "dampbarn" ![](smileys/smiley36.gif)
Til top |
Andreas KBH Forum Bruger
![Avatar](uploads/AndreasKBH/2006-08-30_191925_Fluffball.jpg)
Bruger siden: 26 Januar 2006 Lokalitet: Østjylland
Status: Offline Indlæg: 469
Sendt: 22 Oktober 2006 kl. 20:50 | IP-adresse registreret
Flot sammensat ![](smileys/smiley32.gif) ![](smileys/smiley32.gif) ![](smileys/smiley32.gif)
Kender dog kun Thule produkterne, men B&W skulle jo være sluppet godt fra XT4'eren og så ser den jo godt ud ![](smileys/smiley4.gif)
Håber det spiller som udseende ![](smileys/smiley2.gif) __________________ Venligst Andreas
Back home in a cold country...
Til top |
Sendt: 22 Oktober 2006 kl. 21:13 | IP-adresse registreret
de spiller ganske hæderligt & lidt til men hvis jeg en dag falder over noget brugt fra b&w's 800 serie så er jeg bange for at de kommer til at bo hos mig... men min kæreste bliver ked af det, den dag det sker... __________________ Mvh. Thomas
Til top |
Aaberg Forum Bruger
![Avatar](avatars/animal_monkey.jpg)
Bruger siden: 24 November 2003 Lokalitet: København
Status: Offline Indlæg: 112
Sendt: 22 Oktober 2006 kl. 21:20 | IP-adresse registreret
Flot flot. Du er en af de heldige som har fået dem i Alu:-)
Til top |
Olsen Forum Bruger
![Avatar](uploads/Olsen/2005-02-06_214854_sheetmusic-corner.jpg)
Bruger siden: 21 Februar 2004 Lokalitet: Vestsjælland
Status: Offline Indlæg: 884
Sendt: 22 Oktober 2006 kl. 21:23 | IP-adresse registreret
Må man spørge hvad det er for en CD-holder? Den ser ret pæn ud - hvilket det øvrige også gør!! ![](smileys/smiley4.gif) __________________ Venlig hilsen
Olsen
Til top |
Sendt: 22 Oktober 2006 kl. 21:27 | IP-adresse registreret
Aaberg skrev:
Flot flot. Du er en af de heldige som har fået dem i Alu:-) |
okay de er måske svære at opdrive? synes den sorte at lidt kedelig i forhold til... __________________ Mvh. Thomas
Til top |
Sendt: 22 Oktober 2006 kl. 21:29 | IP-adresse registreret
det er en Rosendahl cd holder.... den var på tilbud i fakta til 299 kr. for noget tid siden. __________________ Mvh. Thomas
Til top |
LPH. Forum Bruger
![Avatar](avatars/white_face.jpg)
Bruger siden: 25 Marts 2006 Lokalitet: Aalborg
Status: Offline Indlæg: 169
Sendt: 23 Oktober 2006 kl. 17:34 | IP-adresse registreret
Go stil.
-LPH __________________ -LPH
Til top |
