Tilbage til HIFI4ALL.DK 27. juli 2026 | 10:47
Emne Emne: Razer Mako 2.1 THX (Emne lukket Emne lukket) Indryk indlægOpret nyt emne
ParadokS
Bruger siden: 24 September 2007
Sendt: 26 September 2013 kl. 16:28 | IP-adresse registreret
Det drejer sig om et 2.1 speaker/subwoofer system til PC. Genial lyd men desværre et meget kendt problem med "clicking
sound of death".
Alle elektronik reperations steder jeg kunne finde tager 500 kroner bare for at se på den og give mig et bud på reperations
omkostninger. Det syntes jeg er lidt vildt! Så hvis der er nogle elektronik kyndige der evt. kan skifte nogle kapacitorer I KBH
området er jeg villig til at betale en rimelig pris og en frokost :)
Det bedste løsningsforslag jeg kunne finde kommer her:
"The solution is that there are two capacitors in the subwoofer amp that need replacing. A qualified electrical repair shop
can do this easily for you. If they put it on the oscilloscope, you'll see that the issue is one of two caps : Best solution is to
replace both the capacitors. One capacitor is 47 uF/50V, and the other is capacitor is a 100 uF 35V. Voltage (Voltage
capacitors) must be of higher capacity, not lower. By putting in slightly bigger capacitors, it will be more resilient to dirty
power, which I believe is the reason why it went bad in the first place - put these on a proper power surge/filter to protect
them.
Han beskriver ydermere her hans forklaring til "reperations eksperten" der påstod den ikke kunne fikses:
"According to "experts" changing the capacitors won't fix it, first the ICs were likely the ones damaged and can't be
repaired (yeah right, solid state parts are known to last 3-4 times longer than electrolytic caps).
second excuse; there was another logic board hidden behind the sub woofer that cannot be removed. I laughed at this one,
because I dismantled the whole thing in front of him and left him speechless.
In the end i got fed up, bought a new soldering iron, solder, and capacitors and redid the whole thing myself.
Hvis det bare er de kapacitorer som skal skiftes burde det være overkommeligt. Så er det bare lige hvad for nogle man skal
sætte I, men det har I nok mere forstand på end mig :)
MVH David.
Til top Vis ParadokS's Profil Søg efter andre indlæg skrevet af ParadokS Besøg ParadokS's Websted
ParadokS
Sendt: 27 September 2013 kl. 18:00 | IP-adresse registreret
Det var ikke så mange svar endnu. Jeg sku måske sige at fair pris er ~500 :P
Sendt: 27 September 2013 kl. 19:25 | IP-adresse registreret
Nu kan jeg ikke ud fra dine billeder se, om det er en switch-mode strømforsyning, der sidder i, hvis det er det, skal du ikke ændre på værdien/kapaciteten. I det tilfælde, er den 47µF sikkert den, der giver feedback til controller-ic´en. Du skifter dem med samme værdi, 105 graders type og med en spændingsværdi på 100 volt på dem begge to. Køb den dyreste og bedste kvaitet, du kan få. Det vil max koste dig 20-30 kr. for dem begge 2. Så kører det igen i årevis. Hvis det en forsyning med nettrafo i, gør du bare som beskrevet alligevel.
ParadokS
Sendt: 27 September 2013 kl. 22:20 | IP-adresse registreret
det er ikke prisen på materialerne der bekymrer mig.. jeg mangler en der har udstyret og knowhow til at skifte det. Men gider
ikke betale 2000 for det. Dog gerne en rimelig pris :)
Sendt: 27 September 2013 kl. 23:59 | IP-adresse registreret
Ja, jeg bor s´gu nok i den forkerte ende af DK i forhold til dig, men der er sikkert masser her på forum fra hovedstaden, der kan svinge en loddekolbe til den meget ukomplicerede rep., der her er tale om.
ParadokS
Sendt: 28 September 2013 kl. 00:41 | IP-adresse registreret
Mange tak for informationen. Så er jeg et skridt videre i forberedelsen. Jeg vil prøve at åbne den og tage et par billeder senere.
ParadokS
Sendt: 28 September 2013 kl. 01:31 | IP-adresse registreret
Så fik jeg åbnet dyret og taget et par billeder. Men ved ikke hvor meget du kan se på dem :)
Har lavet et mini-album på IMGUR.
Ved du evt. hvor man skal/kan købe de to kapacitorer henne og. evt . hvilket mærke som er det bedste?
Sendt: 28 September 2013 kl. 03:51 | IP-adresse registreret
Det er lidt svært at se på billederne. På det første billede af komponentsiden sidder der en lyt(cap til venstre for de to røde ledninger, der ser ud som om den er bulet op i toppen. Hvis det er tilfældet, skal den også skiftes. Ellers er det tæt på ligemeget med fabrikat. Du går bare ind i den nærmeste forretning med løsdele og siger, at du skal ha´ de to (47+100uF) i den bedste kvalitet, de har. Husk 105 grader og min. 63 volt (helst 100 volt).
https://www.elextra.dk/main.aspx?page=article&artno=H232 82
https://www.elextra.dk/main.aspx?page=article&artno=H303 91
ParadokS
Sendt: 28 September 2013 kl. 05:19 | IP-adresse registreret
Ja. jeg er heller ikke så handy med kameraet. Men fik ændret fokus så nu ser det bedre ud tror jeg :)
imgur
Man sku tro de havde sat den grå ledning fast med tapetklister eller et stykke tyggegummi. Ved ikke lige hvad det er for en du
syntes der buler (?).
Sendt: 28 September 2013 kl. 10:42 | IP-adresse registreret
Det gør jeg heller ikke længere, med mindre du har pillet noget ud siden i går. Det hjalp lidt med bedre fokus
Sendt: 28 September 2013 kl. 17:46 | IP-adresse registreret
Er det den store lyt, du mener der buler, Boydk, så er det bare støv på toppen og en finger, der har rørt toppen.
ParadokS
Sendt: 28 September 2013 kl. 18:03 | IP-adresse registreret
Der må da være en med lidt teknisk snilde som vil tjene en plov + frokost for at skifte et par dimser :D
Kom frisk!
ParadokS
Sendt: 29 September 2013 kl. 03:30 | IP-adresse registreret
capacitors).
Nu har jeg lige dobbelt checket, og jeg kan faktisk ikke finde nogle lign. hvor der står 47uF/50V eller 100 uF/35V og det er jo ik
så fedt :D
Jeg kan finde 4 der hedder 47uF/160V tilgengæld :(
Så er det jo nærmere tilbage til tegnebrættet....
madmax
Bruger siden: 06 Oktober 2008
Sendt: 29 September 2013 kl. 09:03 | IP-adresse registreret
Efter min mening , ville jeg ikke bruge så meget tid på den dims.Det har ikke noget med hi-fi at gøre , køb heller en lille forstærker og et sæt rigtige højtaler.
fås her http://dk.farnell.com/panasonic/eca1ham470x/capacitor-47uf-5 0v/dp/8767408
madmax
ParadokS
Sendt: 29 September 2013 kl. 09:27 | IP-adresse registreret
en lille forstærker og rigtige højtalere løber hurtigt op, plus det her 2.1 sæt lyder p***e godt allerede. Og det fylder ingenting på
mit bord.. "rigtige" højtalere fylder. og bassen syntes jeg altid mangler noget i de der mindre bord højtalere uden en rigtig
subwoofer.
Det var forresten på komponent print pladen jeg ikke kunne finde de der 47uF 50V, ikke på webshoppen :P
omegasteffy
Sendt: 29 September 2013 kl. 11:52 | IP-adresse registreret
Tag close up pics (brug makro) af alle lytter der fejler noget.
Skriv lidt mere præcist hvor i (for jyder og tidligere jyder går det altså et stykke ud)
På brugt markedet kan du sagtens finde et sæt ScanDyna A20 el A25 + ældre forstærker til en plovmand... alligevel synes jeg det er lidt skam at et højtalersæt bukker tidligt under. Sikkert for at spare nogle få kr på lytter.
Til top Vis omegasteffy's Profil Søg efter andre indlæg skrevet af omegasteffy
ParadokS
Sendt: 30 September 2013 kl. 22:03 | IP-adresse registreret
Så var der sgu en der postede en nice detaljeret løsning endelig!! http://www.fixya.com/support/t8840595-
razer_mako_2_0_speakers https://www.dropbox.com/sh/cvlnyj5cmkdr8yl/7tNh8CsSAj#lh:nul l-Mako.jpg
dipolist
Bruger siden: 24 September 2013
Sendt: 30 September 2013 kl. 22:09 | IP-adresse registreret
Retter lige link (Håber det er iorden)
Til top Vis dipolist's Profil Søg efter andre indlæg skrevet af dipolist
ParadokS
Sendt: 30 September 2013 kl. 22:22 | IP-adresse registreret
ja sorry.. ;D
omegasteffy
Sendt: 30 September 2013 kl. 22:57 | IP-adresse registreret
Kan du ikke kontrollere om det er samme værdier på dit PCB?
Der kan være forskel mellem US og EU udgaven.
+ evt. se om de ser ud til at have udvidet sig.
