Søg efter produkter i Tilbudsavisen |
Vincent DAC-700 D/A-Converter |
Produkttype: |
Konverter |
Annoncetype: |
Demo tilbud |
Demo tilbud: Vincent DAC-700 D/A-Converter |
Digital/Analogue-converter for the highest demands. |
Totally six different inputs are available, working with a sampling rate up to 32 bit abd supports DSD files. The analogue part is working fully balanced and has a tube output stage.
Se mere på: https://www.hifi4all.dk/content/templates/anmeldelser.asp?articleid=3545&zoneid=3
https://www.i-fidelity.net/testberichte/high-end/vincent-dac-700/test.html
Technical Specifications Sampling Rate Coaxial, Optical: PCM 24 Bit / 192 kHz (DSD 64) Sampling Rate USB: PCM 32 Bit / 384 kHz (DSD 512) Frequency Response: 20 Hz – 20 kHz (+/- 0.5 dB) T.H.D.: <0.004 % Signal-To-Noise-Ratio: >95 dB Dynamic Range: >100 dB Audio Output Voltage: 2.5 V Channel Separation: >90 dB Output Impedance: 600 Ohm Max. Power Consumption: 35 W Inputs: 1 x USB, 2 x Optical, 2 x Coaxial, 1 x AES, 3.5 mm Jack (Power Control) Outputs: 1 x Stereo RCA, 1 x Stereo XLR, 3.5 mm Jack (Power Control) Tubes: 1 x 6Z4, 2 x 12AU7 Playable Formats: MP3, WMA, AAC, AAC+, ALAC, FLAC,APE, WAV, DSD Colour: Black / Silver Dimensions (W x H x D): 430 x 95 x 360 mm Weight: 6.9 k |
Øvrige informationer om dette tilbud: |
Tilbud oprettet: |
18-04-2024 |
Tilbud udløber: |
16-05-2024 |
Garanti: |
2 år og 0 mdr. | | |
Kontakt : Dans TV |
Vær venligst opmærksom på at HIFI4ALL.DK ikke er sælger af produkterne i Tilbudsavisen Al henvendelse skal ske til den respektive annoncør! |
