Her er du: Tilbudsavisen - Annonce 21. september 2020 | 11:15
Redaktionelt
Forsiden
Nyheder
Anmeldelser
Indsigtsartikler
Besøgsartikler
Arrangementer
Interaktivt
Køb, Salg & Bytte
Tilbudsavisen
Debat Forum
Services
Kontakt
Søgning
Søg efter produkter i Tilbudsavisen
Udskriv annoncen
Acoustic Signature TA 1000 tonearm
Annoncør: Blue Cat Audio
Kontakt: kontaktbluecataudio.dk
Produkttype: Tonearm
Annoncetype: Tilbud
Tilbud:
Fåes i 3 forskellige farver og i 3 forskellige længder.
TONE ARM TA-1000
At our classic bestseller the TA-1000 we only use precision miniature bearings from the manufacturer SKF. The bearings are ultra-precisely adjusted during the production process. The bearings are added with minimal pre pressure for zero backlash to achieve a minimum friction and maximum stability. When it comes to arm tubes – 2 mutually exclusive conditions need to be combined. Maximum stiffness and low resonance achieved by internal damping. Very stiff materials are hard and therefore very susceptible to resonances.
The solution is a custom made dual carbon tube. The two pipes are joined by connecting elements. This creates a very rigid tube with a high internal damping and resonance.
The TA-1000 uses a Mogami cable for internal wiring and a 5 pin connector. To set up a pickup perfect it is required to compensate the possible misalignments of the stylus.
The TA-1000 allows you to exactly adjust the Azimut angle. For this you simply open 3 small screws and then the arm tube can be swiveled for ± 5 degrees so the angle can be adjusted perfect for each cartridge. If these screws are again tightened the arm tube sits stiff and perfectly adjusted. This mechanical piece of art is available in 9, 10 and 12 inch length.
Læs evt. mere på:
https://bluecataudio.dk/produkt/acoustic-signature-ta-1000/
https://acoustic-signature.com/en/tone-arms/ta-1000/
Øvrige informationer om dette tilbud:
Tilbud oprettet: 29-08-2020
Tilbud udløber: 26-09-2020
Garanti: 2 år og 0 mdr.
Pris: 10999 DKK
TA-1000
Kontakt : Blue Cat Audio
Blue Cat Audio
Østerbrogade 15
7200 Grindsted
TLF.: 50450661 eller 31375411
Mail: kontaktbluecataudio.dk
Link: http://www.bluecataudio.dk
Vær venligst opmærksom på at HIFI4ALL.DK ikke er sælger af produkterne i Tilbudsavisen
Al henvendelse skal ske til den respektive annoncør!
Persondatapolitik  |  Copyright Copyright © 2020 HIFI4ALL.DK - Alle rettigheder forbeholdes
