Søg efter produkter i Tilbudsavisen |
Cayin CS-100A |
Produkttype: |
Intg. Forstærker |
Annoncetype: |
Tilbud |
Tilbud: Cayin CS-100A |
Kræfter til selv de mest uhåndterlige højtalere. |
The new dual-mode Cayin Audio CS-100A tube amplifier is rated at 80 watts per channel in Class AB Ultra-linear mode and 50-watts per channel in triode mode. With an on-board bias meter, the integrated amplifier can run either KT-88 or EL family tubes and uses silver internal wiring. The CS-100A incorporates a 6SN7 tube for voltage amplification, 12AU7EH for phase inversion/voltage amplification and 12BH7EH for voltage amplification and driver stages, with KT-88 or EL-34 output valves. Soft-Start circuitry protects the amplifier and extends the life of internal components and tubes. A high grade Alps volume control, audio-grade capacitors, carbon film resistors, toroidal transformer for power supply and wide-bandwidth EI output transformers are all standard.
ATTRAKTIV FINANSIERING TILBYDES - KONTAKT OS FOR AT HØRE NÆRMERE. |
Øvrige informationer om dette tilbud: |
Tilbud oprettet: |
31-01-2019 |
Tilbud udløber: |
28-02-2019 |
Garanti: |
2 år og 0 mdr. | | |
CS-100A |
Kontakt : Blue Cat Audio |
Vær venligst opmærksom på at HIFI4ALL.DK ikke er sælger af produkterne i Tilbudsavisen Al henvendelse skal ske til den respektive annoncør! |
