Her er du: Tilbudsavisen - Annonce 17. februar 2019 | 19:47
Redaktionelt
Forsiden
Nyheder
Anmeldelser
Indsigtsartikler
Besøgsartikler
Arrangementer
Interaktivt
Køb, Salg & Bytte
Tilbudsavisen
Debat Forum
Services
Kontakt
Søgning
Søg efter produkter i Tilbudsavisen
Udskriv annoncen
Zu Audio Option Power Cable
Annoncør: Blue Cat Audio
Kontakt: kontaktbluecataudio.dk
Produkttype: Kabler
Annoncetype: Tilbud
Tilbud:
Pris er for 1,0 meter. Andre længder er selvfølgelig tilgængelige i vores drop down menu på hjemmesiden.
Zu Option-Power a conservatively priced, high performance power cable designed to serve most types of audio and precision electronics with an emphasis on better matching of modern compact and lightweight gear. Power cords should after all improve sound and do it without weighing more than the device it’s suppling power to—really, who likes overweight and unwieldy cables pulling gear off the table or shelf. And yes, the connector should also physically fit the power inlet socket space.
Conductor area was reduced and emphasis shifted to shielding performance, both static/dynamic and incoming/outgoing electromagnetic energy while simultaneously reducing cable weight, bulk and reduced equipment connector size, all to better accommodate cable routing and equipment positioning, and allowing high density/close proximity cabling without sacrificing fidelity or increasing noise.
Option-Power is designed and made by Zu in Ogden, Utah.
Note: this cable is available with your choice of a straight equipment side connector or a right angle (90 degree). Select at checkout, price and quality are the same.
Læs evt. mere på:
https://bluecataudio.dk/produkt/zu-audio-option-power/
https://zu-7.squarespace.com/cable/option-pc-mk-i
Øvrige informationer om dette tilbud:
Tilbud oprettet: 28-01-2019
Tilbud udløber: 25-02-2019
Garanti: 2 år og 0 mdr.
Pris: 899 DKK
Kontakt : Blue Cat Audio
Blue Cat Audio
Østerbrogade 15
7200 Grindsted
TLF.: 50450661 eller 31375411
Mail: kontaktbluecataudio.dk
Link: http://www.bluecataudio.dk
Vær venligst opmærksom på at HIFI4ALL.DK ikke er sælger af produkterne i Tilbudsavisen
Al henvendelse skal ske til den respektive annoncør!
Persondatapolitik  |  Copyright Copyright © 2019 HIFI4ALL.DK - Alle rettigheder forbeholdes
