Her er du: Tilbudsavisen - Annonce 20. april 2019 | 04:33
Redaktionelt
Forsiden
Nyheder
Anmeldelser
Indsigtsartikler
Besøgsartikler
Arrangementer
Interaktivt
Køb, Salg & Bytte
Tilbudsavisen
Debat Forum
Services
Kontakt
Søgning
Søg efter produkter i Tilbudsavisen
Udskriv annoncen
Audion - Select 1.0 Passiv preamp.
Annoncør: Blue Cat Audio
Kontakt: kontaktbluecataudio.dk
Produkttype: Forforstærker
Annoncetype: Tilbud
Tilbud:
NEW!!! Passive preamp. Select 1.0
Audion Select 1.0 Passive Line level pre-amplifier is hand built with quality components. The chassis is black powder coated aluminum as is the base. The top plate is mirror finished stainless steel.
The Audion Select passive line level pre-amplifier 1.0 is a passive device. Built with 5 line level inputs buffered, switched from the front panel, 2 line outputs and a direct un-switched tape output. It is hard wired with an Alps pot fitted and with ground loop lift switch designed to stop any ground loops.. Being a passive pre-amplifier it will not add hum or tube noise to your current equipment
The black aluminium chassis is designed to match cosmetically to the rest of the Audion range in looks and sound quality, and having the same size and shape will fit in with other Audion equipment. It has been designed for users with stereo or monoblock amplifiers to add more inputs and volume control to their setup.
We are able to offer 23 way or 48way stepped attenuators, and / or silver internal wiring, and possibly transformer volume control.
Being a passive stage it will not alter your soundstage, but at the same time it will not diminish it either. In use it is absolutely invisible, with convincing depth even at very low levels. It brings recording to life and places you directly in front of the performance
The name "Audion Select" has been given as it is mainly a selector and in the double entendre stakes it is also a select product..
In future we will be offering a passive pre with balanced in/outs again with the option of silver wiring and stepped attenuators or transformer volume control ..
Amplifier matching:
This Select 1.0 passive Line level pre-amplifier is a great match with our power amplifiers.
This is a very good entry level passive pre-amplifier and can be used as a volume control / channel selector for any amplifier other than ours that does not have a volume control.
FØLG OS PÅ FACEBOOK.
Læs evt. mere på:
http://www.audion.co.uk/pre-amps/Select%201.0%20%20line%20level.html
https://www.facebook.com/bluecataudiodenmark/
Øvrige informationer om dette tilbud:
Tilbud oprettet: 15-04-2019
Tilbud udløber: 13-05-2019
Garanti: 2 år og 0 mdr.
Pris: 4199 DKK
Select 1.0
Kontakt : Blue Cat Audio
Blue Cat Audio
Østerbrogade 15
7200 Grindsted
TLF.: 50450661 eller 31375411
Mail: kontaktbluecataudio.dk
Link: http://www.bluecataudio.dk
Vær venligst opmærksom på at HIFI4ALL.DK ikke er sælger af produkterne i Tilbudsavisen
Al henvendelse skal ske til den respektive annoncør!
Persondatapolitik  |  Copyright Copyright © 2019 HIFI4ALL.DK - Alle rettigheder forbeholdes
